Last year I looked into the health benefits of breathing hydrogen, and I kept bumping into Stan Myers stuff, and I came across someone ( Daniel Donatelli ) who has spent 20 years figuring out what Stan figured out.
Another guy was Bob Boyce, he raced a jet ski with hydrogen made on demand, one day his jet ski went a lot better than usual at a certain rpm, to the point that he removed the engine and set it up on a dyno to figure out why. It turned out the regulator on the alternator had failed and AC was getting into the Electrolyser/cell and helping split the H and O apart more efficiently. He ended up making a circuit that does it on purpose.
From memory, which ain't that good, there are various ways of getting the hydrogen out of water, the most common on youtube is what some call the brute force method, chewing through lots of amps to get the job done. Another way is to setup up what an electrical engineer might call run away circuit oscillation, but when used wisely the oscillation run through coils can produce 1000 times the input voltage returned in back EMF. I think Stan figured out quite a few ways to achieve it, to the point where if electrons are pulled out of water, then the bond between the H and O fall apart, and if done correctly, the H and O stay in suspension. Daniel Donatelli calls it is Nano Bubble Water Fuel, and although it looks like water, it can be burnt, and I think this is what Stan used. There is so much good and bad information about Stan out there it's hard to know where to start, but if anyone can be bothered I'd say, if you can read German try this
slideshare.net/choicethailand
otherwise join this patreon site and ask the guy directly
patreon.com/securesupplies
edit. I have no idea if the above is true or not, that's for the individual to decide :-)
