2007-03-24 |
273 |
13.9 |
19.64 |
"Keesler Service Station: Very first fill up as the first owner of the Giant Strawberry. Picked her up with 40 miles on it." |
2007-03-28 |
155 |
8.29 |
18.7 |
"Keesler Service Station" |
2007-04-04 |
140 |
9.08 |
15.42 |
2007-04-08 |
112 |
6 |
18.67 |
2007-04-14 |
11.99 |
26.02 |
"Keesler Service Station: Long drive to Hammonds, LA. No AC cruise control at 60MPH." |
2007-04-21 |
83 |
5.21 |
15.93 |
2007-04-27 |
63 |
3.38 |
18.64 |
2007-05-07 |
151 |
8.04 |
18.78 |
2007-05-14 |
133 |
7.18 |
18.52 |
2007-05-21 |
128 |
7.59 |
16.86 |
"Kangaroo
2007-05-27 |
110 |
4.54 |
24.23 |
Pre gassavers.org" |
2007-06-01 |
55 |
3.65 |
15.07 |
"Cheveron:
SG2 Installed
Tires inflated to 40 PSI" |
2007-06-17 |
328.9 |
15.036 |
21.87 |
"Cheveron:
Looks like FE went up from last fill up" |
2007-06-24 |
211.7 |
8.224 |
25.74 |
"Cheveron: Drove to New Orleans and back." |
2007-07-15 |
247.4 |
11.943 |
20.72 |
"Cheveron" |
2007-07-25 |
33.1 |
0.977 |
33.88 |
"Cheveron: I wanted to try highway driving using engine on coasting (Drive to Neutral) from 65-55. Not driven far but the results were descent. Used same pump as last fill to avoid a fill error." |
2007-07-25 |
119.8 |
5.539 |
21.63 |
"Filled at Cheveron. Driven mostly to work and back which is about 4.5 miles one way." |
2007-07-31 |
414.1 |
17.044 |
24.3 |
"Chevron: same pump as the last 6 fills." |
2007-08-04 |
103.9 |
4.495 |
23.11 |
"Cheveron: Tried using the IAT mod at 260F. Scan Gauge 2 reported a 30mpg tank using 3.4 gallons. I think the IAT mod tricks the SG2 and is probably busted on this end." |
2007-08-16 |
257.7 |
11.558 |
22.3 |
"Cheveron: Same station different pump. Mostly driven to work and back. About 50 highway miles give or take. Lots of Engine on Coasting. The techniques seem to be working for my short distance route since the proof is in the numbers. Nothing impressive, but I haven't had a fill under 20 MPG since June 1st." |
2007-09-01 |
380.6 |
16.115 |
23.62 |
"Cheveron: About 100 miles of Highway driving to Mobile AL from Bilxoi. The rest to and from school." |
2007-09-21 |
353.7 |
15.724 |
22.49 |
"Shell: Used a different station and pump than I usually do. This may add a fill error in the future." |
2007-10-18 |
373.3 |
16.986 |
21.98 |
"Cheveron" |
2007-10-25 |
141.2 |
6.262 |
22.55 |
"Pilot: Fill up before trip to Fairfield CA. Van packed at 5300 lbs." |
2007-10-26 |
403.4 |
15.769 |
25.58 |
"From Houston to Ozona, TX. Average speed about 70 mph. Doing engine on coasts from 80mph to 60mph and 75mph to 60mph." |
2007-10-26 |
409.1 |
15.427 |
26.52 |
"Biloxi to Houston. Average speed 67 mph. Filled in the morning before going Ozona. Shell pump said gas contains 10% ethanol." |
2007-10-27 |
398 |
17.67 |
22.52 |
"From Ozona, TX to Las Cruces, NM. I gave up on hypermilling for this leg of the trip. Cruise control between 70 to 80 mph. Lots of hills, which affected my MPG." |
2007-10-29 |
428.7 |
14.756 |
29.05 |
"Las Cruces, NM to Luke AFB, AZ (Phoenix). Cruise control on at around 70 to 75 mph. Had to slow down in Tuscon and Phoenix due to lower speed limits and construction on I-10. The roads are pretty straight and flat except for a few hills. Average speed according to the SG2 was 60mph for the tank. Best tank so far over a long distance." |
2007-10-31 |
356.9 |
14.979 |
23.83 |
"From Luke AFB, AZ to Buena Park, CA. 58 MPH average according to SG2. Some descent sized hills coming into California from I-10." |
2007-11-02 |
422.2 |
17.309 |
24.39 |
"From Buena Park, CA to Travis AFB, CA. 55 MPH average according to SG2." |
2007-11-10 |
362.6 |
16.55 |
21.91 |
"Travis AFB gas station: Getting used to the traffic in the area. Had a trip to San Francisco with a lot of stop and go. 24 MPH average." |
2007-11-29 |
403.1 |
17.682 |
22.8 |
"76: Haven't been coasting in Neutral, although I still coast to stop lights. On the highway I use cruise control. Average speed 25 MPH." |
2007-12-15 |
334.7 |
15.219 |
21.99 |
"Travis AFB gas station." |
2007-12-21 |
151.9 |
6.198 |
24.51 |
"Travis AFB: Mostly Highway driving." |
2007-12-26 |
114.9 |
4.511 |
25.47 |
"Travis AFB: Mostly highway driving with some EOC in the city. 30MPH Average according to SG2." |
2007-12-31 |
123.3 |
4.732 |
26.06 |
"Travis AFB" |
2008-01-24 |
153.1 |
8.901 |
17.2 |
"Travis AFB: Mostly short distance trips." |
2008-02-03 |
388.5 |
16.74 |
23.21 |
"TRAVIS AFB: Drove to Zephyr Cove, NV." |
2008-02-24 |
321.4 |
14.5 |
22.17 |
"Travis AFB: 24 MPH AVG. One trip to San Francisco from Travis AFB, with short distance trips to work." |
