2010-04-12 |
11.83 |
$3.039 |
32.21 |
2010-04-20 |
365 |
10.72 |
$3.039 |
34.05 |
2010-05-01 |
11.56 |
32.7 |
2010-05-22 |
217 |
8.369 |
25.93 |
2010-06-02 |
344 |
10.26 |
$2.819 |
33.53 |
2010-06-11 |
352 |
11.56 |
30.45 |
2010-06-19 |
11.44 |
27.97 |
2010-06-26 |
246 |
12.27 |
20.05 |
2010-07-07 |
265 |
11.46 |
23.12 |
2010-07-15 |
201 |
8.058 |
24.94 |
2010-07-31 |
11.86 |
$2.819 |
27.82 |
2010-08-02 |
11.08 |
$2.819 |
29.33 |
2010-08-17 |
12.71 |
23.76 |
2010-08-27 |
168 |
5.907 |
$2.74 |
28.44 |
"Orlando, FL" |
2010-08-28 |
275 |
11.33 |
24.27 |
2010-09-06 |
366 |
12.51 |
29.26 |
2010-09-10 |
264 |
9.545 |
27.66 |
2010-09-17 |
270 |
9.46 |
28.54 |
"155,026" |
2010-09-22 |
343 |
11.17 |
30.71 |
"155,370" |
2010-10-08 |
255 |
10.18 |
25.05 |
"155,625" |
2010-10-10 |
11.37 |
$2.969 |
29.9 |
"155,964" |
2010-10-22 |
11.43 |
$3.019 |
29.92 |
"156,307 miles
Replaced: TPS Sensor, MAP sensor, Spark plug wires, rotor, oil change with 0w30 fuel economy mobile 1 synthetic." |
2010-10-26 |
324 |
9.949 |
32.57 |
"156,631
Rotated tires.
Replaced Driver Side axle (Raxle)" |
2010-10-30 |
267 |
8.018 |
$2.979 |
33.3 |
"156,898" |
2010-10-30 |
136 |
4.098 |
$2.919 |
33.19 |
"157,033
Orlando fill-up. Cheaper" |
2010-11-07 |
341 |
10.39 |
$3.039 |
32.82 |
"157,377" |
2010-11-16 |
367 |
11.46 |
32.02 |
"157,744" |
2010-11-26 |
361 |
$2.979 |
31.12 |
"158,105
Orlando" |
2010-12-06 |
10.71 |
$3.099 |
32.21 |
"158,449" |
2010-12-12 |
285 |
9.409 |
30.29 |
"158734
Orlando" |
2010-12-18 |
281 |
9.268 |
$3.189 |
30.32 |
"159015" |
2010-12-22 |
300 |
8.657 |
34.65 |
"159315 - Oil Change performed 10W30 syn" |
2010-12-31 |
389 |
12.48 |
31.17 |
"159704 - Plant City 7-Eleven" |
2011-01-10 |
382 |
12.15 |
31.44 |
"160,086 Mobil - Celebration, FL" |
2011-01-24 |
387 |
12.64 |
$3.379 |
30.62 |
"160,473" |
2011-02-04 |
11.19 |
$3.379 |
30.83 |
"160,818" |
2011-02-18 |
369 |
12.81 |
$3.349 |
28.81 |
"161107" |
2011-03-06 |
11.02 |
$3.719 |
29.04 |
"161507" |
2011-03-17 |
362 |
11.69 |
30.97 |
"161,868" |
2011-03-31 |
277 |
9.653 |
28.7 |
"162,145" |
2011-04-04 |
151 |
4.78 |
31.59 |
"162,296" |
2011-04-05 |
245 |
7.337 |
33.39 |
"162,540 Highway back and forth to Orlando" |
2011-04-12 |
331 |
10.41 |
31.8 |
"162,871 - Tires inflated to max psi for tires (51psi).
New Air Filter and Fuel Filter installed at 162,871." |
2011-04-20 |
338 |
10.78 |
31.35 |
"163,209" |
2011-04-28 |
233 |
7.857 |
29.66 |
"163,442" |
2011-04-28 |
55 |
2.49 |
22.09 |
"163,497
Work trip with city driving thru traffic and idling." |
2011-05-27 |
372 |
11.89 |
$3.969 |
31.29 |
"163,869" |
2011-06-05 |
346 |
11.29 |
30.65 |
"164,215" |
2011-06-17 |
12.06 |
27.53 |
"164,547" |
2011-06-27 |
352 |
11.94 |
$3.719 |
29.48 |
"164,898" |
2011-07-05 |
368 |
11.63 |
31.64 |
"165,266" |
2011-07-17 |
377 |
11.45 |
$3.849 |
32.93 |
"165,643 Moved to Indianapolis" |
2011-07-22 |
12.14 |
30.72 |
"166,016" |
2011-07-30 |
11.26 |
$3.809 |
31.08 |
"166,367 switched to 89 octane" |
2011-08-06 |
10.99 |
31.39 |
"166,712 shell 89" |
2011-08-09 |
331 |
9.755 |
33.93 |
"167,043 shell 89" |
2011-08-15 |
10.72 |
32.65 |
"167,392. 89 octane shell" |
2011-08-20 |
12.46 |
$3.719 |
30.98 |
"167,778. Shell 89 octane" |
2011-08-26 |
336 |
10.531 |
$3.919 |
31.91 |
"168,114. Shell 89" |
2011-08-31 |
363 |
11.405 |
31.83 |
"168,478 - Shell 87" |
2011-09-08 |
334 |
10.721 |
$3.749 |
31.15 |
"168,811 - Shell 89" |
2011-09-13 |
9.755 |
33.32 |
"169,136 - Shell 87" |
2011-09-22 |
391 |
11.668 |
33.51 |
"169,527 - 89 octane" |
2011-09-30 |
418 |
12.82 |
$3.289 |
32.61 |
"169,946 - Shell 89 octane.
New iginition coil installed in distributor, distributor cap." |
2011-10-07 |
425 |
12.616 |
33.69 |
"170,371 - Shell 89" |
2011-10-14 |
10.753 |
31.81 |
"170,713 - Shell 89" |
2011-10-16 |
9.674 |
33.6 |
"171,037 - Shell 89" |
2011-10-18 |
434 |
12.764 |
34 |
"171,461 - Shell 89" |
2011-10-25 |
11.45 |
$3.409 |
29.87 |
"171,803 - Last tank... Cylinder 3 failure. Rebuild over winter." |
2012-09-24 |
203 |
10.789 |
18.82 |
"Shell 93 - 172254 First tank after engine rebuild. Dino oil/break in with mild and hard driving to seat rings.
Does not represent a true tank due to rebuild." |
2012-09-28 |
328 |
10.74 |
$3.849 |
30.54 |
"172582 - Shell 93" |
2012-10-04 |
338 |
11.596 |
29.15 |
"172921 - Shell 93" |
2012-10-10 |
288.6 |
9.807 |
29.43 |
"173209 - Shell 93. Oil change 172995 Mobil 1 5w40." |
2012-10-23 |
343 |
11.741 |
$3.539 |
29.21 |
"173552 - Shell 93" |
2012-10-29 |
308 |
11.071 |
$3.719 |
27.82 |
"173860 - Shell 93" |
2012-11-02 |
232.4 |
8.728 |
$3.439 |
26.63 |
"174094 - Shell 93 AEM CAI reinstalled along with front splash guard." |
2012-11-14 |
217.4 |
7.318 |
29.71 |
"174310 - Shell 93" |
2012-11-19 |
10.171 |
29.59 |
"174,611 - Shell 93" |
2012-11-29 |
343 |
12.268 |
$3.729 |
27.96 |
"174954 - Shell 93" |
2012-12-03 |
12.79 |
$3.629 |
28.07 |
"175312 - Shell 93" |
2012-12-11 |
322 |
10.935 |
$3.489 |
29.45 |
"175634 - Shell 93" |
2012-12-19 |
234 |
8.25 |
28.36 |
"175868 - Shell 93" |
2013-01-07 |
329.5 |
12.432 |
26.5 |
"176198 - Shell 93 Had some fun over break around town." |
2013-01-10 |
364 |
12.716 |
28.63 |
"176562 - Shell 93" |
2013-01-17 |
248 |
9.142 |
$3.349 |
27.13 |
"176811 - Shell 93 Need to look into new fuel filter, fuel system cleaner, plugs and wires. air pressures and alignment may help too along with shedding some weight." |
2013-01-28 |
10.242 |
28.02 |
"177099 - Shell 93" |
2013-01-31 |
270.4 |
10.503 |
$3.869 |
25.75 |
"177368 - Shell 93 Flushed and changed transmission oil with OEM Honda MTF. Transmission shift rod seal, boot replaced and poly shift bushings." |
2013-02-11 |
336 |
12.02 |
$3.889 |
27.95 |
"177705 - Shell 93" |
2013-02-20 |
333 |
12.483 |
$4.029 |
26.68 |
"178038 - Shell 93" |
2013-02-25 |
299.8 |
11.079 |
27.06 |
"178338 - Shell 93" |
2013-02-28 |
247 |
9.272 |
$3.989 |
26.64 |
"178585 - Shell 93" |
2013-03-04 |
244 |
8.736 |
$3.849 |
27.93 |
"178829 - Shell 93" |
2013-03-13 |
310 |
$4.1 |
28.18 |
"179139 - Shell 93" |
