2010-11-21 | "220 miles of PNG in town 165 miles of PNG on the highway between 60 and 70mph strapping tape grille blocks in place" |
2010-11-21 | "Cruise set at 65 the whole way. Grille blocks removed pending A-B-A testing. Very windy tonight. Today, also got distance and fuel calibrations for the UltraGauge." | ||||
2010-11-23 | "No idea what happened here. It was 20 miles of PNG in the city and then 220 miles of ABA on the freeway with the cruise set at 65. One thing I did notice is that the temperature really dove. I noticed my IAT reading 64 degrees when I started, 28 degrees on the last run, and then shot up to 54 when I parked at the gas station. Getting the hot side of the airbox hooked back up should solve this." | ||||
2010-11-25 | "38F, windy on the trip in, two additional people in the car, cruise set at 65." | ||||
2010-12-03 | "One trip into Chicago and back. One other person in the car. The rest was P&G around town. Grille block is in place." | ||||
2010-12-04 | "Trip into Chicago and back. 65 on the way in, as slow as 50 on the way back. Snowed on the way back. Snow tires are on. Two more people in the car." | ||||
2010-12-11 | "This was intended to be a worst-case scenario tank; old driving habits, no hypermiling, snow, 10 degree temperatures, snow tires. Despite all that, it didn't turn out that bad." | ||||
2010-12-11 | "Massive snowstorm. Average 40 mph to Woodstock and back. Some DWL and P&G when I could." | ||||
2010-12-22 | "Mileage is approximate; battery was unhooked for repairs. One 40mph trip to Crystal Lake. Snow and ice-packed roads; cold. Lots of 50% throttle P&G around town. Not sure if the high-load acceleration is the ticket or not. This tank is almost as bad as my ""worst case scenario"" tank." | ||||
2010-12-28 | "Trip to Chicago with five people in the car using DWL; half a trip by myself using DWL. The rest city using P&G. Having calibration issues with the UG. Cap, rotor and plugs a few miles into this tank. Partial front and partial rear belly pans a few miles in as well." | ||||
2010-12-28 | "From Des Plaines oasis to Rockford. Cruise set at 65." | ||||
2010-12-31 | "All city. Mobil #1." | ||||
2011-01-01 | "Downtown Chicago and back with one person. Some cruise control, some DWL. Quite windy. Also getting a P1128 error code. Mobil #1." | ||||
2011-01-05 | "130 miles in the city. Cold, short trips, work, rush hour. 80 miles of ABA testing with the cruise at 60. Mobil #1. 0.1 gal/sec fill rate. Calibrated distance with GPS. Might start using the UG's odometer instead of the car's." |
2011-01-15 | "One trip to Chicago, the rest in town. Started experimenting with EOC. P&G continues whenever possible. Changed oil to Mobil1 0w20. Mobil #1, first latch, first click, can of Seafoam." | ||||
2011-01-18 | "Snowstorm. Trip to Chicago. Speeds all over the place. I clicked the pump about 13 times to see if I could get fuel up into the neck. Guess not. The next tank will be a bit high." | ||||
2011-01-23 | "This tank reads a little higher than it should. Started off with quite a few clicks off, but the refill was off at one. Still had 1128 code trouble for most of the tank. PCV breather was disconnected from the intake, but upon reconnecting, idle gph is up 0.35 from 0.25. Typical trip MPG readings are down by about 10. We'll see about the next tank." | ||||
2011-01-24 | "Super-short tank. Found that the PCV valve had popped out of the intake. Haven't gotten the 1128 code yet. UG's fuel calibration is off. Said this tank was only 26." | ||||
2011-01-24 | "Another short tank to reset the fuel calibration. All highway and country roads. It was windy." | ||||
2011-01-27 | "Two trips to Chicago, partial to Madison, all solo, cruise set between 55 and 60. Some city. Have not gotten an 1128 code yet." | ||||
2011-02-02 | "Trip to Milwaukee, P/G 55-60. Some city." | ||||
2011-02-11 | "Trip to Lakewood, P&G 50-60mph. The rest was cold and snowy city traffic." | ||||
2011-02-13 | "Down to Bloomington, IN with two others. Cruise set at 65." | ||||
2011-02-13 | "Back from Bloomington, IN. Told UG it was a partial fill of 9.816 gallons instead of full fill." | ||||
2011-02-15 | "Solo trip to Chicago P&G 55-65." | ||||
2011-02-18 | "All P&G on the highway. Solo trip to Milwaukee (55-65, 50-60 back) and two to Chicago." | ||||
2011-02-21 | "Solo trip to Champaign. 65mph cruise and headwinds down, 55-65 P&G and cold, rain and crosswinds back. Some city driving. Still using UG's odometer. Suspecting bad front wheel bearings. #508" | ||||
2011-02-27 | "100 miles city. Trip to Champaign using some 55-65 P&G, some DWL around 60. Return trip started with 55-65, but hit a downpour and crosswinds. Cruise set at various points. New front wheel bearings, all grille blocks in place. #484" | ||||
2011-03-01 | "Solo to Chicago P&G 55-65 or 55-60. 30 miles in town. #464" | ||||
2011-03-03 | "55-65 to Roseville; cross and tailwind. 65 to Champaign; headwind. 50-65 or 55 back home; crosswind. #408" | ||||
2011-03-06 | "West to Des Moines with three others. Cruise set at 65." | ||||
2011-03-07 | "East home from Des Moines with two others. Some snow. Cruise set at 60 or 65. #385" | ||||
2011-03-18 | "Two trips to Chicago and one to Rochelle, all at 50-65, the rest city with some EOC. #329" | ||||
2011-03-23 | "Trip to Willowbrook at 65 with two others. Trip to Fizz at 65 in and 50 out. Schaumburg at 65 in, 55 out. The rest city with some EOC. #294" | ||||
2011-03-28 | "Various. PG 50-65, cruise at 65. Started driving 5-10 under the limit in town. Starting to have transmission issues. #262" | ||||
2011-04-11 | "Threw away a partial tank between this one and the previous one due to transmission issues and the mechanic driving it. Battery was disconnected for the repair. This tank: ECU appears to have readapted by 108 miles in. Rockton at 50-65, Woodstock at 45-65/40-60, Chicago 50-65, Willowbrook 50-65/45-60 with rain and strong headwinds. In town at 5 under with P&G and more EOC. A few 50mpg city trips. #219" |
2011-04-15 | "Chicago 60/45-60. El Paso 50-65. More EOC in town. #196" | ||||
2011-04-17 | "To St. Louis at 55, then to El Paso at 65. Strong W winds. #194" | ||||
2011-04-22 | "#184" | ||||
2011-04-25 | "#174" | ||||
2011-05-01 | "To Round Lake Beach at 65, hypermiled home. To Chicago at 65 with extreme crosswind, back at 65 with two others. Lots of city driving on this tank. Mileage is approximate. #177" | ||||
2011-05-12 | "Chicago at 65 w/ one person. Lots of EOC around town. To Milwaukee at 65. #151" | ||||
2011-05-23 | "Return from Milwaukee at 85. Chicago w/one person, cruise between 55 and 65. EOC around town. #125" | ||||
2011-06-01 | "To Rochelle at 55, back at 55. To Milwaukee at 65, back at 55. EOC around town. #118" | ||||
2011-06-17 | "Trips to Chicago 65/55, Rockton and two to Woodstock P&G. EOC around town. #99" | ||||
2011-07-01 | "One trip to Madison with two people at 65. Almost entirely EOC in town. #99" | ||||
2011-07-13 | "Trip to Rockton 55-65, two to Woodstock 50-60 and Chicago with one person at 65. EOC in town. #110" | ||||
2011-07-22 | "Two trips to Seward at 55. EOC in town. #104" | ||||
2011-08-01 | "Trip to Burlington 60/55, the rest in town. #89" | ||||
2011-08-10 | "Trip to Chicago with one person and A/C. EOC in town. Car was pulled off the road and restored. Tank drained; disregard this one." | ||||
2012-09-29 | "First tank after restoration. Breaking in rebuilt engine. Not much hypermiling. Need to recalibrate distance and fuel." | ||||
2012-10-14 | "Trip to Rochelle and a single 43mpg trip in town. All city driving, driven normally. Tire and fuel recalibrated." | ||||
2012-10-28 | "All non-eco driving in town. #273" | ||||
2012-11-12 | "" | ||||
2012-11-22 | "Started P&G and some EOC." | ||||
2012-12-08 | "" | ||||
2012-12-20 | "" | ||||
2013-01-05 | "Much colder, snow and snow tires." | ||||
2013-01-16 | "" | ||||
2013-02-08 | "" | ||||
2013-03-01 | "" | ||||
2013-03-17 | "" | ||||
2013-03-30 | "" | ||||
2013-04-19 | "" | ||||
2013-05-06 | "" | ||||
2013-05-20 | "" | ||||
2013-06-07 | "" | ||||
2013-07-20 | "" | ||||
2013-08-05 | "" | ||||
2013-08-24 | "" | ||||
2013-09-11 | "" | ||||
2013-09-22 | "" | ||||
2013-10-16 | "" | ||||
2013-10-26 | "" | ||||
2013-12-16 | "" |
