2011-09-30 |
645.9 |
10.766 |
$3.39 |
59.99 |
"First full tank in new Insight. FCD showed 60.3 mpg" |
2011-10-05 |
569.2 |
10.645 |
$3.67 |
53.47 |
"FCD read 55.9mpg. No driving techniques. getting baseline mpg." |
2011-10-23 |
619.5 |
10.232 |
$3.65 |
60.55 |
"Long last entry I had written down. Still had the potenzas on before changing to winter tires." |
2011-11-01 |
581.9 |
9.916 |
$3.65 |
58.68 |
"No driving techniques. getting baseline mpg.Got CEL for battery - running without IMA until further notice." |
2011-12-28 |
574.3 |
9.851 |
$3.45 |
58.3 |
"No driving techniques. getting baseline mpg." |
2012-01-13 |
439 |
$3.63 |
46.21 |
"NYC and back - Discovered at the end of this tank that I had a little thump-thumpy rear wheel with a lugnut unfastening. Uh oh - good thing I caught that. That certainly must have negatively influenced the mileage in addition to the beefy studded snow tires. Dashboard indicated 47.2mpg" |
2012-01-16 |
409.9 |
9.902 |
$3.63 |
41.4 |
"The display read 43.2mpg. Still snow tires. draggggggg" |
2012-01-22 |
448.3 |
12.8 |
$3.67 |
35.02 |
"During the last fill it was flippin cold out and I tried the best I could to top the fuel into the filler neck, but apparently I did a horrible job, or that gas is going someplace special because this fill was HUGE, but I got to take my time and really get it to where I could see ""the whites of its eyes"". At least the next fill (if I can get a good fill again) will be way more accurate than this one because this one is garbage.... but I'll put it on anyway. For science! The display read 45.5.mpg. It was real cold. Most of this tank was highway mileage, but at least I had my loose rear lugnut tightened up. IMA was also back for this tank, but there are too many variables to determine whether that helped or not thanks to the huge margin of filling error." |
2012-03-17 |
675.1 |
10.499 |
$3.95 |
64.3 |
"The fill before this one was monstrous - I somehow squeezed almost 12 gallons in after a trip my friend took with the car and filled it up without me knowing about it (meh). I tried to get as much in as posible, but this time it only allowed about 10.5 gallons, so this has to be a flawed mileage number. The FCD read 54.9. Switched away from snow tires during this tank - 2 RE92s up front, 2 skinny geo metro type R13's in back." |
2012-05-27 |
684.3 |
11.496 |
$3.69 |
59.53 |
"fcd read 59.9" |
2012-06-04 |
580.67 |
9.44 |
$1.19 |
61.51 |
"fcd read 60.6. Driving from home to just outside Toronto with a few stops and some city driving in between. NEXT TANK will reflect the removal of the defroster fuse and the power steering fuse. Also added a clutch switch, which will be nice for telling IMA to get lost when it just happens to feel like regen-ing at poorly chosen times." |
2012-06-10 |
654.8 |
10.29 |
$3.69 |
63.63 |
"Right outside Toronto to Kingston, Brockville, around Brockville a little, Montreal, Charlemagne, back to Montreal, then to Malta NY. This fill was very similar to the last, so this should be a good reflection of ""normal"" driving. I think from this fill on I will begin employing more hypermiling techniques. Also added the clutch mod during this tank, which should be useful. fcd read 66.2." |
2012-07-05 |
665.7 |
9.302 |
$3.45 |
71.57 |
"FCD read 68.8. Starting to ramp up the driving techniques a bit again - using some EOC, very light on the throttle, going pretty slow and hanging around lean burn a lot. Gave the battery pack a nice 20 hour float charge (battery indicator was already full when I plugged in) for good measure, right at the very end of the tank before this fillup. Continuing with the ""4 clicks"" fillup method with the pump nozzle about halfway as far in the filler neck as it can go, with the last 4 clicks as slow a fill as I can make them. I think this will provide mor ereliable results than messing with the chance of filling the evap tube and getting sporadic monstrous fills from nowhere." |
2012-07-27 |
648.8 |
9.741 |
$3.65 |
66.61 |
"FCD read 66.9mpg. Been consistently paying a lot of attention to either keeping in lean burn or gliding. Also actively using clutch spoof to avoid charging the battery whenever the car feels like it." |
2012-09-12 |
387 |
6.876 |
56.28 |
"Mostly highway or tooling around town... Don't remember, really. Not a lot of attention to FE..." |
2012-10-06 |
601.7 |
9.64 |
$4.05 |
62.42 |
"To Albany area and back, with some in-town driving up there, then some in-town driving back down here. Kept it pretty light on the highway, but didn't spend a lot of effort on FE in town." |
2012-10-30 |
559.4 |
10.041 |
$3.86 |
55.71 |
2012-11-29 |
479.8 |
9.164 |
$3.71 |
52.36 |
"Getting pretty cold... should probably make a grill block." |
2013-01-05 |
544 |
9.988 |
54.47 |
"Studded snow tires.
54.9 on fcd" |
2013-02-13 |
399.6 |
8.5 |
$3.87 |
47.01 |
"46.7 on fcd
regular old not using it much. Round town, some highway. Rollin' on big studded snows." |
2013-02-17 |
433.3 |
45.61 |
"47.2 on fcd
mostly highway - good tailwind 50+mpg to saratoga springs, then HORRIBLE headwind to syracuse. Studded snow tires. Replaced air filter at the end of this tank because it was acting real sluggish. Definite improvement. Also added lucas injector cleaner at the beginning of next tank. Inspected oil, still looks pretty clear, like grade b maple syrup. smellin' a little gassy, but of course it would." |
2013-03-25 |
379 |
8.372 |
45.27 |
"46.7 FCD" |
2013-04-08 |
460.3 |
9.642 |
$3.69 |
47.74 |
"50.2 fcd" |
2013-04-23 |
390 |
7.06 |
$3.55 |
55.24 |
"54.5 fcd" |
2013-05-04 |
438 |
7.949 |
$3.53 |
55.1 |
"57.3fcd" |
2013-05-06 |
438.1 |
7.959 |
$3.45 |
55.04 |
"56.4 fcd" |
2013-05-18 |
475.8 |
8.522 |
55.83 |
"58 fcd" |
2013-05-28 |
592.7 |
9.821 |
$3.54 |
60.35 |
"58.5 fcd" |
2013-06-02 |
533.5 |
9.095 |
$3.53 |
58.66 |
"58.9 on the FCD. Starting to get real warm, lots better mileage without trying much at all" |
2013-06-17 |
608.2 |
10.477 |
$3.65 |
58.05 |
"61.3fcd" |
2013-06-28 |
578.9 |
10.544 |
$3.39 |
54.9 |
"57.1fcd" |
2013-07-23 |
432 |
7.139 |
60.51 |
"58.0fcd" |
2013-07-26 |
528 |
9.29 |
56.84 |
"MTL trip 57.5fcd" |
2013-08-11 |
434.8 |
7.751 |
$3.72 |
56.1 |
"54.9fcd" |
2013-08-15 |
403.3 |
9.126 |
$3.87 |
44.19 |
"Canada trip - bikes on back and very laden. 47.2fcd" |
2013-08-17 |
380.9 |
8.1 |
$1.265 |
47.02 |
"Canada trip - bikes on back and very laden. This was mostly from Toronto to Cornwall; got some nice tailwind. 44.1fcd" |
2013-08-19 |
467.7 |
10.849 |
$3.75 |
43.11 |
"Canada trip - bikes on back and very laden. Mostly southward in NYS, got to draft quite a bit, but mountainous. 47.2fcd" |
2013-09-11 |
493.8 |
8.924 |
$3.82 |
55.33 |
"53.1FCD" |
2013-09-15 |
518.8 |
10.179 |
$3.54 |
50.97 |
"52.4FCD" |
2013-09-16 |
514.4 |
10.035 |
51.26 |
"51.4FCD" |
2013-09-20 |
534.9 |
10.487 |
$3.73 |
51.01 |
"56.1FCD" |
2013-11-09 |
397.2 |
7.613 |
$3.42 |
52.17 |
"51.2FCD" |
2013-11-11 |
510.7 |
9.88 |
51.69 |
"54.7FCD" |
2013-12-05 |
481.2 |
10.246 |
46.96 |
"snow tires, not much technique going on
48.8FCD" |
2014-01-01 |
449.1 |
9.935 |
$3.65 |
45.2 |
46.2FCD" |
2014-01-13 |
449.1 |
9.935 |
$3.65 |
45.2 |
"46.2 fcd" |
2014-01-26 |
323.9 |
7.776 |
$3.48 |
41.65 |
44.8FCD" |
2014-01-26 |
323.9 |
7.776 |
$3.48 |
41.65 |
"44.8 fcd" |
2014-02-15 |
454.7 |
9.995 |
45.49 |
46.2FCD" |
2014-02-15 |
454.7 |
9.995 |
45.49 |
"46.2 fcd" |
2014-04-05 |
468.8 |
9.79 |
$3.69 |
47.89 |
"48.6 fcd summer tires, seafoam, and new air filter were added." |
2014-05-03 |
537.3 |
9.881 |
54.38 |
"56.6 fcd" |
2014-06-06 |
350.4 |
6.244 |
56.12 |
"59.4fcd
get some gas before entering Canada/MTL" |
2014-06-12 |
594.16 |
9.581 |
$3.65 |
62.01 |
"64.6fcd
touring around northeast" |
2014-06-14 |
431 |
7.35 |
58.64 |
"66.9fcd
movin'
Mileage for Penske truck:
5/29 388mi 29.204gal $3.67/gal 13.3mpg
5/31 342.4mi 24.402gal $4.09/gal 14mpg" |
2014-06-14 |
618.7 |
9.646 |
$3.69 |
64.14 |
"62fcd
movin'" |
2014-07-04 |
469.9 |
7.54 |
$3.65 |
62.32 |
"58.2fcd" |
2014-07-22 |
379.4 |
6.604 |
$3.61 |
57.45 |
"57.3fcd
pumped up tires during this tank - noticed one was very low. next tank should show more reasonable numbers." |
2014-08-24 |
612.5 |
10.046 |
$3.61 |
60.97 |
"62.2fcd
filled the tank a little differently - (and at the end of a very hot afternoon.) tried to fill as slowly as possible, and to 3 clicks, so I probably managed to fill more gas than was consumed.
mild A/C use, but keeping the leaky-ish tire pumped up and takin 'er pretty easy." |
2014-09-06 |
416 |
6.704 |
62.05 |
"FCD 63.2
Been keeping the LF tire fairly topped (seems to have an extremely slow leak) and takin' er real easy-like. Nothing too extreme, but this has been mostly city driving with a couple there 'n back trips to ""god's country""" |
2014-09-20 |
365.5 |
5.577 |
65.54 |
"Added seafoam to oil and gas during this fillup.
62.7 FCD" |
2014-10-05 |
365.4 |
7.015 |
$3.14 |
52.09 |
"56.8 FCD" |
2014-10-17 |
567.6 |
9.799 |
$3.18 |
57.92 |
"61.3fcd" |
2014-10-19 |
558.7 |
8.99 |
$3.17 |
62.15 |
"62.5fcd" |
2014-11-09 |
402.2 |
7.229 |
$2.99 |
55.64 |
"55.9fcd" |
2014-11-22 |
534.3 |
9.95 |
$3.25 |
53.7 |
"Put on snow tires
53.3fcd" |
2014-12-31 |
448.7 |
10.495 |
$2.44 |
42.75 |
"45.8fcd" |
2015-02-12 |
404.8 |
9.708 |
$2.48 |
41.7 |
"42fcd
Lots of snow driving and shorter trips - real cruddy." |
2015-02-25 |
432.1 |
10.442 |
$2.59 |
41.38 |
"43.4fcd" |
2015-03-25 |
367 |
9.819 |
$2.95 |
37.38 |
"39.2fcd
Added seafoam, changed o2 sensor, then changed back due to ""chunky"" lean burn. Old o2 sensor started working OK again." |
2015-04-11 |
320.2 |
6.456 |
$2.37 |
49.6 |
"45.8fcd" |
2015-05-03 |
498 |
8.823 |
$2.55 |
56.44 |
"58.2fcd" |
2015-05-30 |
244 |
4.451 |
$2.99 |
54.82 |
"62.5fcd" |
2015-05-30 |
458.5 |
8.711 |
$2.85 |
52.63 |
"52.4fcd" |
2015-06-03 |
682.6 |
10.66 |
$2.89 |
64.03 |
"63.9fcd" |
2015-06-06 |
546.1 |
8.683 |
$2.72 |
62.89 |
"62 FCD" |
2015-06-09 |
374.8 |
6.508 |
$2.92 |
57.59 |
"62.7 FCD. End of roadtrip, just topping up in Indiana where the gas is cheaper." |
2015-06-09 |
448.7 |
7.704 |
$2.59 |
58.24 |
"60.3 FCD. Westward return." |
2015-08-16 |
523 |
10.284 |
50.86 |
"50.5 FCD" |
2015-09-10 |
318.3 |
6.37 |
49.97 |
"49.8FCD mostly city driving" |
2015-09-14 |
547.8 |
8.982 |
$2.13 |
60.99 |
"63.4fcd pawpaw fest trip" |
2015-09-14 |
324.2 |
5.206 |
$2.22 |
62.27 |
"71.2fcd pawpaw trip" |
2015-09-26 |
571.2 |
9.068 |
62.99 |
"58.7fcd" |
2015-10-31 |
477.5 |
9.975 |
$2.77 |
47.87 |
"50.5fcd" |
2015-11-07 |
580.7 |
10.369 |
$2.19 |
56 |
"58.9fcd" |
2015-11-15 |
576.6 |
9.701 |
$1.89 |
59.44 |
"60.1fcd" |
2015-11-21 |
508 |
9.58 |
$1.84 |
53.03 |
2015-11-25 |
567 |
10.025 |
$2.23 |
56.56 |
"56.6fcd" |
2015-11-28 |
495.4 |
9.185 |
$2.07 |
53.94 |
"56.1fcd" |
2015-11-30 |
568.4 |
9.728 |
$1.99 |
58.43 |
"59.2fcd" |
2015-11-30 |
306.7 |
5.593 |
$1.83 |
54.84 |
"58.7fcd" |
2015-12-20 |
504.2 |
9.655 |
$1.83 |
52.22 |
"52.1fcd" |
2015-12-20 |
521.6 |
9.714 |
$2.16 |
53.7 |
"56.1fcd" |
2015-12-26 |
524.3 |
10.71 |
$1.79 |
48.95 |
"53.1fcd" |
2015-12-26 |
391 |
7.64 |
$1.83 |
51.18 |
"48.1fcd" |
2016-01-02 |
500.6 |
9.62 |
$1.89 |
52.04 |
"51.9fcd" |
2016-02-08 |
359.1 |
8.841 |
$1.87 |
40.62 |
"45.5fcd" |
2016-03-26 |
428.2 |
9.228 |
$2.35 |
46.4 |
2016-04-17 |
257.2 |
5.455 |
$2.19 |
47.15 |
"47.0fcd" |
2016-04-21 |
341.7 |
7.41 |
$1.97 |
46.11 |
"47.9fcd" |
2016-06-04 |
557.2 |
10.23 |
$2.34 |
54.47 |
"Changed oil at 179847, sent oil in to Blackstone labs" |
2016-06-05 |
241.2 |
3.856 |
$2.35 |
62.55 |
"Kalamazoo: There 'n back again on new oil. 66.7fcd" |
2016-07-04 |
527.8 |
9.408 |
$2.29 |
56.1 |
"mke trip" |
2016-07-17 |
563.7 |
9.648 |
$2.33 |
58.43 |
"59.2fcd
fuel pump didn't autostop properly, so I had a minor spill on this fill. woops." |
2016-08-20 |
563.3 |
10.178 |
$2.32 |
55.34 |
2016-10-02 |
532.1 |
10.145 |
$2.09 |
52.45 |
"54.5fcd" |
2016-11-04 |
534.6 |
10.269 |
$1.99 |
52.06 |
"55.9fcd" |
2016-11-19 |
528.6 |
9.339 |
$2.15 |
56.6 |
"57.3fcd" |
2016-11-23 |
582.8 |
10.218 |
$2.29 |
57.04 |
"60.3fcd" |
2016-11-26 |
505.3 |
8.985 |
$2.22 |
56.24 |
"54.2fcd" |
2016-11-26 |
496.9 |
10.323 |
$1.97 |
48.14 |
"50.9fcd" |
2017-01-28 |
455.8 |
9.448 |
$2.04 |
48.24 |
"50.7fcd" |
2017-01-28 |
277.1 |
5.298 |
$1.99 |
52.3 |
"52.1fcd" |
2017-04-21 |
309 |
6.562 |
47.09 |
"50.7fcd" |
2017-04-21 |
560 |
9.304 |
$2.31 |
60.19 |
"60.6fcd" |
2017-06-23 |
511.9 |
9.17 |
$2.22 |
55.82 |
"57.3fcd" |
2017-07-09 |
579.1 |
9.793 |
$2.15 |
59.13 |
"58.9fcd" |
2017-07-11 |
429.3 |
7.463 |
$2.43 |
57.52 |
"62.5fcd" |
2017-07-17 |
610.9 |
10.24 |
$2.44 |
59.66 |
"59.9fcd
added seafoam to next tank" |
2017-07-17 |
475.3 |
7.697 |
$2.34 |
61.75 |
"60.8fcd
added oil during this tank - found it had been either burning or leaking. Seems like a very slow loss of oil, luckily." |
2017-08-27 |
463.4 |
8.315 |
$2.29 |
55.73 |
"55.2fcd
-8/13 replaced bottom engine mount. Marked improvement on the ol 'first gear quakes'
-8/26 replaced sparkplugs to continue troubleshooting bad FE" |
2017-09-24 |
533.1 |
9.231 |
$2.69 |
57.75 |
"58.2fcd" |
2017-10-28 |
545.4 |
10.112 |
$2.47 |
53.94 |
"57.1fcd" |
2017-11-11 |
532 |
9.664 |
$2.55 |
55.05 |
"55.4fcd" |
2017-11-12 |
545.8 |
10.227 |
$2.65 |
53.37 |
"56.8fcd" |
2017-11-20 |
582.8 |
9.98 |
$1.143 |
58.4 |
"60.8fcd
Looks like I was visiting Canada for this one" |
2017-11-24 |
561.4 |
10.532 |
$2.67 |
53.3 |
"53.8fcd" |
2017-11-26 |
508.8 |
10.089 |
$2.31 |
50.43 |
"51.7fcd" |
2017-11-27 |
412.2 |
6.847 |
60.2 |
"63.6fcd" |
2018-04-24 |
445.6 |
9.733 |
$2.85 |
45.78 |
"47.0fcd
Wow - looks like I went over 4 months without refeulling!" |
2018-05-25 |
565.1 |
10.109 |
$2.81 |
55.9 |
2018-05-28 |
597.2 |
10.121 |
$2.89 |
59.01 |
"57.5fcd
** ADDED NTK24301 OEM O2 SENSOR **
Improvement is pretty evident. I really should have splurged for the OEM in the first place. Originally when I got the OBDII O2 sensor a couple years ago, I got the Bosch, which was complete rubbish. I put the original back in and just got slightly worse mileage as I started troubleshooting other things like the EGR plate and the EGR valve (replaced that too), and a new sset of plugs. None seemed to have a noticeable effect like the OEM O2 sensor did. Now it seems to more easily enter lean burn." |
2018-05-30 |
258.4 |
4.769 |
54.18 |
"57.1fcd
This fillup was 91 octane ethanol-free gas I found in Malone NY to fill up before entering Canada. The next fillup should demonstrate dramatic increase in FE. I was shocked at how dramatically FE improved (~60 to ~73) and how much more easily I entered lean burn even on a half-tank mix of regular ol' e10 and ethanol-free. I'm extra curious to see how a full tank of non-ethanol gas works. Here's my back-of-the-napkin ""is it worth the extra price?"" calculation:
73 m/gal 3.59 $/gal 35.90/tank
60 m/gal 3.13 $/gal 31.30/tank $4.60 more per tank
130 more miles per tank $4.60 more per tank
If I went 130 miles more on low-octane gas at 60mpg, it would cost 2.16 gallons * $3.13/gallon = $6.78. Non-ethanol/ 91 octane gas is worth the price." |
2018-06-03 |
638.7 |
9.7 |
$1.446 |
65.85 |
"64.6fcd
91 octane fuel from ontario" |
2018-06-03 |
209.4 |
3.351 |
$3.18 |
62.49 |
"65.3fcd
89 octane fuel" |
2018-08-04 |
607.9 |
9.974 |
$3.27 |
60.95 |
"61.3 fcd
89 octane fuel" |
2018-08-12 |
542.8 |
9.459 |
$2.83 |
57.38 |
"56.1fcd
changed oil" |
2018-09-22 |
517.4 |
9.797 |
$2.98 |
52.81 |
"54.7 fcd
On 9/15 replaced transmission and clutch @ 198398" |
2018-10-12 |
501.9 |
9.013 |
$2.74 |
55.69 |
"55.2 fcd
trans fluid changed at 198942" |
2019-02-16 |
430.6 |
9.694 |
$2.49 |
44.42 |
"46.7 fcd" |
2019-03-27 |
479.5 |
9.888 |
$2.85 |
48.49 |
"50.7 fcd
P1647 engine code (IMA system) - need to remember to start grid charging that poor old weak HV pack." |
2019-03-31 |
594.2 |
10.389 |
$2.58 |
57.2 |
"57.3 fcd" |
2019-03-31 |
168.2 |
3.645 |
46.15 |
"52.8 fcd" |
2019-05-23 |
433.5 |
8.599 |
$3.15 |
50.41 |
"50.2 fcd" |
2019-05-30 |
717.7 |
10.391 |
$2.76 |
69.07 |
"70 fcd
added some oil after a mighty zephyr of fuel economy swept the Fruit Bat eastward.
Also added new wipers." |
2019-06-02 |
613 |
9.804 |
$2.99 |
62.53 |
"61.3 fcd" |
2019-06-02 |
418.3 |
6.724 |
$2.95 |
62.21 |
"64.8 fcd" |
2019-06-09 |
627.3 |
10.201 |
61.49 |
"62.2fcd" |
2019-06-13 |
617 |
9.651 |
$2.49 |
63.93 |
"65.5fcd" |
2019-06-14 |
661.4 |
10.372 |
$2.59 |
63.77 |
"64.6fcd" |
2019-06-17 |
685.4 |
10.539 |
$2.55 |
65.03 |
"65.8fcd" |
2019-06-18 |
365.5 |
5.522 |
66.19 |
"67.4fcd" |
2019-07-08 |
558.1 |
9.879 |
$2.65 |
56.49 |
"56.6fcd" |
2019-07-10 |
606.1 |
9.95 |
$2.75 |
60.91 |
"59.6fcd" |
2019-07-14 |
564.7 |
10.052 |
$2.85 |
56.18 |
"3.9l/100km fcd" |
2019-07-26 |
606.3 |
10.009 |
60.58 |
"3.8l/100km fcd" |
2019-07-28 |
633.9 |
10.502 |
$2.75 |
60.36 |
"3.8l/100km fcd
This tank used 91 octane, ethanol-free fuel" |
2019-08-12 |
511 |
8.967 |
$2.48 |
56.99 |
"58.9fcd" |
2019-09-25 |
470.8 |
8.412 |
$2.63 |
55.97 |
"55.4fcd" |
2019-10-17 |
572.7 |
10.068 |
$2.74 |
56.88 |
"59.9fcd
Added some oil" |
2019-10-17 |
253.5 |
2.661 |
$2.55 |
95.26 |
"66.2fcd
Heavy tailwind? I don't remember what was special here, but I don't see an error in the numbers/where a typo could exist." |
2019-10-21 |
561 |
9.477 |
$2.59 |
59.2 |
"59.4fcd" |
2019-12-01 |
499.64 |
9.802 |
$2.71 |
50.97 |
"4.5l/100km fcd" |
2019-12-08 |
456.02 |
9.657 |
$2.53 |
47.22 |
"4.5l/100km fcd" |
2019-12-10 |
583.65 |
10.449 |
$2.69 |
55.86 |
"4.1l/100km fcd" |
2019-12-20 |
576.32 |
10.009 |
$2.54 |
57.58 |
"4.1l/100km" |
2019-12-21 |
511.2 |
9.68 |
$2.58 |
52.81 |
"4.2l/100km" |
2019-12-29 |
511.9 |
9.879 |
51.82 |
"54.5fcd" |
2019-12-31 |
549.4 |
10.431 |
$2.67 |
52.67 |
"52.8fcd
Added some oil" |
2019-12-31 |
345.4 |
6.677 |
$2.43 |
51.73 |
"52.4fcd" |
2020-02-25 |
470.3 |
9.773 |
$2.69 |
48.12 |
"49.3fcd. added some oil." |
2020-02-25 |
346.9 |
6.762 |
$2.37 |
51.3 |
"53.1fcd" |
2020-09-17 |
578.62 |
10.235 |
$2.45 |
56.53 |
"3.7l/100km fcd. This tank had been filled with ethanol-free gas by my father after the car sat outside for about 6 months with occasional driving just to keep it limber. I also changed the oil before going through this tank." |
2020-09-27 |
589.37 |
9.576 |
$2.14 |
61.55 |
"3.8l/100km fcd" |
2020-09-28 |
538.42 |
9.046 |
$1.94 |
59.52 |
"3.7l/100km" |
2020-10-28 |
641.32 |
10.371 |
$2.05 |
61.84 |
"3.7l/100km fcd" |
2020-11-28 |
535.19 |
9.927 |
$1.94 |
53.91 |
"4.2l/100km fcd. Added half a quart of oil. There seems to be a strong pattern emerging here of one fill per month, on the 28th." |
2021-04-03 |
456.52 |
8.988 |
50.79 |
"4.2l/100km fcd" |
2021-04-03 |
579.86 |
9.817 |
$2.61 |
59.07 |
"4l/100km fcd" |
2021-04-11 |
559.98 |
10.394 |
$2.95 |
53.88 |
"4.2l/100km fcd" |
2021-04-18 |
572.84 |
9.572 |
$2.83 |
59.85 |
"3.8l/100km fcd" |
2021-04-18 |
588.56 |
9.041 |
$2.69 |
65.1 |
"3.6l/100km fcd" |
2021-04-25 |
546.5 |
9.35 |
$2.93 |
58.45 |
"4l/100km fcd" |
2021-05-08 |
415.39 |
8.107 |
$3.09 |
51.24 |
"4.0l/100km fcd" |
2021-05-15 |
445.09 |
7.248 |
$3.14 |
61.41 |
"Waxed it. 3.9l/100km fcd" |
2021-05-23 |
578 |
9.532 |
$3.09 |
60.64 |
"rotated tires. 3.7fcd" |
2021-07-17 |
498.46 |
9.358 |
$3.24 |
53.27 |
"4.1l/100km fcd. added .5qt oil" |
2021-07-23 |
592.66 |
10.1 |
58.68 |
"4l/100km fcd" |
2021-07-24 |
549.66 |
9.946 |
$3.27 |
55.26 |
"New tires (RE92) and preventative maintenance replacement of steering boots. 4.2l/100km fcd" |
2021-08-23 |
358.47 |
7.592 |
$3.09 |
47.22 |
"4.6l/100km" |
2021-08-29 |
533.76 |
9.522 |
$3.09 |
56.06 |
"4.2l/100km fcd. valve cover gasket replaced" |
2021-09-07 |
557.18 |
$3.09 |
58.04 |
"4.0l/100km fcd" |
