2010-01-23 |
174 |
6.46 |
$2.5 |
26.93 |
"Driving Conditions: City - Cold weather/short trips
Service: Installed new tires, installed vacuum gauge" |
2010-01-31 |
198.3 |
7.81 |
$2.5 |
25.39 |
Service: Inflated tires to 35 psi
Comments: These short trips are killing my gas mileage" |
2010-02-07 |
265.1 |
10.05 |
$2.5 |
26.38 |
Service: Ordered Scanguage II from Ecomodder.com, cleaned air intake & throttle body including gaskets, replaced hoses and pcv valve/gromet, oiled rear passenger window track (it was squeaky)
Mileage: 190,400" |
2010-02-19 |
256 |
9.574 |
26.74 |
Service: Installed Scanguage" |
2010-03-15 |
197 |
6.571 |
29.98 |
"Driving Conditions: City - Warm weather/short trips
Service: Installed Monroe Quickstruts on front, replaced inside left CV boot" |
2010-03-22 |
294.6 |
9.511 |
30.97 |
"Driving Conditions: Mostly highway - Warm weather
Service: Put water remover in gas" |
2010-03-31 |
289.1 |
9.366 |
30.87 |
"Driving Conditions: City/highway - Warm weather
Mileage: 191,500
Service: Oil Change (full synthetic), AT Drain/Fill (full synthetic)" |
2010-04-06 |
252.7 |
7.833 |
32.26 |
"Driving Conditions: More highway - Warm weather" |
2010-04-11 |
337.1 |
9.483 |
35.55 |
"Driving Conditions: Mostly highway - Warm weather/windy" |
2010-04-20 |
291.1 |
9.514 |
30.6 |
"Driving Conditions: City - warm weather/windy/wet short trips
Service: Replaced brake pedal pad, replaced spark plugs with Bosch Platinum IR Fusion plugs
Mileage: 192,500" |
2010-04-30 |
245 |
8.178 |
29.96 |
"Driving Conditions: Mostly city" |
2010-05-06 |
298.1 |
8.665 |
34.4 |
"Driving Conditions: Mostly highway" |
2010-05-15 |
285 |
8.693 |
32.78 |
2010-06-05 |
233.6 |
7.405 |
31.55 |
"Service: Installed Monroe Quickstruts on the rear" |
2010-06-13 |
297.8 |
9.004 |
$2.519 |
33.07 |
"Service: Replaced exhaust manifold" |
2010-06-24 |
264.8 |
9.495 |
27.89 |
2010-07-05 |
287.9 |
9.209 |
31.26 |
2010-07-13 |
216.3 |
7.163 |
$2.469 |
30.2 |
2010-07-13 |
342.8 |
9.555 |
35.88 |
"Road trip to Florida. 55 mph with AC" |
2010-07-14 |
211 |
6.383 |
33.06 |
2010-07-14 |
315 |
9.479 |
33.23 |
2010-07-30 |
319.9 |
9.662 |
33.11 |
2010-08-06 |
291.1 |
8.94 |
32.56 |
2010-08-08 |
181.6 |
5.518 |
$2.729 |
32.91 |
2010-08-09 |
305.9 |
8.89 |
34.41 |
"Road trip back to Texas. 65 mph, AC on, with modest drafting, burned 0.5 quart of oil" |
2010-08-09 |
291.5 |
9.18 |
31.75 |
2010-08-09 |
323.2 |
10.12 |
$2.6 |
31.94 |
2010-08-23 |
255 |
10.17 |
25.07 |
2010-09-01 |
270.4 |
8.678 |
31.16 |
"Mileage: 197,500
Service: Oil change, 5w30 Mobil 1 synthetic for High Mileage vehicles, replaced differential fluid with Valvoline Dexron VI synthetic
Notes: Some metal shavings on magnet in differential drain plug" |
2010-09-17 |
269.4 |
10.12 |
26.62 |
"Without Scanguage. Doh!" |
2010-09-29 |
252 |
8.3 |
30.36 |
"With Scanguage
Service: Replaced Alternator and Power Steering belts, removed upper resonator" |
2010-10-07 |
278.7 |
8.557 |
32.57 |
2010-10-20 |
323.2 |
9.526 |
33.93 |
"Service: Replaced front exhaust pipe (it is so much quieter now!)" |
2010-10-31 |
221.2 |
7.247 |
30.52 |
"Mileage: 199,200" |
2010-11-11 |
245 |
7.874 |
31.12 |
2010-11-19 |
247.9 |
7.881 |
31.46 |
2010-11-27 |
317 |
9.484 |
33.42 |
2010-12-03 |
153.6 |
4.751 |
32.33 |
"200,000 miles!" |
2010-12-25 |
303 |
10.42 |
$2.949 |
29.08 |
"Front hub bearings are bad. Needs alignment." |
2011-01-13 |
267.2 |
9.369 |
28.52 |
"Service: Replaced front hub bearings, lower ball joint, and outer tie-rod ends. Got an alignment." |
2011-01-22 |
308.4 |
9.897 |
31.16 |
"Service: Inflated tires to 40 psi" |
2011-01-31 |
260 |
8.84 |
29.41 |
2011-02-08 |
166.3 |
6.218 |
$2.889 |
26.74 |
"Service: Added 1/2 quart oil
Driving Conditions: Very cold, all city driving" |
2011-02-15 |
209.9 |
6.97 |
$2.989 |
30.11 |
"Service: Replaced battery ground cable. Changed oil filter. Added 1/2 quart Mobil synthetic oil (5W30).
Mileage: 202,000" |
2011-02-22 |
251.6 |
7.793 |
32.29 |
2011-03-01 |
217.1 |
7.23 |
30.03 |
2011-03-08 |
254.1 |
7.948 |
31.97 |
2011-03-18 |
268.3 |
8.218 |
32.65 |
2011-03-26 |
246.3 |
7.56 |
$3.479 |
32.58 |
2011-04-03 |
290.6 |
8.657 |
33.57 |
"Service: Added 1/2 qt oil
Weather: Very warm" |
2011-04-14 |
309 |
9.87 |
31.31 |
"P&G all city miles" |
2011-04-21 |
198.7 |
6.524 |
30.46 |
"Service: Set idle to 650 rpm, adjusted IAC to lowest possible setting, added 1/2 quart oil" |
2011-05-03 |
328.9 |
9.892 |
33.25 |
2011-05-17 |
300.8 |
9.373 |
$3.855 |
32.09 |
2011-05-29 |
353.7 |
34.68 |
"Driving Conditions: Freeway in the mountains" |
2011-06-16 |
298.2 |
10.45 |
28.54 |
"Mileage: 205,330
Service: Changed oil and filter w/ Mobil 1 5w30
Got NC Driver's License
Changed title and plates to North Carolina" |
2011-07-02 |
258 |
8.658 |
29.8 |
2011-07-05 |
337.1 |
9.426 |
35.76 |
"Road trip from Asheville, NC to Lake Lanier, GA and back. Mountains, 70-90 F, 50-60 mph" |
2011-07-18 |
258 |
9.114 |
$3.629 |
28.31 |
2011-08-26 |
300.8 |
10.08 |
29.84 |
2011-09-08 |
325.3 |
9.955 |
$3.589 |
32.68 |
2011-09-21 |
309.2 |
9.607 |
32.18 |
"Mileage: 207,000" |
2011-10-02 |
309.9 |
9.997 |
$3.389 |
31 |
2011-10-09 |
268.9 |
8.692 |
$3.369 |
30.94 |
"Service: Replaced converter, muffer and resonator pipe with Walker Exhaust parts." |
2011-10-23 |
289 |
10.244 |
28.21 |
2011-11-03 |
244.1 |
8.994 |
$3.389 |
27.14 |
"Mileage: 208,000
Notes: New ""commute"" is only 7.1 miles" |
2011-11-12 |
285.7 |
9.668 |
$3.449 |
29.55 |
2011-12-13 |
280.1 |
10.557 |
26.53 |
2012-01-01 |
283.2 |
10.038 |
28.21 |
2012-01-13 |
287.4 |
10.621 |
$3.539 |
27.06 |
"Conditions: All city driving, cold weather
Mileage: 210,000
Maint: Replaced Oil Filter, Added 3/4 qt 5w-30 Mobil 1 Synthetic High Mileage, PS Drain/Fill" |
2012-01-30 |
287.3 |
10.419 |
27.57 |
2012-02-29 |
284.2 |
9.868 |
28.8 |
2012-04-08 |
267 |
9.541 |
27.98 |
"Service: Replaced fuel injectors" |
2012-05-27 |
317 |
9.665 |
$3.469 |
32.8 |
2012-06-02 |
283 |
8.844 |
32 |
"Service: Drained and filled Transmission and Differential with Amsoil ATF
Mileage: 211,500" |
2012-06-14 |
336 |
9.719 |
$3.329 |
34.57 |
2012-06-30 |
10.742 |
$3.269 |
35.19 |
"Mileage: 212,500
Service: Added BG MOA and 1/4 qt Oil, Rotated and Balanced Tires, Alignment" |
2012-07-11 |
9.796 |
$3.369 |
34.71 |
2012-07-31 |
331 |
10.724 |
30.87 |
2012-08-18 |
258 |
8.3 |
31.08 |
2012-09-05 |
284 |
8.555 |
$3.869 |
33.2 |
2012-09-26 |
11.967 |
$3.839 |
31.84 |
2012-10-28 |
290 |
10.218 |
28.38 |
"Mileage: 214,300
Service: Changed oil with Mobil 5W-30 synthetic, amsoil oil change flush" |
2012-12-19 |
245 |
10.496 |
$3.369 |
23.34 |
"1.5 mile ""commute""
Engine wouldn't even warm up before I got to work" |
2013-01-17 |
299 |
10.788 |
$3.379 |
27.72 |
2013-01-31 |
306 |
10.549 |
$3.449 |
29.01 |
2013-02-18 |
316 |
10.274 |
$3.869 |
30.76 |
2013-03-04 |
10.865 |
$3.789 |
29.45 |
2013-03-20 |
289 |
9.687 |
29.83 |
"Mileage: 216,000" |
2013-04-05 |
319 |
11.275 |
28.29 |
"Mileage: 216,374
Service: Replaced Oil Filter, Added MOA and 1/2 qt Oil" |
2013-04-15 |
257 |
8.419 |
30.53 |
2013-04-29 |
310 |
9.874 |
$3.489 |
31.4 |
"Service: Replaced windshield wipers, coolant flush, replaced thermostat" |
2013-05-13 |
328 |
9.847 |
$3.489 |
33.31 |
"Mileage: 217,000
Service: added BG Ethanol Treatment
Normal operating temperature is now 188F" |
2013-05-22 |
331 |
9.928 |
33.34 |
2013-05-27 |
233 |
7.331 |
$3.469 |
31.78 |
2013-05-29 |
262 |
7.718 |
$3.469 |
33.95 |
"Great Smoky Mountains National Park trip" |
2013-06-14 |
360 |
10.451 |
$3.379 |
34.45 |
2013-08-08 |
276 |
8.708 |
31.69 |
2013-08-15 |
318 |
9.689 |
$3.469 |
32.82 |
"Mileage: 220,000" |
2013-09-04 |
326 |
10.282 |
31.71 |
2013-09-14 |
10.672 |
$3.489 |
31.86 |
2013-09-27 |
9.579 |
$3.369 |
31.53 |
2013-10-08 |
9.183 |
33.21 |
2013-10-14 |
9.22 |
33.84 |
2013-10-24 |
10.53 |
33.24 |
2013-11-03 |
10.535 |
34.08 |
2013-11-10 |
9.832 |
32.55 |
2013-11-16 |
279 |
8.832 |
31.59 |
2013-11-24 |
10.943 |
30.34 |
2013-12-19 |
293 |
9.452 |
$3.369 |
31 |
2013-12-27 |
337 |
10.751 |
31.35 |
2014-02-19 |
11.08 |
30.23 |
2014-04-04 |
328 |
9.504 |
34.51 |
2014-04-14 |
293 |
9.511 |
30.81 |
2014-04-21 |
276 |
9.48 |
29.11 |
2014-06-04 |
276 |
9.951 |
27.74 |
