2011-07-28 300.4 9.63 31.19 "Trips to work and back mostly, 2 runs in a 90k zone though. First full tank in this car.
Tyres will need changing soon, no mods at all except maybe the right foot."
2011-08-09 329 9.35 35.19 "529.5kM - could be slightly wrong though as the car last had around 480kM on the trip meter, then the battery lost power and the trip computer reset, 49.5 was on the trip computer at fill up, 480 being the last remembered number prior to the battery issue."
2011-08-20 313.7 9.36 33.51 "Average tank, trips in traffic reduce economy.
Still searching for a comms way to add an OBDuino.."
2011-09-15 343.6 9.946 34.55 "- This is the tank after the battery was replaced (8 year old battery!).
- The fuel for this tank (which is what will be used by the next set of kms!), is from another servo though. Fuel prices for E10 are $1.45L, but PULP from ""Metro"" was 1.499/L. So filled with that, not sure if it's crap fuel though (let the K's decide)."
2011-09-26 337.3 9.518 35.44 "The fuel for this lot of k's is hard to say what has improved.
""Jack Rabbit"" Pulse & Glide used (definitely attempted wider opening of the throttle).
A long drive was done too - that could have been it (not so likely..)
The fuel was from another servo and just 'Premium Unleaded' - was cheaper, but.. what RON rating?
And at the end of the tank, we have 4 new tyres - not a likely effect to be seen just yet though."
2011-10-09 363 9.917 36.6 "This was back at the old servo, same fuel again, only changes were tyres from last tank and P&G with fast acceleration."
2011-10-23 354.7 9.589 36.99 "Pretty ordinary running - still using Jack Rabbit. No real change from previous tanks."
2011-11-05 356.8 9.89 36.08 "Regular driving, perhaps I was less efficient than I usually would be.
One trip with the A/C on too."
2011-11-18 324.23 9.63 33.67 "Fairly ordinary. Nothing much - maybe a bit of juice wasted driving aggressively.."
2011-11-29 340.7 9.42 36.17 ""
2011-12-12 340.64 10.14 33.59 "Overfilled this time."
2011-12-23 361.82 9.96 36.33 "Filled up now with 98 RON, perhaps more fuel efficient.. price wasn't much more than 95 RON.
However, Christmas break so no more trips to work for some time.."
2012-01-07 336.22 9.5 35.39 "Switched to premium, this trim was during holidays so not usual day to day trips."
2012-01-24 364.74 9.33 39.09 ""
2012-02-07 333.49 9.92 33.62 "Oil changed again.
Back to work, possibly traffic (it gets reallly slow if the timing is wrong).
Was also testing steady RPM driving on half this tank - difficult to see results.
Will need to get some real time data on that!"
2012-02-19 356.17 10.1 35.26 "95 RON"
2012-02-29 369.09 9.8 37.66 "The 594 kms are made of a lot of Highway kMs (around 200), with some lengths of slow traffic negating some of those highway benefits. The tank the kMs came from was 95 RON.
Now filled with 98 RON (1.56), so hopefully the tank starts to improve based on the higher octane fuel...
Also, this tank is 'better' because of the home trip - it's a few minutes earlier thus aiming to get into better flowing traffic (after 4pm - slow!)."
2012-03-19 469.45 12.45 37.71 "More 98 RON, though there was some freeway driving too so that might make the figures artificially better than normal.
Higher kMs is due to a fuel up mid tank, but I added the 10L to fuel used.
The oil was changed to one which promises lower friction (and is 10W30 over 10W40 in Magnatec), 100kMs into this tank.
Hard to say if it's the freeway trips or the 98RON fuel giving better mileage. Needs some more monitoring."
2012-04-03 351.57 9.1 38.63 "98 RON
Filled up before fuel light came on as I figured there'd not be enough for another trip.
Normal commuting for this tank.
Aside from the trips to that large hardware store and the wholesale chicken place, nothing stands out.
Work traffic was avoided most ?all? this tank."
2012-04-18 344.3 9.38 36.71 "Must have been more traffic this time or too heavy on the foot.
98 RON, normal work running."
2012-05-02 278 7.63 36.44 "98 RON.
Work trips only. Traffic issues I think."
2012-05-12 333.61 9.41 35.45 "Freeway trips (not economy), not too many, but some trips were slow in traffic too.
98 RON"
2012-05-25 343 9.48 36.18 "98 RON
Some slow work runs- temps are colder now, i wonder if that's it?"
2012-06-10 329.26 9.54 34.51 "98RON Some slow traffic trips, perhaps the right foot is too heavy too?"
2012-06-28 323.36 9.19 35.19 "98 RON
Started opening the throttle in this tank in the middle opening up to 100% in the highest gear suitable.
No real issues this tank."
2012-07-10 303.85 8.22 $1.529 36.96 "Filled up before end of tank at a new servo due to Sydney trip.
98 RON.
Good running, minimal traffic."
2012-07-18 365.86 9.63 $1.379 37.99 "98 RON fill.
The kMs for this tank were a large amount of Sydney KM (Freeway) - the fuel was from the Shell servo off the Freeway exit.
Had an issue with the crankshaft sensor - replaced at the empty tank mark, and now filled up.
Both Crankshaft and Camshaft sensors replaced."
2012-07-29 281.79 7.8 36.13 "98 RON
Towing a trailer / parachute (sucks fuel) so filled up at 1/4 tank for pending Sydney trip.
Sydney trips through this tank too.
Work running was poor traffic too."
