2013-06-04 |
280 |
7.75 |
36.13 |
"Missing front L/R inner fender plastic, tires 34 psi, ignition 9degree" |
2013-06-28 |
8.05 |
$3.81 |
44.6 |
"Both inner fender plastic install, ignition correct to 17degrees, tires psi increase to 44" |
2013-07-07 |
389.1 |
9.59 |
40.57 |
"No change. CEL turn on for o2 sensor" |
2013-07-17 |
505.5 |
9.36 |
$3.69 |
54.01 |
"Federal version installed" |
2013-07-27 |
530.75 |
9.417 |
56.36 |
"Front grill block off. Mud guard removed. Driving @ higher speed on last 1/4 tank." |
2013-08-07 |
522.1 |
9.346 |
55.86 |
"MPGUINO installed at 1/2 gas tank. Learning/testing it's function." |
2013-08-20 |
616.8 |
9.321 |
$3.47 |
66.17 |
"Wheel disc cover added. Re-adjust kamm back wing. WAI installed" |
