2012-02-24 | "" | ||||
2012-02-26 | "" | ||||
2012-02-28 | "" | ||||
2012-03-04 | "" | ||||
2012-03-11 | "" | ||||
2012-03-15 | "" | ||||
2012-03-17 | "" | ||||
2012-03-18 | "" | ||||
2012-03-21 | "" | ||||
2012-03-24 | "" | ||||
2012-03-25 | "" | ||||
2012-03-29 | "" | ||||
2012-04-01 | "Short fill. Actual fill was 8.446 gallons. Added .75 gallons from subsequent fill to average consumption. First tank with scangauge. Also added upper grill block. Power steering delete after approx 100 miles." |
2012-04-02 | "Fixing short fill. Actual fill was 2.875. Subtracted .75 gallons and added that to previous fill." | ||||
2012-04-11 | "Slowest fill rate after 9 gallons. Improving EOC skills. ~100 miles of AC" | ||||
2012-04-14 | "More EOC. Fast fill rate to auto-stop." | ||||
2012-04-15 | "All highway/interstate. Leadfoot friend and I split the driving, he averaged 36-38mpg on SG and frequently above 80mph, I was 41-43 mpg and 75 or less. Near 100% AC use. Slowest fill rate." | ||||
2012-04-22 | "Fast fill rate and accidentally let it run all the way to the auto stop. Mix of town and highway." | ||||
2012-04-25 | "Slowest fill rate. Cooler temperatures meant less a/c. Less EOC as well. ScanGauge indicated 42.6 mpg. No adjustment required." | ||||
2012-05-02 | "Slowest fill rate. 50% with AC. Highway running with town mixed. Limited EOC." | ||||
2012-05-05 | "Lots of AC use because it's getting so hot. I need to get moving on underbody trays, the stock plastic is parachuting at times up front. It's beat. Just trying to keep trip MPG over 40." | ||||
2012-05-13 | "Fuel prices are going down. Filled up at slowest fill rate. Scangauge estimate was 0.3 gal low on this fill-up bringing the adjustment to ~16%. DIY tint added on side windows. Looks ok, but needs a professional job. I'm going to run it for some time and then get professional ceramic tint." | ||||
2012-05-18 | "" | ||||
2012-06-17 | "" | ||||
2012-06-17 | "Guess after my helpful friend filled up my car." | ||||
2012-06-17 | "" |
