2012-03-16 |
9.48 |
$4.259 |
44.3 |
2012-03-22 |
407 |
9.21 |
$4.359 |
44.19 |
"60 Miles were ""pushed""" |
2012-03-29 |
445 |
9.72 |
$4.349 |
45.78 |
2012-04-04 |
443 |
9.52 |
$4.279 |
46.53 |
"55PSI then 60PSI, 70% HWY, rest city, starter is getting a workout!" |
2012-04-10 |
439 |
9.86 |
$4.159 |
44.52 |
"Some heavy driving. Added front lower lip" |
2012-04-19 |
394 |
9.04 |
43.58 |
"Rear spats installed" |
2012-04-25 |
438 |
9.955 |
44 |
"More than usual traffic 2x" |
2012-05-03 |
486 |
9.22 |
52.71 |
"Removed cold air intake, replaced with short RAM intake.
Installed fuel pump shutoff switch.
Lots of coasting
Removed more of backseat (seat area), 30 still installed." |
2012-05-12 |
486 |
9.218 |
52.72 |
"A little upset about these numbers (52MPG! ). My SGII said I was at 54.4, for the tank? In the past it had been lower than my actual, the only change was the fuel pump shut off switch. Will need to look into this-" |
2012-05-18 |
440 |
9.16 |
48.03 |
"One horrible day of stop and go traffic. 15mi of my old ways, frequent EOC. Overdue for oil change. Will go this weekend." |
2012-05-26 |
524 |
9.74 |
53.8 |
"Super surprised on this one, the SCII stated 48.5. Plus the fill up wasn't working. Need to research. Got screen (finally) so hopefully will be mirror-less by Tuesday. Used key rather than shut-off for entire tank, for EOC." |
2012-06-03 |
439 |
8.78 |
50 |
"SG was giving in-accurate readouts most of the tank, which really frustrated me, while driving, after a reset it finally was acting as it should. On the day before the fill-up I also replaced the plugs and wires, and a oil change was performed 5W30.
SG TAV was 48MPG.
Also raced and paced a ""Callaway"" Z06 at 115, and learned aero mods are very good! Current tank will be very interesting as well due to the plug and wire change.
I am mirror-less but no camera installed yet. . ." |
2012-06-10 |
408 |
8.45 |
48.28 |
"Oops, after resetting the SG I forgot about the two tank rule, and how accurate the measurements are.
SG tank avg: 61.4" |
2012-06-19 |
423 |
8.454 |
50.04 |
"Had to reset my SG again. SG reported 55.8 TAV." |
2012-06-26 |
411 |
8.68 |
47.35 |
"Second fill-up after SG reset, readings still off" |
2012-06-29 |
223 |
5.31 |
42 |
"Woodmans pump 1. SG seems a little better, but still quite off and quite frustrating.
100 miles of this tank was AC on and 100F and in trafic. Uggh" |
2012-07-09 |
446.4 |
9.08 |
49.16 |
"SG Said 49. Still a little off. I am hoping two more fill-ups it will be good.
More coasting less EOC
Road Ranger Pump 9" |
2012-07-16 |
488 |
51.37 |
"A little racing... Last half of tank was perfecting P&G, love the numbers SG is showing me. Best trip at 65.4.. 95 degrees today, 100 tomorrow, gotta get some beaded seat covers and maybe one of those chest things Wayne uses.
Road Ranger Pump 11
Tires at 60psi
SG tank: 57mpg
GC: 51.5mpg" |
2012-07-29 |
476 |
8.89 |
53.54 |
"P&G, Woodmans pump 1" |
2012-08-05 |
491.1 |
9.772 |
50.26 |
"Had to guess on mileage, as my VSS crapped out due water, 40 mi of the tank or so.
P&G + EOC
Road Ranger - Pump 5" |
2012-08-13 |
487 |
9.556 |
50.96 |
"P&G + EOC
Some rain
Road Ranger Pump 1" |
2012-08-20 |
529 |
9.269 |
57.07 |
"Best tank ever!! Added another lower lip, since I am procrastinating on the belly pan, which I hope to start very soon. I am going to start at the rear.
Most tank P&G, basically if I didn't need to accelerate the car was off. And yes I am quite patient.." |
2012-08-28 |
558 |
9.89 |
56.42 |
"P&G, SG readings high, due to reset.
Some rain
2012-09-06 |
513 |
9.427 |
$4.079 |
54.42 |
"Lots of rain and wind..ugh. Clutch is now slipping, so bump starting is taking extra effort.
2012-09-25 |
545 |
10.51 |
51.86 |
"At the mechanic for half the tank, so I have no idea how it was driven. Overall not bad though. Replaced passenger wheel bearing. Rolls much smoother now though!
Woodmans Pump 8" |
2012-10-01 |
5.466 |
53.42 |
"This was a test, as it seemed I got better range the first half of my tank than the second. Apparently my gauge is off a bit
2012-10-10 |
519 |
9.726 |
53.36 |
"Cold and rainy most of this tank. Ordered LED fogs so I don't need to use my battery sucking headlights at dusk and dawn.
2012-10-20 |
493 |
10.113 |
48.75 |
"Even colder and rain, plus wind! Crap tank. Got the LED fogs installed, don't do much for me, but others can easily see me at dusk and dawn, plus almost no batt. drain. Moved my fuel cut-off switch to the FI relay, much cleaner offs and easier starts. Replaced the ""lawn trim"" lower lip with 8"" black coroplast, looks more OEM and cleaner.
Got tons a oil leaks effecting my clutch at mid to high RPM, ordered new gasket for my VTEC solenoid to start eliminating leaks.
Road Ranger Pump 2" |
2012-10-27 |
522 |
8.376 |
62.32 |
"Best tank so far! Finally broke 60.
Clutch still slipping.
Some rain and wind this week
Road Ranger Pump 3" |
