2010-06-18 |
298 |
9.19 |
$2.84 |
32.43 |
"All highway driving @ 65 MPH. Car loaded with weight and no hypermiling.
No A/C used.
Cruise control used." |
2010-06-29 |
394 |
11.26 |
$2.74 |
34.99 |
"Using Scangauge2 for hypermiling. Everyday driving with a lot of short trips. (normal commute)
No A/C used.
No cruise used." |
2010-06-30 |
173.7 |
4.617 |
37.62 |
"Some highway cruising @ 55 MPH.
(3 test loops)
No A/C used.
No WAI.
Coolant temp: 191*F
Intake air temp: 100*F
Ambient air temp: 70*F" |
2010-07-01 |
70 |
1.916 |
36.53 |
"Warm Air Intake (WAI) active now.
Air temps between 140*F and 160*F when warmed up.
Normal commuting - stop-n-go.
No A/C used.
No cruise used.
WAI just installed." |
2010-07-02 |
474 |
12.54 |
$2.569 |
37.8 |
"Wife hypermiling on highway between 55 MPH and 63 MPH.
WAI active. Car loaded with 2 people and 300 lbs of extra weight for trip.
No A/C used
No cruise control used.
WAI used." |
2010-07-06 |
565 |
16.05 |
35.2 |
"Wife hypermiling in mountains of NC & GA, with some highway.
No A/C.
No cruise.
No WAI." |
2010-08-02 |
57.9 |
1.533 |
$2.85 |
37.77 |
"Some highway cruising at 55 MPH.
No A/C used.
WAI used." |
2010-08-12 |
223 |
6.198 |
$2.84 |
35.98 |
"Daily driving - commute stop-n-go. Short trips. Hypermiling.
No A/C used.
WAI used.
CTS tricker used." |
2010-08-23 |
269 |
7.467 |
36.03 |
"Daily driving - commute stop-n-go. Short trips. Hypermiling, but no Engine-Off coasting.
No A/C used.
WAI used.
2010-08-26 |
209.4 |
5.332 |
39.27 |
"Wife hypermiling on the highway at 55 MPH. Two people plus 300 lbs of extra weight for trip to D.C..
No A/C used.
WAI used.
CTS tricker used.
Increased throttle resolution mod used.
Tire pressure up to 45 PSI.
New 0W-30 Mobile1 full synthetic oil used. Level even with add-mark.
(changed oil 48 hours before starting trip)" |
2010-08-26 |
209 |
5.039 |
41.48 |
"Me hypermiling on the highway at 55 MPH. Two people plus 300 lbs of extra weight for trip to D.C..
No A/C used.
WAI used.
CTS tricker used.
New 0W-30 Mobile1 full synthetic oil used. Level even with add-mark." |
2010-08-31 |
460.1 |
12.55 |
36.66 |
"Some mixed driving, and some highway at 55 MPH. Two people plus 300 lbs of extra weight for trip to D.C..
No A/C used.
Some cruise control used.
WAI used.
CTS tricker used.
2010-08-31 |
268.3 |
6.524 |
41.13 |
No A/C used.
WAI used.
CTS tricker used.
2010-08-31 |
122.4 |
2.787 |
43.92 |
No A/C used.
WAI used.
CTS tricker used.
2010-09-01 |
271.6 |
6.884 |
39.45 |
"50/50% mix of cruise-control and hypermiling on the highway at 55 MPH. Two people plus 300 lbs of extra weight for trip to D.C..
No A/C used.
WAI used.
CTS tricker used.
2010-09-01 |
197.7 |
5.218 |
37.89 |
"No hypermiling. Cruise set to 62 MPH on the highway. Two people plus 300 lbs of extra weight for trip to D.C..
Some A/C used.
WAI used.
CTS tricker used.
2011-07-03 |
8.996 |
$3.33 |
38.02 |
"Wife hypermiling on highway at 60 MPH. Two people plus extra 300 lbs for trip to Georgia.
No A/C
No WAI
No cruise
No tricker used
Increased TB resolution used
Underdrive pulleys used
Tires at 45 PSI
Oil - 5w-30 non-synthetic
*note: The driver-side rear tire has been making noise due to a jagged wear pattern caused by a failed shock absorber. I recently replaced the rear shocks, but this tire still makes noise and adds extra rolling resistance accounting for a slight decrease in mpg. The switch back to regular motor oil also showed a slight decrease in mpg in comparison to the 0w-30 mobil-1 synthetic.
The underdrive pulleys have increased the operating temperature of the coolant back up to the normal factory level of 210* - 230*F." |
2011-07-03 |
177.5 |
4.5 |
39.44 |
No A/C
No WAI
No cruise
No tricker used
Tires at 45 PSI
Oil - 5w-30 non-synthetic" |
2011-07-10 |
317.9 |
8.237 |
38.59 |
"Wife cruising on highway at 65 MPH. Two people plus extra 300 lbs for trip to Georgia.
A/C used
No WAI
cruise used
No tricker used
Tires at 45 PSI
Some EOC (engine on)" |
