2008-07-16 108.5 2.892 $4.379 37.52 ""
2008-09-12 79.86 2.076 $3.739 38.47 "No freeway"
2008-09-14 121.8 2.161 $3.639 56.36 "Freeway and country roads. Only 1.5 commute days."
2008-09-26 98.4 2.551 $3.599 38.57 "Mostly commute on surface streets. I blocked most of the oil cooler since the temp is dropping. Runs much better in the morning with blocked cooler."
2008-10-15 104 2.618 $3.339 39.72 "Partial oil cooler block is improving cool weather warm up and performance"
2008-10-27 97.25 2.362 $2.699 41.17 "Commute"
2009-03-13 104.3 2.6 $2.139 40.12 "3 days commute with mornings in the 30s. One 65 mile trip."
2009-05-27 99 2.634 $2.659 37.59 "Commute
Bike sat off and on because of helmet problem"
2009-06-11 104.7 2.379 $2.899 44.01 "Commute"
2009-06-24 103 2.521 $2.899 40.86 "Commute, 5 miles freeway, refilled at 76 station instead of Chevron"
2009-07-24 99.6 2.509 $2.779 39.7 "Finally cleaned the air filter"
2009-08-11 109.4 2.642 $2.999 41.41 "commute plus 20 mile roundtrip to church on Freeway"
2009-09-04 110 2.685 $3.099 40.97 "Commute"
2009-09-16 112.1 2.282 $3.139 49.12 "80 mile round trip to Grass Valley the rest was commute"
2009-09-28 105.4 2.564 $2.959 41.11 "Commute, refueled at 76 station"
2009-10-21 101.5 2.643 $2.859 38.4 "Commute. Filled really full."
2009-11-08 114.4 2.832 $2.839 40.4 "Commute and two trips to church (freeway)"
2010-02-17 94.9 2.49 $2.729 38.11 "Winter - The bike has been sitting a lot."
2010-04-09 111.5 2.805 $2.999 39.75 "Commute"
2010-05-19 117.4 2.953 $3.079 39.76 "Commute. Need to add 4 miles to the next tank since I forgot to reset the odometer."
2010-07-21 103.1 2.742 $3.139 37.6 "Commute - lots of time between use"
2010-07-30 101.7 2.4 $3.059 42.38 "Commute"
2010-08-18 124.3 3.07 $3.159 40.49 "Commute"
2010-10-10 107.3 2.715 $3.099 39.52 "Commute
Installed new cables, chain, sprockets, and tires. Rear sprocket is 1 tooth smaller which should improve mpg in the future."
2010-10-21 125.1 2.88 $3.099 43.44 "First full tank with new sprocket"
2010-11-11 107.5 2.78 $3.339 38.67 "Very Full Tank
Days are getting colder - carb icing in morning
Premium fuel"
2011-03-30 109.6 3.128 $4.059 35.04 ""
2011-05-19 121.5 3.243 $4.039 37.47 ""
2011-07-12 106.2 2.76 $3.739 38.48 "Engine surging, tires low"
2011-07-16 120.7 2.62 $3.639 46.07 "sync'd carbs 60 miles in and then took 60 mile ride"
2011-08-04 130.3 3.288 $3.839 39.63 "First full tank on synch carbs. Really full tank."
2011-08-22 138.1 3.288 $3.699 42 "Added injector cleaner to fuel"
2011-09-26 125.3 3.193 $3.799 39.24 ""
2011-10-31 130.7 3.2 $3.759 40.84 ""
2012-02-26 92.6 2.707 $4.199 34.21 ""
2012-04-04 107.2 2.887 $4.239 37.13 ""
2012-05-22 110.3 2.858 $4.299 38.59 ""
2012-06-03 78.5 1.974 $3.999 39.77 ""
2012-06-07 121.2 2.463 $4.079 49.21 "90 mile ride on the freeway and the back roads"
2012-08-23 129.7 3.407 $4.119 38.07 ""
2012-09-27 107.2 2.749 $4.099 39 ""
2012-10-14 160.5 3.867 $4.299 41.51 "60 mile freeway, rest commute"
2013-02-23 92.1 2.394 $4.139 38.47 ""
2013-04-24 106.5 2.627 $3.859 40.54 ""
2013-06-05 167 3.36 $3.909 49.7 "Trip to end of Forest Hill Road - stopped at snow."
2013-07-22 122.8 2.593 $3.859 47.36 ""
2013-10-01 159.8 3.251 $3.919 49.15 "Trip to Forest Hill and beyond"
2013-11-15 128.5 3.051 $3.399 42.12 ""
2014-01-26 100.5 2.651 $3.499 37.91 ""
2014-04-07 145.2 3.636 $3.839 39.93 ""
2014-04-18 132.6 3.011 $3.859 44.04 ""
2014-06-01 109.1 2.421 $3.889 45.06 "Added new oil cooler block (cover) half way through the tank."
2014-06-26 106.3 2.313 $3.959 45.96 ""
2014-10-28 114.9 3.117 $3.019 36.86 "Put motorcycle back together after electrical issues. Sat all summer."
2014-11-16 140.8 3.081 $3.799 45.7 ""
2015-03-21 121.4 2.757 $3.299 44.03 ""
2015-06-04 106.5 2.225 $3.259 47.87 ""
2015-08-10 114.8 2.497 $3.159 45.98 "Switched to thinner oil - Mobil 1 5w-30 synthetic"
2015-09-14 139.3 2.941 $2.579 47.36 ""
2015-11-21 113.8 2.602 $2.299 43.74 ""
2016-03-23 93 2.093 $2.469 44.43 "Ride to Foresthill"
2016-04-07 104.3 2.208 $2.519 47.24 ""
