Old 05-23-2025, 06:42 PM   #3 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
I used a floor jack outdoors many times. You can either allow the wheels to burry into the dirt, or put plywood under it.
With the plywood method, that allows you to use a creeper too.
Thanks! I might go that route. But I'm also trying to find tools that fit in my practically "tiny-house" life style. So not a lot of storage for things as large as floor jacks, much less for plywood.
But if a floor jack will not need replacing every season, that's probably the route I should go.
