I used to wonder that myself. When I was young and clueless I tried running it out of gas once to see if the light worked. No light.
Both of my 6000s have the full gauge cluster. I pulled another one for parts once. I believe the light spot is there for visual symmetry only, since it would look kinda corny otherwise. There was nothing printed in the low fuel light spot, like there is in every other unused spot. There is no bulb hole, though one could be carved. And right behind the bulb spot is the tachometer control board. So Im sure it didnt come with one, at least in the analog cluster. But Im sure one could be put in without too much modification.
Winter daily driver, parked most days right now
Summer daily driver
