2003-11-03 |
3748 |
180.2 |
$1.8 |
20.8 |
"All trips from year 2003. No ecomodding." |
2004-11-07 |
3353 |
166.2 |
$1.8 |
20.17 |
"All trips from year 2004. No ecomodding." |
2005-10-19 |
5057 |
233.5 |
$1.8 |
21.66 |
"All trips from year 2005. Engine crankcase ventilation improvements. A lot of blow-by gases (worn piston rings)" |
2006-10-15 |
4229 |
185.6 |
$1.8 |
22.79 |
"All trips from year 2006." |
2007-10-19 |
2484 |
110.4 |
$1.9 |
22.5 |
"All trips from year 2007. Engine rebuilt. AFR sensor installed. Found out that mixtrure was rich all the time. Carburettor adjustments.
Block heater installed. Used only a few times." |
2008-10-05 |
1971 |
86.2 |
$2 |
22.87 |
"All trips from year 2008. Fooling around with Air/Fuel mixtures. Leaning the mixture is not the ultimate solution for good MPG. I just did'nt realize that back then." |
2009-10-01 |
3454 |
126.5 |
$1.8 |
27.3 |
"All trips from year 2009. Rear axle gear ratio changed from 3.7:1 to 3.09:1
Zemco fuel computer installed." |
2010-05-06 |
188.2 |
7.46 |
$1.8 |
25.23 |
"some problem with ignition, testing at idle.
Rear diff oils -> 75w-80 synthetic" |
2010-06-08 |
185 |
7.03 |
$1.8 |
26.32 |
2010-06-18 |
230.4 |
9.35 |
$1.8 |
24.64 |
2010-06-20 |
323.7 |
9.816 |
$1.8 |
32.98 |
"50-60mph highways and country roads (+200km trips)" |
2010-06-29 |
244 |
8.12 |
$1.8 |
30.05 |
"Countryroads" |
2010-07-10 |
226.6 |
8.15 |
$1.8 |
27.8 |
2010-07-19 |
211.1 |
7.94 |
$1.8 |
26.59 |
2010-07-26 |
279.5 |
9.63 |
$1.8 |
29.02 |
2010-08-02 |
228.5 |
7.93 |
$1.8 |
28.81 |
2010-08-05 |
172.6 |
5.67 |
$1.8 |
30.44 |
"Countryroads.
Partial hidden grill block installed." |
2010-10-04 |
250.9 |
9.64 |
$1.8 |
26.03 |
"Engine belly pan fabricated from sheet metal" |
2010-10-12 |
167.7 |
6.56 |
$1.8 |
25.56 |
"Cold weather" |
2011-05-03 |
211.8 |
8.15 |
$2 |
25.99 |
"Cold morning starts" |
2011-05-08 |
213 |
7.3 |
$2 |
29.18 |
2011-05-17 |
211.2 |
7.35 |
$2 |
28.73 |
"Tyre pressure 2.2bar -> 2.8 bar. EOC is much easier." |
2011-06-01 |
222.3 |
7.33 |
$2 |
30.33 |
"EOC some more." |
2011-06-10 |
259.6 |
8.5 |
$2 |
30.54 |
"A few country trips (40km long). EOC:ing some more" |
2011-06-17 |
113 |
4.7 |
$2 |
24.04 |
"Serious problems with ignition. Alot testing at idle and driven short distances." |
2011-06-19 |
502.4 |
15.4 |
$2 |
32.62 |
"A long weekend trip @ 80km/h mostly. Ignition advance was not optimized very well." |
2011-06-27 |
247.8 |
8.3 |
$2 |
29.86 |
"ethanol 10%. Some eoc, some city, some highway, some country roads." |
2011-07-02 |
147.8 |
4.85 |
$2 |
30.47 |
2011-07-09 |
396.8 |
12.72 |
$2 |
31.19 |
"A long holiday trip. Hot weather and car was fully loaded. Max speed 55mph (90km/h)" |
2011-08-02 |
227.3 |
6.67 |
$2 |
34.08 |
"Countryroads @ max 90 km/h (55mph). During this trip found out that ign advance curve was too small. Centrifugal advance corrected from 10 deg to about 20 deg (2500 rpm) Engine has alot more torgue now!" |
2011-08-31 |
208.7 |
6.36 |
$2 |
32.81 |
"Countryroads mainly. Some eoc.
temperature +15*C ...+25*C" |
2011-09-11 |
171.4 |
5.48 |
$2 |
31.28 |
"Countryroads etc. E10 fuel" |
2011-09-12 |
204.3 |
6.39 |
$2 |
31.97 |
"Highway 80-100 km/h. E10 fuel." |
2012-05-29 |
367.85 |
11.89 |
$2.1 |
30.94 |
"""New"" summer tyres. 7% taller. 3bar" |
2012-06-09 |
297.02 |
9.77 |
$2.1 |
30.4 |
"10*C...17*C roof rack and transporting stuff to here and there." |
2012-06-15 |
231.77 |
7.13 |
$2.1 |
32.51 |
"Eoc:ing countryroads" |
2012-06-18 |
298.26 |
8.72 |
$2.1 |
34.2 |
"Weekend trip to countryside. Eoc 70-90km/h
Nice warm weather on my way there.
Rainy and windy when coming back.
My first actual fueling under 7 L/100km! " |
2012-07-02 |
192.63 |
7.15 |
$2.1 |
26.94 |
"Problems.
Engine misfiring when cold and when trying to accelerate.
+15*C...25*C Very often rainy weather." |
2012-07-15 |
279 |
8.44 |
$2.1 |
33.06 |
"Still misfiring. Mostly countryroads and tried to maximize EOC:ing, since the engine cannot misfire when it does not run ;-)
-distributor cap changed.
-spark plugs changed
-Ignition condenser changed (this solved the misfire problem)
-Dragging front brake fixed
-Found a fuel leak from the fuel pipe at the back. Fixed.
Electrical fuel pump and regulator finally in use." |
2012-07-23 |
243.58 |
7.7 |
$1.9 |
31.63 |
"+12*C...+22*C
Engine runs ok.
30 km commutes (small roads)
tyre pressure 3 bar" |
2012-07-31 |
187.65 |
6.75 |
$2.1 |
27.8 |
"On this fueling the tank got really full" |
2012-08-02 |
260.35 |
7.61 |
$2.1 |
34.21 |
"One day trip. Driving countryroads 60-90km/h, some eoc.
And again the tank got really full." |
2012-08-15 |
280.24 |
8.37 |
$2.1 |
33.48 |
"+15*C...+22*C 60-90km/h" |
2012-08-27 |
174.61 |
5.43 |
$2.2 |
32.16 |
"+11*C...+20*C" |
2012-09-08 |
346.1 |
11.36 |
$2.2 |
30.47 |
"Fuel gauge does not work" |
2012-10-03 |
181.44 |
7.01 |
$2.2 |
25.88 |
"Fuel gauge does not work. Weather is colder. Need to run smaller gears in order to charge the battery. Bad
Old generator does not charge in low rpm." |
2012-10-20 |
229.29 |
9.82 |
$2.1 |
23.35 |
"cold weather. +5*C...+10*C. Short distances. Using small gears to ensure batt charging" |
2013-04-28 |
148.51 |
5.62 |
$2 |
26.43 |
"First fueling after winter. During winter sleep the old generator was replaced with a DIY 6 Volt Alternator.
And breaker points replaced with pertronix ignitor." |
2013-05-04 |
155.34 |
5.18 |
$2 |
29.99 |
"Cold mornings. +3*C ...+12*C
Now battery is being charged also during idle. " |
2013-05-08 |
235.5 |
7.38 |
$2 |
31.91 |
"+3*C...+18*C
One longer trip 200km countryroads." |
2013-05-20 |
238.61 |
7.45 |
$2 |
32.03 |
"+8*C...+20*C
Small roads and streets..." |
2013-05-31 |
259.73 |
8.27 |
$2.12 |
31.41 |
"+12*C...+22*C mostly commuting (14km) some city, some countryroads. some eoc." |
2013-06-09 |
298.88 |
9.63 |
$2.12 |
31.04 |
"Some longer trips, some full load trips. Some Eoc.
+16*C... +25*C" |
2013-06-14 |
95.07 |
3.28 |
$2.1 |
28.98 |
2013-06-14 |
195.73 |
6.57 |
$2.1 |
29.79 |
"A long weekend trip. Countryroads. Raining.
Battery died and put extra load on alternator. Also idling alot." |
2013-06-16 |
200.08 |
6.58 |
$2.1 |
30.41 |
"A long weekend trip. Full load. Countryroads. Raining.
2013-06-16 |
303.23 |
8.44 |
$2.1 |
35.93 |
"A long weekend trip. Coming back with a new battery and less load. And not raining so much." |
2013-06-27 |
236.12 |
8.11 |
$2.1 |
29.11 |
"Some city, some countryroads" |
2013-07-05 |
266.57 |
8.66 |
$2.1 |
30.78 |
"+16*C...+24*C
Mostly commuting to work. Easy on the gas." |
2013-07-13 |
268.43 |
8.9 |
$2.1 |
30.16 |
"Commuting countryroads. some shopping trips." |
2013-07-16 |
264.08 |
8.45 |
$2.1 |
31.25 |
"One longer 300km trip with full load. Countryroads.
This time fueling got the tank full
+24*C" |
2013-07-25 |
305.71 |
9.17 |
$2.1 |
33.34 |
"+16*C...+25*C tyre pressure check ->3bar" |
2013-08-03 |
256.63 |
7.9 |
$2.1 |
32.48 |
"+16*C..+25*C" |
2013-08-13 |
274.65 |
8.5 |
$2.2 |
32.31 |
"+20*C...+25*C" |
2013-08-21 |
216.86 |
7.47 |
$2.1 |
29.03 |
"Full tank" |
2013-08-29 |
223.69 |
7.79 |
$2.1 |
28.72 |
"Some city, some country. Full tank again. 14*C..22*C" |
2013-09-12 |
264.7 |
8.18 |
$2 |
32.36 |
"More air through pcv valve. (1,5mm hole)" |
2013-09-25 |
300.74 |
9.85 |
$2 |
30.53 |
"+2*C...+16*C" |
2014-04-06 |
289.56 |
10.49 |
$2.24 |
27.6 |
"Carburettor changed. bigger throats. need more power for caravan towing." |
2014-05-16 |
270.92 |
10.27 |
$2.15 |
26.38 |
"Cold mornings. -2*C...+10*C" |
2014-05-26 |
227.42 |
8.22 |
$2.16 |
27.67 |
2014-06-03 |
277.13 |
10.13 |
$2.13 |
27.36 |
2014-06-05 |
144.78 |
4.56 |
$2.25 |
31.75 |
"Countryroads" |
2014-06-05 |
50.33 |
1.72 |
$2.25 |
29.26 |
"Countryroads.
$8.51 /gal" |
2014-06-06 |
137.32 |
6.61 |
$2.27 |
20.77 |
"Towing caravan. 6 persons and a dog. Heavy load of food, drinks and stuff.
The ultimate heavy loading for this vehicle ever!!! $8.6 /gal" |
2014-06-12 |
225.56 |
8.03 |
$2.17 |
28.09 |
"$8.22 /gal" |
2014-06-20 |
211.27 |
8.08 |
$2.17 |
26.15 |
"$8.21 /gal" |
2014-06-28 |
282.1 |
10.05 |
$2.17 |
28.07 |
"$8.21 /gal" |
2014-07-12 |
282.1 |
10.28 |
$2.12 |
27.44 |
"Bought a new A/F meter. I'm running rich all the time. The towing carb settings are BAD!
I only towed a 221 km. $8.02 /gal" |
2014-08-10 |
266.57 |
8.71 |
$2.13 |
30.61 |
"Re-tuned the carburettor. Leaner mixture now on light loads.
$8.06 / gal" |
2014-08-25 |
247.93 |
7.96 |
$2.16 |
31.15 |
"+14*C...+25*C
$8.18 / gal" |
2014-09-10 |
264.08 |
9.12 |
$2.06 |
28.96 |
"Some city driving.
+10*C...+20*C
$7.79 /gal" |
2014-09-10 |
184.55 |
5.07 |
$2.1 |
36.4 |
"One day trip countryroads 60-90km/h. 17*C
$7.95 / gal" |
2014-09-20 |
178.95 |
5.66 |
$1.99 |
31.62 |
"80-90km/h 12*C
$7.53 / gal" |
2014-09-21 |
183.93 |
5.13 |
$2.06 |
35.85 |
"One day trip countryroads. 14*C
$7.8 / gal" |
2014-10-24 |
209.4 |
7.59 |
$1.93 |
27.59 |
"cold mornings. short distances.
$7.31 /gal" |
