2010-01-04 |
318.3 |
19.1 |
16.66 |
2010-01-11 |
369.6 |
20.04 |
18.44 |
2010-01-14 |
103.9 |
6.4 |
16.23 |
"Start...Partial belly pan, side skirts (5"" clearance), 5.5 qts Supertech synthetic 5W-30, Mobil1 M1-102 oil filter, hood not taped, middle grill block added, 300lbs of gear" |
2010-01-15 |
364.4 |
17 |
21.44 |
"Cruise set at 65mph, night drive, Houston to Ardmore" |
2010-01-15 |
245.6 |
10.61 |
23.15 |
"Cruise set at 65mph, day drive, Ardmore to Wichita" |
2010-01-17 |
78.7 |
4.75 |
16.57 |
"Mostly city street driving" |
2010-01-18 |
324.1 |
14.5 |
22.35 |
"Cruise set at 65mph, night drive, Wichita to Gainesville" |
2010-01-19 |
335.7 |
15.9 |
21.11 |
"Cruise set at 65mph, day drive, Gainesville to Houston" |
2010-02-03 |
287.8 |
17.41 |
16.53 |
"Start...Engine bay belly pan completed--2/3 of underside covered, HAI (180° turn of lower part of airbox-intake hose 1"" from right exhaust manifold)" |
2010-02-17 |
296.8 |
18.5 |
16.04 |
"Start-removed HAI and 180° airbox turn around, removed front tire spats, installed cool air mod, replaced ""D"" throttle body gasket with ""O"" type." |
2010-02-21 |
314.9 |
15.1 |
20.85 |
2010-03-01 |
340.3 |
16.5 |
20.62 |
2010-03-12 |
303.5 |
16.85 |
18.01 |
2010-03-13 |
376.3 |
17.03 |
22.1 |
"Night/day drive, cruise set at 65mph (Houston TX to Ardmore, OK)" |
2010-03-14 |
277.9 |
13.33 |
20.85 |
"Day drive, cruise set at 65mph (Ardmore, OK to Wichita, KS)" |
2010-03-18 |
354.5 |
18.5 |
19.16 |
"Night drive, cruise set at 65mph (Wichita, KS to Lincoln, NE)" |
2010-03-18 |
233.4 |
10.5 |
22.23 |
"Day drive, cruise set at 65mph (Lincoln, NE to Kearney, NE to York, NE)" |
2010-03-19 |
240.6 |
24.06 |
"Night drive, ethanol, cruise set at 51mph (York NE to Wichita KS)" |
2010-03-21 |
278.1 |
23.87 |
"Day drive, (Wichita KS to Ardmore OK), stop and go traffic, cruise set at 70mph" |
2010-03-22 |
384.1 |
15.7 |
24.46 |
"Day/night drive, cruise set at 71mph (Ardmore OK to Houston TX)" |
2010-04-07 |
348.5 |
19.75 |
17.65 |
"Start-removed main belly pan and side skirts fer refit." |
2010-04-21 |
18.5 |
18.11 |
2010-04-24 |
334 |
16.15 |
20.68 |
2010-04-26 |
243 |
10.25 |
23.71 |
2010-05-11 |
306 |
19.6 |
15.61 |
2010-05-22 |
17.6 |
17.1 |
2010-05-31 |
364 |
19.2 |
18.96 |
2010-06-19 |
315 |
20 |
15.75 |
2010-07-02 |
154 |
10.35 |
14.88 |
2010-07-02 |
372 |
16.5 |
22.55 |
"Cruise set to 70mph, night drive, Houston to Ardmore" |
2010-07-04 |
21.95 |
"Cruise set to 70mph, morning drive, Ardmore to Wichita" |
2010-07-04 |
210 |
19.09 |
"Cruise set to 70mph, day drive, Wichita to Oklahoma City" |
2010-07-05 |
424 |
20.5 |
20.68 |
"Cruise set to 70mph, afternoon/evening drive, Oklahoma City to Houston" |
2010-07-13 |
153 |
9 |
17 |
2010-07-17 |
68.3 |
4.4 |
15.52 |
2010-07-17 |
449 |
20.2 |
22.23 |
"Cruise set to 70mph, day drive, Houston to Lexington, ambient temps over 106°F, no camper top" |
2010-07-17 |
484 |
19.75 |
24.51 |
"Cruise set to 70mph, afternoon/evening drive, Lexington to Houston, new camper top" |
2010-08-09 |
19.5 |
14.72 |
2010-08-10 |
234 |
21.87 |
"Day drive at 65mph from Houston to San Antonio" |
2010-08-11 |
324 |
15 |
21.6 |
"Night drive at 65mph from San Antonio to Ft Stockton" |
2010-08-11 |
250 |
9.45 |
26.46 |
"Ft Stockton to El Paso" |
2010-08-11 |
331 |
14.5 |
22.83 |
"El Paso to Phoenix" |
2010-08-12 |
259 |
10.75 |
24.09 |
"Phoenix to Brea" |
2010-08-17 |
396 |
19.15 |
20.68 |
"Running around Southern California..." |
2010-08-18 |
257 |
24.02 |
"Brea to Phoenix" |
2010-08-18 |
14.8 |
22.64 |
"Phoenix to El Paso" |
2010-08-19 |
283 |
23.58 |
"El Paso to Ft Stockton" |
2010-08-19 |
233 |
8.25 |
28.24 |
"Outside mirrors folded in, cruise set at 60mph, Ft Stockton to San Antonio" |
2010-08-19 |
24.62 |
"San Antonio to Houston" |
2010-08-25 |
412 |
19.7 |
20.91 |
"Start-removed belly/engine pan and side skirts, reset ECU, tires at 35lbs PSI, replaced alternator, 4 new Yokohama Geolander H/T-S 235/75R-15 108SXL tires" |
2010-08-31 |
326 |
18.4 |
17.72 |
2010-09-11 |
316 |
18.75 |
16.85 |
"Start use of Ultra-Gauge (which replaces my Scangauge II)" |
2010-09-20 |
355 |
20 |
17.75 |
"Start front end alignment" |
2010-09-27 |
255 |
14 |
18.21 |
2010-09-27 |
219 |
11.5 |
19.04 |
"Road trip to Austin, no side skirts or belly pans, front grill 66% blocked, cruise set to 70mph" |
2010-10-05 |
19 |
19.63 |
2010-10-12 |
19 |
17.47 |
"Start new front/rear Denso O2 sensors, ECU reset, tires @40PSI" |
2010-10-20 |
355 |
20 |
17.75 |
2010-10-29 |
343 |
20.25 |
16.94 |
2010-11-05 |
260 |
15.25 |
17.05 |
"Start MAF cleaned, 100% lower grill block" |
2010-11-06 |
19 |
21.32 |
"Start new belly pan, air dam pan, engine pan, 11"" side skirts, 66% upper grill block, day drive to Dallas, cruise set to 65mph, partial drive with double mattress on top and bike rack on back... " |
2010-11-07 |
231 |
9.75 |
23.69 |
"Two accidents that backed up traffic to stop and go, day drive back to Houston, cruise set to 65mph" |
2010-11-17 |
339 |
20 |
16.95 |
"Start new NGK Laser Platinum plugs, cleaned throttle body, rear pan installed" |
2010-11-20 |
133 |
7.85 |
16.94 |
2010-11-21 |
394 |
17 |
23.18 |
"Start rear pan, 4° rear diffuser, rear pan skirts (5"" ground clearance), cruise set to 70mph, day drive Houston to Ardmore" |
2010-11-21 |
253 |
9.52 |
26.58 |
"Day/night drive Ardmore to Wichita, cruise set to 65mph, ethanol free gas" |
2010-11-24 |
323 |
15.7 |
20.57 |
"Day drive from Wichita to Lincoln, cruise set to 60mph, cold front" |
2010-11-27 |
418 |
20.25 |
20.64 |
"Start rear mud flaps removed, 10% ethanol, day drive from Lincoln to Wichita via I-29/I-35, cruise set to 65mph, extra 100 lb cargo" |
2010-11-28 |
252 |
21 |
"Start heavy head winds, night drive from Wichita to Ardmore, cruise set to 65mph" |
2010-11-29 |
20 |
20.7 |
"Start heavy head winds, rear skirts removed by winds, day drive from Ardmore to Houston, cruise set to 65mph, stop/go traffic for 1 hr from Houston" |
2010-12-04 |
238 |
13.25 |
17.96 |
2010-12-04 |
218 |
22.95 |
"Start removal of camper top/tools (rear raised 3"" higher), tailgate down, day trip to Corsicana, cruise set to 65mph, roof ducktail installed, diffuser reset to 4°" |
2010-12-05 |
217 |
8.5 |
25.53 |
"Start tailgate up, evening/night drive to Houston, cruise set to 65mph" |
2010-12-11 |
311 |
16.9 |
18.4 |
"Start half tonneau testing" |
2010-12-17 |
323 |
16.5 |
19.58 |
2010-12-17 |
228 |
23.75 |
"Start aero cap, oil and filter change (Supertech synthetic 5W-30, Mobil1 oil filter), 4oz of AutoRX (maint), night drive at 65mph from Houston to San Antonio, air temp dropped to approx 45°F, scattered showers, 200lbs of tools/gear" |
2010-12-20 |
259 |
23.55 |
"Night drive from San Antonio to Houston, cruise set to 65mph, air temp approx upper 50's" |
2010-12-28 |
123 |
7.25 |
16.97 |
2010-12-29 |
375 |
15 |
25 |
"Start extra passengers and luggage (400lbs), tires at 44psi, night drive from Houston to Ardmore, cruise set to 65mph, heavy rain in Dallas, 2 extra stops, 4.5"" clearance for rear skirt, new aero cap version with hatch and rear window" |
2010-12-29 |
251 |
8.75 |
28.69 |
"Start ethanol free gas, morning drive from Ardmore to Wichita, cruise set to 65mph, temps in the upper 40's, misty rain" |
2010-12-31 |
112 |
7 |
16 |
"City driving only (Wichita), temps in the 40's" |
