0000-00-00 |
529 |
15.27 |
34.64 |
2007-12-02 |
33.17 |
2007-12-18 |
322 |
10.24 |
31.45 |
2007-12-26 |
10.91 |
30.25 |
2007-12-30 |
407 |
11.23 |
36.24 |
2008-01-01 |
159 |
5.23 |
30.4 |
2008-01-12 |
11.08 |
34.84 |
2008-01-19 |
356 |
10.46 |
34.03 |
2008-01-27 |
416 |
12.66 |
32.86 |
2008-02-01 |
399 |
10.91 |
36.57 |
2008-02-12 |
356 |
11.07 |
32.16 |
2008-02-18 |
10.83 |
34.44 |
2008-03-17 |
523 |
14.54 |
35.97 |
2008-03-24 |
403 |
11.08 |
36.37 |
2008-04-08 |
412 |
11.35 |
36.3 |
2008-04-10 |
144 |
4 |
36 |
2008-04-18 |
402 |
11.49 |
34.99 |
2008-05-01 |
482 |
13.69 |
35.21 |
2008-06-01 |
688 |
17.03 |
40.4 |
"Started coasting more, made a partial grill block for the last 100 miles, lot of idling from working on cooling system various times." |
2008-06-04 |
123 |
2.875 |
42.78 |
"Driving to work and a trip or two into town, partial grill block, rear tires @50psi front @ 42psi. Cold mornings around 49-52 degrees on way to work, under 60 on way home." |
2008-06-11 |
356 |
9.074 |
39.23 |
"Mostly commuting. Mornings in the mid 40s, 55-60 max high, rainy for the week. 80 miles were with 400lbs extra weight and moderate to heavy traffic." |
2008-06-16 |
360 |
9.049 |
39.78 |
"about 1/3 of the tank was with warmer weather, around 60-65 degrees. Didn't do engine off coasting nearly as much. Passed people on several occasions. Made two out of town trips with passengers. I didn't drive nearly as eco-friendly as with other tanks. Took the freeway (80mph) over the side road for the first 3 miles and last 3 miles of each commute, the other way is 50mph and right along the freeway." |
