2010-04-01 |
371 |
6.885 |
$2.89 |
53.89 |
"No mods average speed of 55 MPH, using 91 fuel" |
2010-04-17 |
459 |
8.04 |
$2.99 |
57.09 |
"No mods at this time, driving a average speed of 50 MPH, using 91 fuel" |
2010-04-22 |
473 |
7.4 |
$2.87 |
63.92 |
"Fuel 87. Added a grille block and headlight covers, also changed the oil to 5w-20." |
2010-04-27 |
482 |
7.68 |
$2.92 |
62.76 |
"No much change. Did put new spark plugs, cap and rotor in. Weather has not been the greatest lately. Also Added moon disk." |
2010-05-01 |
521 |
7.844 |
$2.93 |
66.42 |
"Driving was all over the place alot of driving in the 40 to 50 range but also did a little driving around 65. Fixed my egr and pumped a little fuel on the ground but over all the tank did much better then I thought it would" |
2010-05-06 |
431 |
6.5 |
$2.88 |
66.31 |
"NO mods done on this tank, lost a little fuel from disconnecting the fuel lines, been driving between 45 and 50 for the most part." |
2010-05-13 |
478 |
7.521 |
$2.87 |
63.56 |
"Lost a head light cover half way through this tank, also hauled about 250 pounds of dirt and rock in the back for a small part of the tank. At the end of this tank I put on a heat fuel exchanger. Not planning on seeing results but next tank or two should tell. Hopefully it will help more with winter fuel MPG. Also lost small amounts of fuel playing with my fuel lines. Used 87 fuel average speed of 45-50." |
2010-05-17 |
543 |
8.089 |
$2.67 |
67.13 |
"Well ran this tank with headlight cover and bezels off nothing else different but my driving was all over the place no great average speed maybe around 55. Did shut the car off at a few stop lights tho." |
2010-05-22 |
554 |
8.144 |
68.03 |
"Was going for 70mpg this tank but didn't make it used dwl driving and engine off coast when coming to long complete stops. Average speed of 50 ran 87 gas. Looks like I need some more mods for 70mpg....coming soon" |
2010-05-29 |
604 |
8.513 |
$2.67 |
70.95 |
"About the same driving as the last tank used 87 fuel again. I'm gonna have you give this tank to the hot weather been in the 80s to 90s this whole tank. No other mods at this time ." |
2010-06-04 |
543 |
7.572 |
$2.67 |
71.71 |
"Driving was all over the place so not sure on a average did some sort runs at about 65 and the rest of the tank was at about 45mph. Also did engine off coast to complete stop and at some lights. Changes the oil at the start of this tank, no more mods have been added at this time. Used 87 fuel.Egr light came back on. Working on the idea of a manual egr control at this point." |
2010-06-09 |
603 |
8.415 |
$2.67 |
71.66 |
"This tank went very well an average speed of 45-47 mph using 87 and in this tank I used no engine off coast the car was running the whole time it was moving. At the start of the tank I removed the egr filter, no other mods have been done at this time." |
2010-06-16 |
631 |
8.674 |
$2.57 |
72.75 |
"Driving this tank was about same as last no engine off coast which from this point on I wong be doing because I seem to get better mpg not doing it. Average speed was 45-50 mph and I ran 87 E0. Next tank I will be running 89 E10 as a request to see how much E10 hurts my MPG. This tank turned out nice tho I would have like to run the tank to about 680 miles. maybe next tank." |
