Old 05-13-2025, 09:40 PM   #24 (permalink)
Macskyver
Macskyver's Avatar
Originally Posted by ECO-AKJ View Post
Maybe look at a Ford Escort or some other 'econobox' that had the hydraulic clutch and brake with cable driven trottle.
That's a good idea. The only caveat is that I would ideally want a pedal assembly from a car that has roughly the same size brakes so the factory master cylinder has enough volume and pressure to actuate the LS430 calipers properly. Either that or I need to make sure it will accept an aftermarket master cylinder.
