Originally Posted by redpoint5
Very neat, but I consider unsprung weight to be behind other shortcomings of hub motors such as durability and power output. I realize things are typically improved incrementally though, and this would be a good incremental improvement. Perhaps it has improved upon the durability issue as well?
From what I recall power... well torque is not the problem.
Power is just 'torques' x rpm after all.
4 bog std Chinese hub motors, in rims, have 1400Nm from 0 rpm!
Enough to pull a train!
https://www.qsmotor.com/car-motor/
If you're talking hub power or unsprung weight per kg; well that's a different story.
A light motor is generally a weak motor.
But these guys seem to have decent numbers.
As it's open:
