Old 05-15-2025, 01:53 PM   #30 (permalink)
Logic
Originally Posted by Macskyver View Post
Today I basically got the engine ready to pull out. That involved removing the exhaust, heat shields and driveline. Here's the exhaust pulled out of the car:
It is in pretty bad shape, especially toward the front. I do like how it splits into the rear duals. I think I'll keep that basic design. I would like to use what's there but I'm concerned it's a bit small though. The larger size where it comes together is under 2.5" and the duals going to the rear are 2". My plan is to come off the turbo with 3" exhaust. The 2" duals would be a restriction to that.
I assume we are talking 1 pipe back from 1 turbo, not 2 as in the pic?
Area of 3" circle = 7.07 square inches.
Area of 2" circle = 3.14 square inches X 2 = 6.28 square inches.
So somewhat of a restriction in the pipes yes, and turbos like backpressure even less than normally aspirated cars do.
But more important is the restriction in the mufflers.
Apparently mufflers worth the name come with a CFM rating.
For power, you want to divide that CFM # by the engine power (desired) and get a number above 2.2 (David Vizard)
Should be similar for economy unless you plan to dawdle around at nothing over 2000 rpm!
Also NB that a turbo does a pretty good job of silencing exhaust, so you can probably get away with one muffler per pipe.
IMHO two or three very free flow mufflers per pipe flow and sound better than one restrictive muffler. This is what BMW does.
I also NB that turbos send the exhaust down the pipe in a spiral.
Now a piece of string spiraled around the exhaust is much longer than the exhaust when straightened out.
That means that the spiral flow after a turbo is to be avoided and should be engineered out.
As you are not averse to swinging spanners at a car/engine, pgfpro's posts on running super high compression and super lean to get 50mpg (IIRC) without an aero mod in sight are well worth the read.
NB that in town driving: 68% of energy is used accelerating weight vs 14% overcoming aero drag.
