2009-03-31 |
15.7 |
$1.89 |
18.28 |
"I ADDED ONE BOTTLE OF HEET" |
2009-04-11 |
306.8 |
16.3 |
$1.93 |
18.82 |
"USED SAME GAS STATION AS BEFORE BUT NO HEET" |
2009-04-22 |
330.4 |
16.71 |
19.77 |
"SAME GAS STATION NO HEET" |
2009-05-06 |
337.5 |
17.03 |
19.82 |
2009-05-21 |
455.5 |
21.54 |
$2.369 |
21.15 |
"had to put in 5.5 gallons in philly to make it home." |
2009-06-03 |
335.4 |
16 |
20.96 |
2009-06-17 |
325.2 |
16.25 |
20.01 |
"DROVE LIKE AN A**HOLE FOR A COUPLE DAYS AND USED TH AC FOR A SHORT PERIOD." |
2009-07-05 |
436.7 |
20.33 |
$2.49 |
21.48 |
"Drove like an as*hole for about 5 days, used the AC for a day, and drove around philly for the day. had to get a couple gallons to get home." |
2009-07-19 |
337.1 |
16.54 |
20.38 |
"PUT SOME SEA FOAM THROUGH THE INTAKE AND IN THE GAS. FILLED UP WITH 89 INSTEAD OF THE USUAL 87." |
2009-08-02 |
351.9 |
16.92 |
20.8 |
"FILLED UP WITH 89 AGAIN, IT SEEMS TO BE GETTING BETTER FE WITH THAT GAS." |
2009-09-11 |
336 |
16.07 |
20.91 |
"I used 89 octane, seems to work better. I had to skip a tank my gauge cluster was broke and odometer didn't work." |
2009-09-23 |
322.2 |
15.12 |
21.31 |
"USED 89 AS USUAL" |
2009-10-03 |
328 |
16 |
20.5 |
"FILLED UP WITH 89" |
2009-10-15 |
310 |
16.06 |
$2.489 |
19.3 |
2009-10-28 |
17.1 |
$2.71 |
18.71 |
2009-11-08 |
323.5 |
16.42 |
19.7 |
2009-11-21 |
193.5 |
10.59 |
$2.549 |
18.27 |
"FILLED UP WITH 87 BEFORE I KEFT FOR A DRIVE UP TO WIND GAP PA." |
2009-11-26 |
16.17 |
23.81 |
"285 OF THE MILES WERE HIGHWAY DOING BETWEEN 65 AND 85. THE REST WAS LOCAL DRIVING" |
2009-12-09 |
300 |
17.29 |
17.35 |
"IDLED ALOT FOR WARMUPS AND CHANGED THERMOSTAT." |
2009-12-21 |
287.5 |
17 |
16.91 |
"ALOT OF WARM UPS. SLIPPING AND SLIDING FROM THE SNOW." |
2009-12-31 |
308.5 |
17.94 |
17.2 |
"SECOND TIME USING REGULAR INSTEAD OF MID GRADE" |
2010-01-10 |
285 |
16.67 |
17.1 |
2010-01-20 |
313 |
16.54 |
18.92 |
2010-02-02 |
260 |
16.51 |
15.75 |
2010-02-16 |
286 |
16.75 |
$2.529 |
17.07 |
"FILLED UP WITH REGULAR AND ADDED 2 BOTTLES OF GAS LINE ANTIFREEZE/WATER REMOVER" |
2010-02-27 |
270 |
16.38 |
16.48 |
"USED 2 BOTTLES OF DRY GAS" |
2010-03-11 |
291.8 |
16.76 |
17.41 |
2010-03-19 |
338.6 |
16.67 |
20.31 |
"DROVE ABOUT 230 MILES ON HIGHWAY." |
2010-03-30 |
298.4 |
16.47 |
18.12 |
2010-04-06 |
270 |
13.45 |
20.07 |
"HAD TO FILL UP BEFORE DRIVING TO A COLLEGE." |
2010-04-13 |
316.2 |
14.34 |
$2.71 |
22.05 |
"ONCE AGAING HAD TO FILL UP BEFORE DRIVING TO A COLLEGE." |
2010-04-22 |
346.3 |
16.55 |
20.92 |
"FILLED WIT MID GRADE INSTEAD OF REGULAR" |
2010-05-05 |
319.3 |
16.79 |
19.02 |
"FILLED UP WITH 87" |
2010-05-19 |
322.3 |
17.91 |
18 |
"FILLED UP WITH 89 ND PUT MECHANICAL FAN ON" |
2010-05-29 |
329 |
17.23 |
$2.669 |
19.09 |
"FILLED UP WITH 87 NOTICED SOME PINGING AND ADDED 2 BOTTLES OF OCTANE BOOST." |
2010-06-09 |
359.6 |
17.09 |
21.04 |
2010-06-21 |
15.72 |
18.26 |
"CAR WAS HAVING COOLING ISSUES SO IT SPENT ALOT OF TIME IDLING WHILE I WAS FIXING IT. FILLED UP WIT 87" |
2010-07-05 |
339 |
17 |
19.94 |
2010-07-18 |
16.42 |
20.22 |
2010-07-28 |
319 |
16 |
19.94 |
"FILED UP WITH REGULAR" |
2010-08-29 |
317.2 |
18 |
17.62 |
"FILLED WITH MID GRADE" |
2010-09-09 |
331.7 |
16.5 |
20.1 |
2010-09-22 |
16.42 |
18.57 |
2010-10-05 |
301.4 |
16.61 |
18.15 |
2010-10-15 |
263.7 |
14.49 |
18.2 |
2010-11-08 |
303 |
16.47 |
$2.75 |
18.4 |
"FILLED UP WITH MID GRADE" |
