Not getting into inches and ounces for a moment, how hard would it be to only switch to the centigrade system? (I used "centigrade" as not to use anyone's name
It seems that temperature is more independent from all of the other measures, while lengths, volumes and weights a more intertwined with each other. This should make it slightly easier to implement.
I know it'd be odd at first, as old recipes would ask for oven temperatures of 400 deg. (F), while a "metric" oven would only go to 250 deg. (C). Also, 32 deg.F is literally freezing, while 32 deg.C is starting to be on the hot side. Plus centigrade has a lower "resolution", i.e. 1 deg.C is about 2 deg.F.
What matters is
where you're going, not
how fast.
