2007-01-19 |
493 |
15.06 |
32.74 |
2007-03-08 |
496 |
14.58 |
34.02 |
2007-03-30 |
491 |
14.71 |
33.38 |
2007-05-05 |
466 |
14.94 |
31.19 |
2007-05-22 |
515 |
14.94 |
34.47 |
2007-06-14 |
504 |
14.61 |
34.5 |
2007-07-04 |
488 |
14.12 |
34.56 |
"mild weather, mostly commute" |
2007-08-01 |
529 |
15.33 |
34.51 |
2007-08-22 |
520 |
13.82 |
37.63 |
"best mileage ever! Manual coast shutoff entire tank; summer vacation (--> less traffic); mild weather" |
2007-10-02 |
506 |
15.04 |
33.64 |
"Higher consumption despite manual coast shutoff entire tank and stoplight shutoff about 1/4 of tank. Perhaps shorter trips (vacation; about 3 trips instead of commute; cooler weather; higher tire pressure (2.5 bar)" |
2007-11-01 |
507 |
14.7 |
34.49 |
"Above-bumper grill block. Relatively mild weather for time of year" |
2007-11-29 |
491 |
14.74 |
33.31 |
"Winter tires installed, inflated to 2.5 bar. Now cooler weather. Last tank nozzle may have filled slightly less than usual, but then I added ca. 1 litre from lawnmower canister, so net about zero. Engine off at long stoplights." |
2007-12-22 |
510 |
15.14 |
33.69 |
"Colder; clutch coast last 150 km; Aral usual nozzle" |
2008-01-24 |
517 |
15.21 |
33.99 |
"Relatively mild; vacation 1st 150 km (shorter trips, wife on board); battery replaced after 300 km; mild pulse & engine-idle glide entire tank; some stoplight shutoffs; muffler replaced; (usual Aral nozzle)" |
2008-02-16 |
573 |
14.84 |
38.61 |
"Best FE ever! (Mild pulse & engine-idle glide, frequently also engine-off) entire tank; ca. 15 kg weight removed from trunk; frequent stoplight shutoff, key off ca. 1 s means some rolling distance not measured, usual nozzle" |
2008-03-18 |
596 |
14.53 |
41.02 |
"Mild P&G and frequent EOC. Usual nozzle may have shut off a tick early." |
2008-04-14 |
579 |
14.31 |
40.46 |
"Mild P&G and EOC. Installed engine stop/start buttons (eliminates odometer blackout periods caused by key switching). Highway cruising speed 90 km/h vs. 100 km/h. One 15-minute stop-and-go traffic jam. Ca. 15 km driving by wife." |
2008-05-10 |
573 |
14.97 |
38.28 |
"New starter (156 EUR); oil pressure switch replaced in shop (lots of idling?)" |
2008-06-09 |
623 |
14.9 |
41.81 |
"Broke the 1000 km per tank barrier! 24 km by spouse (corrected 5.58 l/100km)" |
2008-07-16 |
619 |
15.1 |
40.99 |
"75 km by spouse (spouse-compensated 5.60 l/100km; 42.0 mpg)" |
