Here is the Citroen Tubik 21
Would it make sense to put DBD before, in, or after the venturi? Inner and outer faces?
This would create an air curtain for the back of the vehicle.
Trailing:
You're trying to get flowing air to go around a (rounded) corner it normally wouldn't.
Where it would break away and become turbulent.
So where would you put DBD..?
Leading:
Imagine you are shooting ping-pong balls, in the direction of airflow only, at the nose of a car.
Any ball that comes straight back is where there's static pressure buildup.
Any direction besides straight back is better.
With parallel to the surface best. (It even creates vacuum, pulling the car forward)
But you Already knew that...
There you go. But do NB that there are other forums etc you would enjoy
