2011-09-05 | "Baseline, not actual tank ~ approximate value of previous tanks for reference." | ||||
2011-09-07 | "First true fuel log and addition of Scan Gauge" | ||||
2011-09-12 | "result of grill block and gliding. This grill block encompasses most of the front panel gaps and was more efficient then the newer more hidden block" |
2011-09-16 | "" | ||||
2011-09-22 | "Different gas station, Driving in rain multiple days. Removed first grill block and replaced with more hidden block which does not cover all panel gaps." |
2011-09-28 | "Added additional 1/3 lower grill block halfway thru tank with small square hole near air intake" | ||||
2011-10-06 | "Last few miles of tank maxed out tire pressure to 51 front and 44 in the rear. Re fueled w. 89 octane to see if it had any effect on mileage, ign was reading 23 that evening on the scan gauge in light rain at 55-60mph." | ||||
2011-10-12 | "Looking at houses one day lowered totals. Refill with 87 and did a more complete temporary grill block and bumper reshape on last 1/4" | ||||
2011-10-16 | "One day looking at houses" | ||||
2011-10-21 | "" | ||||
2011-10-28 | "" | ||||
2011-10-31 | "" | ||||
2011-11-07 | "siliconed headlights and front panel gaps, final version of grille block installed." | ||||
2011-11-10 | "" | ||||
2011-11-16 | "" | ||||
2011-11-19 | "driving with A/C and looking at houses/ city" | ||||
2011-11-21 | "long trip 240 miles to at freeway speeds of 60mph other half of the tank was work commute, one long hard city commute and a short highway trip ~40 miles" |
2011-11-29 | "" | ||||
2011-12-02 | "Cool weather and too fast driving" | ||||
2011-12-09 | "" | ||||
2011-12-15 | "" | ||||
2011-12-21 | "Eoc 1 day" | ||||
2012-01-25 | "New house....new route. Fresh oil for next tank @ 100.5k miles" | ||||
2012-02-03 | "" | ||||
2012-02-10 | "Some high speed driving and short trips. Added lawn edging as air dam, net gain of zero so far @ speed. Might trim 2"" off of it after next tank" | ||||
2012-02-19 | "lawn edging air dam added, and cut to help after a tank full of no progress" | ||||
2012-03-10 | "lawn edging cut to act as a deflector for the front tires, added new fins on tail lights to help break flow. plan to continue down the side of car" | ||||
2012-03-16 | "some long coasts netting 42-44mpg's during commute. a few short trips and one highway trip brought down average" | ||||
2012-03-27 | "" | ||||
2012-04-08 | "" | ||||
2012-05-18 | "" |
