Thread: HVAC Heat Pump
Old 12-27-2025, 05:01 PM   #95 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
I believe my parents furnace was 80 - 90,000 BTU. Variable speed blower - 97% efficiency - etc. About as expensive as you can get but the federal tax credit and utility rebate paid the difference between the high efficiency option and the 92% efficiency unit the HVAC guy wanted to sell them. They have a site built home with a basement. Furnace and duct work is in the basement so heat lost from the ducting is not actually lost.
Yes, mobile home units can be more expensive - just like everything mobile home or RV specific.
Got it! So a 40-50,000 BTU at 95% would hopefully be less than $10,000, even though it is for a mobile home. I was told it shouldn't be above $7,000 for me by that HVAC tech who works in Colorado. He didn't say if that's with some sort of credit or utility rebate or not. Just to expect $5,000 to $7,000, and not more than $7,000.
From your description I thought you had a ducted unit but it sounds like you don't. Sounds like the one that was in my grandmother's mobile home or the one in my parent's lake house. (Just a vertical unit that sucks air in from the bottom and blows hot air out the top located in the hallway near the middle of the home (or vice versa - there are updraft and downdraft versions) (See Below)
When I was giving prices I was talking installed for the forced air heat pump.
What did I say that sounded like it wasn't ducted? It is ducted, with 6 floor vents (actually 5 now since we covered one to put the frige over it) that blow heat out. They are about 8.5 x 4" in size. The duct goes along under the trailer with the furnace in the middle.
So that $4,500 for the unit + installation + having an electrician run the 220 line to power it.
If I had one installed I'd probably just go with whatever the installer offers. I have no idea what the unit price would be through an installer, just that it's no more than $7,000 for a gas unit installed.
If I go with a heat pump I think I'd go the DIY route: I'd put in my own 240V line and install it myself. I can just take the one that I installed for the 40A EVSE that was at the front door. It's plenty long, all I'd have to do is cut it as it goes right by the furnace under the floor.
DIY units generally prefilled and have prevacuumed lines with fixed hose lengths. With a forced air unit generally the lines are too long and even if the unit is prefilled you need to add more refrigerant to accommodate the extra volume from the long lines.
Interesting. That makes for a lot of unknowns. Like, where is the exterior unit going to go? What does the extra refrigerant cost?
If it takes hours to raise your house temp to 65F in the morning with a forced air furnace a heat pump will not work for you. Not unless you keep your house much warmer at night - which will cost money.
Yeah. It's sounding more and more like I should just ask an installer what is best and go with that option.
This is my exact unit I currently have (Coleman 7663):
