2008-02-14 |
645.1 |
10.44 |
61.79 |
"fcd - 64.3" |
2008-03-05 |
647.5 |
9.87 |
$2.939 |
65.6 |
"fcd - 68.8" |
2008-03-16 |
733 |
10.24 |
$3.139 |
71.58 |
"fcd - 72.8" |
2008-04-02 |
685.8 |
9.19 |
$3.139 |
74.62 |
"fcd - 74.2" |
2008-04-19 |
656 |
9.63 |
$3.239 |
68.12 |
"fcd - 72.1" |
2008-05-09 |
647.5 |
8.97 |
72.19 |
"fcd - 72.6" |
2008-06-01 |
751.8 |
9.81 |
76.64 |
"fcd - 78.0" |
2008-06-20 |
635.1 |
8.4 |
75.61 |
"fcd - 78.4" |
2008-07-16 |
808.1 |
9.68 |
83.48 |
"fcd - 85.3" |
2008-08-05 |
760.8 |
9.83 |
77.4 |
"fcd - 80.3" |
2008-08-18 |
698.8 |
10.41 |
67.13 |
"fcd - 70.0" |
2008-08-28 |
625.8 |
62.14 |
"fcd - 64.1" |
2008-09-21 |
799.1 |
10.24 |
$3.379 |
78.04 |
"fcd - 80.3" |
2008-10-22 |
744.5 |
10.27 |
72.49 |
"fcd - 77.0" |
2008-11-14 |
774.5 |
9.72 |
$2.239 |
79.68 |
"fcd - 80.6" |
2008-12-13 |
756.9 |
9.86 |
$1.479 |
76.76 |
"fcd - 78.9" |
2008-12-28 |
417.5 |
5.97 |
$1.479 |
69.93 |
"fcd - 73.0" |
2009-01-21 |
754 |
10.51 |
$1.739 |
71.74 |
"fcd - 74.9" |
2009-02-14 |
721.6 |
9.74 |
74.09 |
"fcd - 75.9" |
2009-03-11 |
744.5 |
9.91 |
$1.869 |
75.13 |
"fcd - 77.5" |
2009-03-31 |
742.3 |
$1.759 |
79.82 |
"fcd - 79.1" |
2009-04-13 |
642.8 |
7.31 |
$1.779 |
87.93 |
"fcd - 79.1" |
2009-05-01 |
745.9 |
10.13 |
$1.699 |
73.63 |
"fcd - 85.0" |
2009-05-19 |
724.4 |
8.53 |
84.92 |
"fcd - 85.0" |
2009-06-10 |
819 |
9.61 |
85.22 |
"fcd - 88.3" |
2009-07-08 |
833.7 |
9.99 |
83.45 |
"fcd - 89.0" |
2009-07-28 |
861.4 |
9.77 |
88.17 |
"fcd - 90.0" |
2009-07-30 |
587 |
9.94 |
59.05 |
"fcd - 58.5
75-80 on highway with A/C on, out of lean burn" |
2009-08-20 |
832.1 |
10.09 |
82.47 |
"fcd - 86.2" |
2009-09-17 |
788.1 |
9.43 |
83.57 |
"fcd - 84.6" |
2009-09-22 |
687 |
68.22 |
"fcd - 71.2
partially 75-80 on highway with A/C on, out of lean burn" |
2009-09-30 |
595.6 |
10.29 |
57.88 |
"fcd - 58.5
2009-10-23 |
808.4 |
9.99 |
$2.339 |
80.92 |
"fcd - 85.0" |
2009-11-19 |
812.6 |
9.94 |
81.75 |
"fcd - 83.6" |
2009-12-13 |
760 |
9.77 |
77.79 |
"fcd - 77.7" |
2010-01-12 |
724.2 |
10.14 |
71.42 |
"fcd - 76.3" |
2010-02-02 |
723.9 |
9.67 |
74.86 |
"fcd - 76.3" |
2010-02-25 |
741.1 |
10.13 |
73.16 |
"fcd - 75.9" |
2010-03-23 |
724.5 |
9.84 |
73.63 |
"fcd - 75.4" |
2010-03-28 |
621.7 |
9.29 |
66.92 |
"fcd - 67.2
75-80 on highway, out of lean burn" |
2010-04-19 |
722.5 |
10.23 |
70.63 |
"fcd - 75.2" |
2010-05-11 |
724.4 |
9.05 |
80.04 |
"fcd - 80.1" |
2010-06-18 |
827.9 |
10.25 |
80.77 |
"fcd - 84.1" |
2010-07-07 |
840.7 |
10.24 |
82.1 |
"fcd - 85.5" |
2010-08-07 |
937 |
9.963 |
94.05 |
"fcd - 96.1
first tank with FAS button used consistently." |
2010-09-09 |
984.6 |
10.67 |
92.28 |
"fcd - 96.1" |
2010-10-09 |
927.6 |
9.93 |
93.41 |
"fcd - 95.1
FAS switch modified to cut fuel injectors." |
2010-11-29 |
790.8 |
10.28 |
76.93 |
"fcd - 79.6
this tank started with my first IMA light and a 1447 code. right before fillup, I received another IMA light and a 1449 code. looks like I will be replacing the 144v battery sooner, rather than later... " |
2010-12-24 |
745.3 |
9.74 |
76.52 |
"fcd - 75.6
one IMA light: reset." |
2011-01-26 |
750 |
10.04 |
$2.95 |
74.7 |
"fcd - 75.6
one IMA light reset..." |
2011-02-19 |
766.3 |
10.39 |
$3.169 |
73.75 |
"fcd - 76.1" |
2011-03-17 |
806.6 |
10.38 |
77.71 |
"fcd - 78.9" |
2011-04-14 |
739.6 |
8.96 |
82.54 |
"fcd - 80.3" |
2011-05-12 |
792.5 |
$3.609 |
78.7 |
"fcd - 81.3" |
2011-06-10 |
775.9 |
77.59 |
"fcd - 77.0" |
2011-08-03 |
784 |
10.24 |
$3.279 |
76.56 |
"fcd - 77.5" |
2011-08-24 |
738.2 |
10.512 |
70.22 |
"fcd - 73.7" |
2011-09-13 |
739.8 |
10.184 |
72.64 |
"fcd - 72.3" |
2011-10-07 |
719.7 |
10.207 |
$3.279 |
70.51 |
"fcd - 71.6" |
2011-11-08 |
734.4 |
10.577 |
69.43 |
"fcd - 71.6" |
2011-12-08 |
677.6 |
10.321 |
65.65 |
"fcd - 68.6" |
2012-01-11 |
674.7 |
10.355 |
65.16 |
"fcd - 64.6" |
2012-02-07 |
682.5 |
9.945 |
$3.449 |
68.63 |
"fcd - 70.2" |
2012-03-01 |
659.2 |
10.112 |
65.19 |
"fcd - 68.6" |
2012-03-20 |
576.4 |
9.775 |
58.97 |
"fcd - 59.9" |
2012-04-12 |
619.2 |
10.831 |
$3.839 |
57.17 |
"fcd - 60.1" |
2012-05-09 |
749.1 |
10.407 |
71.98 |
"fcd - 73.3" |
2012-06-06 |
751.7 |
10.073 |
74.63 |
"fcd - 75.2" |
2012-08-10 |
779.9 |
10.11 |
77.14 |
"fcd - 79.4" |
2012-09-04 |
750.1 |
10.346 |
72.5 |
"fcd - 73.7" |
2012-09-28 |
765.4 |
10.752 |
71.19 |
"fcd - 74.9" |
2012-10-26 |
665.2 |
9.463 |
70.29 |
"fcd - 70.2" |
2012-11-21 |
709.6 |
10.732 |
$3.379 |
66.12 |
"fcd - 69.0" |
2012-12-15 |
665 |
10.346 |
64.28 |
"fcd - 64.3" |
2013-01-25 |
614.5 |
10.224 |
60.1 |
"fcd - 62.0" |
2013-02-15 |
597.3 |
10.484 |
56.97 |
"fcd - 58.5" |
2013-03-06 |
646.2 |
9.726 |
$3.709 |
66.44 |
"fcd - 64.6
replaced 168v battery with 8ah from Hybrid ReVolt. looking forward to the next tanks numbers..." |
2013-04-01 |
701.9 |
10.305 |
68.11 |
"fcd - 70.9
not as much improvement as I hoped for, but am having problems with emissions. Throwing P1162 and P0420. Will hopefully work things out before the next tank." |
2013-04-20 |
262.9 |
3.865 |
$3.329 |
68.02 |
"fcd - 71.2" |
2013-04-25 |
637.3 |
9.068 |
70.28 |
"fcd - 71.4" |
2013-05-24 |
748.3 |
9.15 |
$3.379 |
81.78 |
"fcd - 85.0" |
2013-07-11 |
726.4 |
10.536 |
68.94 |
"fcd - 70.2" |
2013-08-10 |
672.8 |
10.408 |
64.64 |
"fcd - 65.3" |
2013-08-30 |
669.3 |
10.175 |
$3.239 |
65.78 |
"fcd - 67.4" |
2013-09-10 |
685.5 |
8.82 |
$3.279 |
77.72 |
"fcd - 77.0" |
2013-09-18 |
715 |
9.812 |
$3.279 |
72.87 |
"fcd - 73.5" |
2013-09-27 |
808.1 |
10.149 |
79.62 |
"fcd - 80.3" |
2013-10-12 |
687.8 |
9.751 |
$3.079 |
70.54 |
"fcd - 72.6" |
2013-11-07 |
684 |
9.82 |
$3.019 |
69.65 |
"fcd - 70.5" |
2013-11-27 |
683.4 |
9.928 |
68.84 |
"fcd - 70.7" |
2013-12-17 |
586 |
9.072 |
$3.019 |
64.59 |
"fcd - 66.7" |
2014-01-14 |
598.9 |
9.128 |
65.61 |
"fcd - 66.7" |
2014-02-05 |
681.3 |
9.721 |
70.09 |
"fcd - 71.9" |
2014-02-28 |
701.9 |
10.243 |
68.52 |
"fcd - 71.6" |
2014-03-23 |
559.5 |
8.198 |
$3.279 |
68.25 |
"fcd - 70.5" |
2014-04-15 |
687 |
9.722 |
70.66 |
"fcd - 71.2" |
2014-05-16 |
719.2 |
10.546 |
68.2 |
"fcd - 71.6" |
