Originally Posted by Gasoline Fumes
If the engine is running while coasting and it goes back into drive smoothly, it's probably OK. But no guarantees!
I tried it in my driveway at low speeds, shifts from Drive to neutral fine but that was at low speed, i think i will try again on my way home and do it at slow speed and then slowly try at higher and higher speeds.
Apparently from what ive read the older auto's are fine, its the newer ones with all the fancy sensors and what not that could cause possible damage.
