2010-12-04 |
13.5 |
$2.91 |
30 |
"With a gas leak, loose lugnuts and city stop and go some." |
2010-12-17 |
373.5 |
14.18 |
$2.86 |
26.34 |
"Temperatures in the single digits with a low of 3 degrees. Not to mention car was overheating due to water frozen in line making it go into limp mode. Also discovered low trans fluid and realized it hasn't been shifting to 4th. Hopefully adding fluid fixed this." |
2010-12-28 |
359.3 |
13.7 |
$3.08 |
26.23 |
"Trans still not engaging 4th over half the time. Think I may have fixed after noticing incorrect vacuum on trans modulator." |
2010-12-31 |
273.4 |
$3.14 |
28.48 |
"Fixed Vacuum modulator. Filled early to program new MPGuino. Was running late to work a few days so should be better next time ." |
2011-01-07 |
363.1 |
11.64 |
$3.14 |
31.19 |
"MPGuino helps alot! Also trip to Detroit 100 miles highway." |
2011-01-12 |
379 |
13.68 |
$3.05 |
27.7 |
"Got quite a bit of snow and temps in the single digits most days." |
2011-01-20 |
13.6 |
$3.08 |
27.43 |
"Cold weather still killing me . Filled with 89 octane so I will see if there is any change." |
2011-01-31 |
383.3 |
14.3 |
$3.13 |
26.8 |
"This tank was with 89 octane. I had some radiator problems so a lot of idling and tinkering. Also late to work a few times . Next tank is 87 octane from BP instead of usual Speedway." |
2011-02-03 |
222.9 |
8.9 |
$3.25 |
25.04 |
"I refilled early because we got 12"" of snow, the roads were terrible and I got stuck in the driveway twice and burned up a lot of gas trying to get out." |
2011-02-10 |
367.7 |
13.2 |
$3.08 |
27.86 |
"Pretty normal tank. Dad took it once and the temps have been absolutey frigid. -13 wind chill today!" |
2011-02-18 |
428.2 |
14.06 |
$3.18 |
30.46 |
"Warm temps helping alot! Even got 36mpg and 35 mpg on my work to home commute!" |
2011-02-26 |
405.5 |
13.54 |
$3.44 |
29.95 |
"More snow storms and freezing temps." |
2011-03-07 |
400.9 |
12.84 |
$3.43 |
31.22 |
"Pretty average commute to and from work Few trips to friends house too. Did lose tire pressure and had to refill from 8lbs on passenger rear." |
2011-03-14 |
444.3 |
14.05 |
$3.53 |
31.62 |
"Would have been better but had the car packed with people before getting gas and lost a few total mpgs on the avg." |
2011-03-21 |
410.1 |
13.19 |
$3.48 |
31.09 |
"Still managing a low tire. Got pissed and floored it a lot one day. " |
2011-03-27 |
406.5 |
13.8 |
$3.55 |
29.46 |
"Was fine up until a tranny line to the radiator leaked running my fluid low and killing my mpg by slipping like a mofo till I discovered the problem." |
2011-04-05 |
409.6 |
13.78 |
$3.78 |
29.72 |
"Front end is shaking like an SOB. Have to find out what it is." |
2011-04-11 |
447.6 |
13.83 |
32.36 |
"Gas prices are killing me.. shakes a lot less after new tires and balancing. Still needs something in the suspension as it still has a shimmy at 60. Warm weather is helping." |
2011-04-20 |
435 |
13.01 |
33.44 |
"Snowed one day, cold temps and running late to work a few times. Hopefully next is better!" |
2011-04-28 |
431.6 |
12.05 |
$4.19 |
35.82 |
"Tried and succeeded at trying to leave early and used basic eco driving skills." |
2011-05-02 |
444.1 |
13.8 |
$4.29 |
32.18 |
"Highest fill in a long time.. This was my trip to and from Chicago. The stop and go crazy traffic hurt me quite a bit." |
2011-05-10 |
450.4 |
12.86 |
$3.96 |
35.02 |
"Home to work commute with a few trips to friends house. Pretty good! I am going to try for a 500 mile tank this time!" |
2011-05-18 |
488.8 |
13.96 |
$3.94 |
35.01 |
"Normal commute.. keeping around the 35 mark . Nearing my goal of a 500 mile tank!" |
2011-05-27 |
481.5 |
13.52 |
$3.72 |
35.61 |
"Would have hit my goal but it has been raining buckets which has killed my avg." |
2011-06-06 |
455.6 |
13.4 |
$4.05 |
34 |
"I didn't expect much as we had a huge storm come through and knock out power for about 5 days. So it was the utility car a few days." |
2011-06-15 |
472.2 |
13.42 |
$3.62 |
35.19 |
"Typical commute.. need to fix radiator, front end shimmy and alignment.. might hit 36mpg then!" |
2011-06-28 |
521.8 |
14.18 |
$3.27 |
36.8 |
"Great tank got to take it real easy. Zero highway." |
2011-07-08 |
442.8 |
12.77 |
$3.64 |
34.68 |
"Drove fairly normal. Less Eco habits." |
2011-07-18 |
468.5 |
13.4 |
$3.48 |
34.96 |
"Had some errands to run outside of the work commute brought down my average some." |
2011-08-04 |
480.1 |
14.33 |
$3.56 |
33.5 |
"Same." |
2011-08-11 |
431.2 |
12.85 |
$3.44 |
33.56 |
"Same. Less Eco" |
2011-08-22 |
470.1 |
13.65 |
$3.54 |
34.44 |
"Usual.. got new runs/tires 2 tanks ago." |
2011-08-29 |
437.8 |
$3.63 |
32.92 |
"Lots of errands in town. Stop & go. Less Eco driving." |
2011-09-06 |
435.8 |
12.7 |
$3.77 |
34.31 |
"Finally replaced radiator. Minor Eco driving." |
2011-09-14 |
442.8 |
13.02 |
$3.58 |
34.01 |
"Some Eco driving.. colder temps and few in town trips." |
2011-09-26 |
475.2 |
14.22 |
$2.98 |
33.42 |
"A lot less Eco and several small trips. Got new exhaust kinda.. side exit pipe and tractor muffler.. what 50$ got me lmao." |
2011-10-06 |
467.6 |
14.25 |
$3.38 |
32.81 |
"Not much Eco Driving and messing around some." |
