2018-12-18 |
65.3 |
1.0108 |
64.6 |
"Apparently the Insight is more efficient at stop-n-go, short trips doing pizza delivery once warmed up than I thought." |
2018-12-19 |
49.7 |
0.7611 |
65.3 |
"Forced regen for a small bit again. Need a calpod switch to avoid unnecessary use of the IMA during delivery runs. IMA working well." |
2018-12-20 |
105.6 |
1.6122 |
65.5 |
"Lots of deliveries tonight. Learning how to regen better. Battery never went below 70% charge." |
2018-12-22 |
128.3 |
2.0694 |
62 |
"Colder weather plus more low speed driving and turning around. Fought the IMA to keep it charged due to repeated use of assist." |
2018-12-23 |
125.4 |
1.9624 |
63.9 |
"Fought forced regen for the first half." |
2018-12-26 |
77.4 |
1.217 |
63.6 |
"Normal pizza delivery driving. Passenger mirror delete helped some." |
2018-12-27 |
74.3 |
1.1431 |
65 |
"Terrible weather gave only upper 50s MPG for the first half; somehow got better the last half." |
2018-12-29 |
67.6 |
1.0696 |
63.2 |
"Normal pizza delivery driving. Snow + icy roads after finished delivering." |
2018-12-30 |
121.6 |
1.7726 |
68.6 |
"40 F instead of 30 F for most driving. Just did well overall." |
2019-01-01 |
68.9 |
1.0519 |
65.5 |
"Brake reduction clips installed. Shifts at 2300-2700 RPMS instead of 2100-2400 RPMs." |
2019-01-05 |
60.2 |
0.9094 |
$1.99 |
66.2 |
"Initial trips were super short (~55 mpg). Got better toward the end. Had a battery negative and then positive recalibration." |
2019-01-06 |
49 |
0.7195 |
68.1 |
"First day delivering with the regen switch. Keeps IMA charged nicely!" |
2019-01-07 |
25.5 |
0.3905 |
65.3 |
"Only 4 delivery runs. Most were < 2 miles. One longer trip of 75-80 MPG (stars aligned ) kept the overall MPG decent. Those <2 mile runs were about 55-58 MPG.." |
2019-01-10 |
24.4 |
0.3604 |
67.7 |
"Earlier shift, not as many deliveries, colder engine, but starting to do some EOC." |
2019-05-12 |
87.4 |
1.2156 |
71.9 |
"Summer is here. Cooler day though. Main FE mods since last pizza delivery are additional belly pan and 80 PSI in tires." |
2019-05-13 |
59.9 |
0.7573 |
79.1 |
"Not any warmer than the other day. This pizza delivery mileage is insane. No IMA, pretty much no hypermiling." |
2019-05-17 |
58.2 |
0.7897 |
73.7 |
2019-05-18 |
91.8 |
1.1562 |
79.4 |
2019-05-20 |
28.6 |
0.3603 |
79.38 |
2019-05-23 |
77.2 |
0.9962 |
77.49 |
2019-05-24 |
123.5 |
1.5457 |
79.9 |
2019-05-25 |
123.8 |
1.5495 |
$2.549 |
79.9 |
2019-05-27 |
71.3 |
0.9284 |
$2.549 |
76.8 |
2019-05-29 |
36.6 |
0.4453 |
$2.549 |
82.19 |
2019-05-30 |
18.2 |
0.2935 |
$2.549 |
62.01 |
"Short delivery runs, and few of them. Cold engine most of the time. Catalytic broke off at the end so I stopped delivering for the day." |
2019-06-07 |
33.8 |
0.5068 |
$2.549 |
66.69 |
"New catalytic converter. Forgot to reset the 12V, so the car ran rich whenever it wasn't in lean burn, which is quite often during pizza delivery." |
2019-06-08 |
82 |
0.9591 |
$2.549 |
85.5 |
"First good warm day delivering (over 80 degrees)." |
2019-06-09 |
54.3 |
0.6822 |
$2.549 |
79.6 |
2019-06-10 |
50.1 |
0.6081 |
$2.549 |
82.39 |
2019-06-12 |
80.6 |
0.97 |
$2.549 |
83.09 |
2019-06-13 |
69.6 |
0.9039 |
$2.549 |
77 |
2019-06-14 |
80.4 |
0.9595 |
83.79 |
2019-06-15 |
47.6 |
0.5877 |
80.99 |
2019-06-17 |
79.3 |
0.9407 |
84.3 |
2019-06-19 |
47.7 |
0.5612 |
85 |
"First delivery day with IMA deleted." |
2019-06-20 |
47.4 |
0.5657 |
83.79 |
2019-06-21 |
60.5 |
0.7019 |
86.19 |
2019-06-28 |
82.7 |
0.9261 |
89.3 |
"First trip with the Meanwell pseudo-alternator" |
2019-06-29 |
46.9 |
0.5441 |
86.2 |
2019-07-01 |
73.6 |
0.8559 |
85.99 |
"Did a redline pull to 55 to get out of the way of traffic." |
2019-07-03 |
78.2 |
0.8877 |
88.09 |
2019-07-04 |
81.8 |
0.8999 |
90.9 |
2019-07-05 |
80.5 |
0.9015 |
89.3 |
"Did one 4500-500 RPM shift-point acceleration." |
2019-07-06 |
43.4 |
0.5065 |
85.69 |
2019-07-08 |
45.9 |
0.5199 |
88.29 |
2019-07-11 |
26.3 |
0.3313 |
79.38 |
2019-07-12 |
74.4 |
0.8879 |
83.79 |
"Had my time and gas wasted at a couple stops, heavier traffic, higher upshifts at times." |
2019-07-13 |
66.6 |
0.756 |
88.1 |
"Downshifted to 2nd once to pass someone." |
2019-07-14 |
57.7 |
0.6587 |
87.6 |
"Was over 90 for the first half, then had a run over some terrible gravel roads, low speed and lower mileage. A friend drove the car around the parking lot and knocked it down by 1.2 MPG at the end." |
2019-07-15 |
0.1305 |
81.99 |
2019-07-17 |
66.9 |
0.7264 |
92.1 |
"Over 90 degrees today. Had a 6 mile run with the Meanwell accidentally disabled that was over 100 MPG." |
2019-07-18 |
50.6 |
0.5823 |
86.9 |
"Raining at the beginning of the shift but still just over 80 MPG. Warmed up and got better." |
2019-07-19 |
64.1 |
0.6856 |
93.49 |
"Another hot day." |
2019-07-22 |
71.2 |
0.7894 |
90.2 |
"Hypermiled just a little bit since I was stretching out the tank to 900+ miles." |
2019-07-24 |
82.6 |
0.9178 |
$2.549 |
90 |
2019-07-25 |
48.7 |
0.5358 |
$2.549 |
90.89 |
"2 redline accelerations." |
2019-07-26 |
56.7 |
0.6594 |
$2.549 |
85.99 |
"Busy day." |
2019-07-27 |
50.2 |
0.5811 |
$2.549 |
86.39 |
2019-07-29 |
64.4 |
0.7335 |
$2.549 |
87.8 |
"Wet." |
2019-07-30 |
33.1 |
0.3699 |
$2.549 |
89.48 |
2019-08-01 |
61 |
0.6624 |
$2.549 |
92.09 |
"Insight was running very efficiently today. Sunny, decently warm but not hot. One less efficient run toward the end (in the 80s mpg)." |
2019-08-03 |
1.1 |
0.0173 |
$2.549 |
63.58 |
2019-08-05 |
39.2 |
0.4207 |
$2.549 |
93.18 |
2019-08-06 |
88.6 |
0.9922 |
$2.549 |
89.3 |
"Inefficient driving the first half, 3-5 redline accelerations. Made up for it in the last half." |
2019-08-07 |
29.2 |
0.3561 |
$2.549 |
82 |
"One quite inefficient trip showing a new delivery driver around (multiple near redline accelerations)." |
2019-08-08 |
79.4 |
0.9085 |
$2.549 |
87.4 |
"One longer run with hard acceleration and fast driving up to 70 MPH." |
2019-08-09 |
46.3 |
0.5162 |
$2.549 |
89.69 |
2019-08-10 |
92.2 |
1.0222 |
$2.549 |
90.2 |
2019-08-12 |
59 |
0.6218 |
$2.549 |
94.89 |
"Hypermiled just a tiny bit on my last day of work this summer to get these numbers." |
2019-12-16 |
6.2 |
0.0877 |
70.7 |
"1 run." |
2020-01-10 |
1080.7 |
15.148 |
71.34 |
"12/17 to 1/10 driving summed up" |
