2008-06-06 |
170.7 |
4.282 |
39.86 |
2008-06-06 |
307.6 |
9.249 |
33.26 |
"Used AC alot." |
2008-06-08 |
186.9 |
4.989 |
37.46 |
"Used AC a lot." |
2008-06-13 |
378.1 |
8.633 |
43.8 |
2008-06-17 |
266 |
6.835 |
38.92 |
2008-06-26 |
311.4 |
8.621 |
36.12 |
2008-06-30 |
325.7 |
7.575 |
43 |
2008-07-03 |
204 |
5.403 |
37.76 |
"Realized my tire gauge was off, and I had been running with tires at 30psi, not 35psi as I thought. Got new tire gauge, have tires pumped to 36psi." |
2008-07-04 |
361.5 |
8.917 |
40.54 |
"Driving mostly 55 & 65 mph using cruise control." |
2008-07-06 |
243 |
5.695 |
42.67 |
"A good chunk of these miles were driven on the freeway with the cruise control set at 5 miles per hour over the 55 & 65 miles per hour speed limits. Scheduling was tight, and I needed to drive over 300 miles." |
2008-07-11 |
379.8 |
9.141 |
$4.139 |
41.55 |
2008-07-16 |
373.2 |
8.85 |
$4.12 |
42.17 |
2008-07-18 |
98.5 |
1.97 |
$4.12 |
50 |
"I filled up because we are heading out of town right after work. I filled till it shut off as normal." |
2008-07-19 |
364 |
8.943 |
$4.16 |
40.7 |
"Was surprised I didn't get low 30's mpg. I drove on thru-way at 65 with mixed cruise control, anf steady throttle. Drove very hilly backroads. My wife drove some of the miles. Ack!" |
2008-07-25 |
320.6 |
8.13 |
$4.06 |
39.43 |
"My wife drove the first part of the tank on the freeway using cruise control and no hypermiling techniques. I struggled to improve the average for the rest of the tank, still did not get it above 40mpg. *grumble*" |
2008-08-03 |
348.1 |
8.852 |
$4.06 |
39.32 |
"I was hoping to average over 40mpg on this tank. Not sure. I was struggling to keep my FE up. I did make a lot of short trips on this tank. But my regular trips to and from work seemed to have a lower FE.
I noticed today that one of my tires had a lower PSI than the others. I found what looks like a staple in the tread. I am going to get it fixed tomorrow hopefully. Not sure what this happened. Had to have been since last weekend when I last checked my tires. Maybe this is why my FE was lower than I hoped?" |
2008-08-09 |
351.8 |
8.751 |
$3.97 |
40.2 |
"Included a couple days of stop and go traffic on my way home from work due to accidents. I think I might have been slightly better had it not been for those. Also I think I had my tire fixed after my last fillup due to a nail in it. So a small part of this tank might have been with an underinflated tire." |
2008-08-17 |
323.3 |
8.672 |
$3.88 |
37.28 |
"A crappy tank! I had a slow leaking tire fixed a week ago. Then when I check my tire pressure Saturday, the pressure was down. Still a slow leak. The tire shop said the plug is leaking. My tires are pretty worn, so I am looking at getting a new set of tires. I am going to try to get Bridgestone B381's. Anyway, I am guessing low pressure in the one tire trashed my FE! " |
2008-08-25 |
336.1 |
8.037 |
41.82 |
2008-08-30 |
393.7 |
9.672 |
40.71 |
2008-08-31 |
203 |
5.021 |
40.43 |
2008-09-05 |
382.6 |
8.598 |
44.5 |
"Got my new tires a couple tanks ago. This was the first tank with mostly day-to-day normal driving. My FE seems to be up." |
2008-09-13 |
316.6 |
8.386 |
37.75 |
2008-09-20 |
372 |
9.305 |
39.98 |
2008-09-26 |
241.6 |
6.815 |
35.45 |
2008-09-29 |
412.8 |
9.576 |
43.11 |
2008-10-03 |
114.8 |
3.728 |
30.79 |
2008-10-05 |
399.7 |
9.988 |
40.02 |
2008-10-08 |
392.5 |
9.597 |
$3.5 |
40.9 |
2009-04-22 |
419 |
10.11 |
41.44 |
2009-05-01 |
338.4 |
9.695 |
34.9 |
2009-05-17 |
445.6 |
10.71 |
41.61 |
2009-05-22 |
367.8 |
8.36 |
44 |
