2011-06-02 |
300 |
27.27 |
"base line initial fueling
mileage and fuel used estimated from records
top injector w/ 20% NM 80% methanol /castor oil" |
2011-07-03 |
239 |
19.92 |
"additives
1/4 turn drip 70 M /10 castor /20 NM
mixed driving -no top
adjustments:
advanced ignition 1/4 turn leaned mix 1/4 turn
changed thermostat from 160 to 195" |
2011-07-11 |
86 |
4.25 |
20.24 |
"no ethanol fuel added
when checked timing was 60 BTDC
Set Ing Timing to 20 degrees BTDC..
compression check 10 july 140/120/140/110
oil pressure hot idle 2 kg/cm speed 4 kgcm
Restore Product added @ 3800 odo" |
2011-08-08 |
$3.65 |
28.62 |
"Heritage fuel no-ethanol 3980 odo
oil pressure hot: idle 2 kg/cm and a needle width
speed 4 kg/cm and a needle width" |
2011-12-02 |
323 |
11.2 |
28.84 |
"No -Ethanol fuel
30 mile runs
MMO in the top oiler" |
2012-02-07 |
279 |
25.36 |
"No-Ethanol
2 -30 mile runs balance in-town less than 5 miles OAT @ 40F MMO in the top oiler" |
2012-05-25 |
308 |
10.057 |
30.63 |
"No Ethanol fuel 30 mile runs .MMO in the top oiler @1-2 turns
Compression test cold 1140 miles since *Restore* added
#1 150
#2 140
#3 150
#4 140" |
2012-10-20 |
252.9 |
9.94 |
25.44 |
"no ethanol fuel mmo in top oiler" |
2013-05-08 |
313.2 |
12.6 |
$3.279 |
24.86 |
"added10% ethanol fuel
fuel consumed in & around town over winter" |
2013-08-14 |
296 |
10.5 |
$3.209 |
28.19 |
"10% ethanol used
methanol 70%, nitro-methane 20% castor oil 10% in top oiler" |
2013-12-05 |
287.5 |
9.712 |
$2.909 |
29.6 |
"10% ethanol fuel , hot soup in the top oiler" |
2014-05-19 |
266 |
10.298 |
25.83 |
"10% ethanol added and burned
top jar was dry, added MMO[mystery marvel oil]
metering was 2 turns , , it smoked like a freight train , all the good all that mmo in the top is not so bad
reduced to 1/4 turn and no smoke" |
