2012-02-28 265.6 13.212 $3.769 20.1 "Pizza Deliver car.
Got oil changed, air filter about 75 miles into this tank.
Has fuel leak needing fixed. Also breaks are locking up. need fixed"
2012-03-03 279.5 12.738 $3.769 21.94 "Pizza Deliver car. Has fuel leak needing fixed."
2012-03-06 244.6 12.192 $3.899 20.06 "Pizza Deliver car.
The gas pump was acting up, so I'm not sure if the tank is actually full. Will probably throw off this average and next.
2012-03-11 253.4 12.92 $3.86 19.61 "Pizza Delivery car"
2012-03-12 110.8 6.144 $3.86 18.03 "Pizza Delivery car
I filled up when I half a tank to try to get an idea of how much fuel I am leaking on the first half a tank, because that is where I smell gas the most. Turns out it sucks. I'm guessing after i fix the fuel leak I should be getting 23-24 consistently."
2012-03-18 272.3 12.861 $3.86 21.17 "Pizza Delivery car"
2012-03-22 290.1 13.436 $3.96 21.59 "Pizza Delivery car"
2012-03-29 259.5 13.405 $3.96 19.36 "Pizza Delivery car. Lots of in town driving doing deliveries."
2012-04-01 301.41 13.239 $3.969 22.77 "Still Pizza delivery for most of my driving. Almost have the fuel leak in the tank fixed."
2012-04-03 132.29 5.874 $3.79 22.52 "One day of work Delivering pizza. Also has a 20 mile highway trip where i found gas for $.20 less that in town. Still leaking fuel"
2012-04-07 251 10.977 $3.89 22.87 "Mostly delivery. Filled up 40 miles into my 220 mile trip home."
2012-04-10 279 10.777 $3.549 25.89 "Drove home on 4/6 at mile 160 fromm fill up. Then had some time to drive around while home which is the other 119 miles shown.
Fuel leak is still not fixed right."
2012-04-11 230.9 7.631 $3.89 30.26 "This was the return trip from visiting family. Holgate Ohio to Athens Ohio. Hit some bad traffic in Columbus and had to do 70-75 to keep up with the flow.
This was only about half a tank, the first half that leaks fuel. I know I did better mileage on the way up, but didn't fill up when I got there.
Also just checked and the elevation is the same in both places."
2012-04-15 298.3 13.314 $3.89 22.4 "Pizza delivery. Still leaking fuel"
2012-04-20 299.9 13.102 $3.89 22.89 "Still leaking fuel. Should have repaired on wednesday 4/25. Gas light came on at 295.5, so I'm going to shoot for 300 without the gas light coming on next."
2012-04-26 278.4 12.568 $3.79 22.15 "Pizza delivery. Will fix fuel leak in next tank"
2012-05-01 294.8 13.661 $3.79 21.58 "Pizza delivery.
Fixed fuel leak at 215 of this tank.
Went to fill up and one of the hose clamps was loose, so i lost probably around .25 gal on the ground while filling. Got home and fixed (i hope)."
2012-05-07 315.2 13 $3.79 24.25 "Pizza delivery. The amount of fuel used will never happen again so perfectly. Right on 13gal.
Car seems to miss or burp when i start it. Going to run fuel system cleaner in it this tank."
2012-05-12 320.7 13.642 $3.79 23.51 "Pizza Delivery. Still leaking fuel when i fill up. can't get the hose on right"
2012-05-18 351 14.003 $3.79 25.07 "Pizza delivery. A little more highway than usual. Thought i was going to run out of gas.
Actually overfilled this one.
Also still don't have the fill hose on right so i leaked a little while filling up"
2012-05-21 307.4 10.378 $3.65 29.62 "Delivery
Not a full fill
First 212 miles were normal driving/deliver
Last part was all highway.
When i filled, the pump shut off and i thought it was full, but it was not."
2012-05-23 364.5 12.994 $3.76 28.05 "All highway. Last fill up was short/ not full which is why last one is high and this one is low. Should have been in the 32 ish range"
2012-05-30 360.8 14.818 $3.79 24.35 ""
2012-06-05 346.3 13.653 $3.63 25.36 ""
2012-06-12 323.9 13.458 $3.73 24.07 "NOT A FULL FILL.
It was graduation week at OU and the traffic was the worst I have ever seen here. ALOT of sitting in traffic"
2012-06-19 296.5 11.724 $3.58 25.29 ""
2012-06-24 341.9 13.414 $3.52 25.49 "my last 3-4 fills have been past the click at the pumps. It seems to like to click off early, so i make sure to listen to it fill into the filler neck"
2012-06-30 321.7 13.154 $3.42 24.46 "There was a very bad storm in Ohio. All the stations in town were running out of gas. I went to fill up but due to long lines i forgot to check to see if it was full"
2012-07-03 360.9 13.785 $3.39 26.18 "drove home. First 100 miles were delivering pizza"
2012-07-08 361.1 13.585 $3.53 26.58 "drive from home. last 80 or so miles was delivering. It have been very hot so i have been using the AC. not sure if it is the AC or the 2 inch wider tires i put on 2 weeks ago."
2012-07-13 284.4 12.412 $3.43 22.91 "not sure what happened here? It is probably a combination on wider tires, air conditioning because its hot, and my main route to work is blocked so i have to drive 4 miles through town and not on the highway. This next tank is starting out bad as well and I am trying. If it is bad i'm going back to my 15"" tires"
2012-07-21 311 12.986 $3.47 23.95 ""
2012-07-26 189.4 8.432 $3.69 22.46 "Had to fill early because of a storm rolling in. This is a very low tank i feel. With a combination of the wider tires and needing to use the AC, its not good. I will be switching back to my standard tires soon."
2012-08-02 313.6 13.323 $3.89 23.54 "Still had the wider tires on. Need to change them soon."
2012-08-07 340 13.64 $3.86 24.93 "Put my stock tires back on at 220 miles of this tank. Already see an improvement."
2012-08-11 296.4 11.488 $3.86 25.8 "Ran a can of seafoam at around 175 of this tank. 185 got an oil change, Mobile 1"
2012-08-12 215.7 7.712 $3.82 27.97 "Drove home at 2am. This was only the highway drive home. No cars really so no one to draft off.
Also I decided to try 89 octane"
2012-08-17 172.8 6.131 $3.87 28.18 "This was all my driving while I was home. Very flat, and a lot of driving at 55."
2012-08-18 224.6 6.593 $3.76 34.07 "My drive back to Athens from home. I can't believe how high this one is. I had a lot of people to draft off most of the time, but the traffic in Columbus was almost the worst I've had to be in."
2012-08-25 365.1 13.602 $3.72 26.84 ""
2012-09-01 343.5 13.834 $4.059 24.83 "Beat on the car a little this tank. though i was doing bad so i had a little fun with it, drifting around corners in the rain.
This next tank is with 89 octane to help with the spark knock"
2012-09-09 333.7 13.439 $4.059 24.83 "Used 89 octane for this tank and the next."
2012-09-22 364.2 15.565 $3.96 23.4 ""
2012-10-03 326 13.499 $3.94 24.15 ""
2012-10-12 315.8 13.425 $3.79 23.52 "Really annoyed by my MPG the last few tanks. Not sure why it is down...."
2012-10-24 392.8 16.239 $3.79 24.19 "Put 2 gallons in while at work one day just to keep going, which is why it is over 15.5 gallons"
2012-10-31 337.2 14.514 $3.54 23.23 "Figured out that the last few tanks that are low is because of winter gas has been started."
2012-11-11 374.6 15.621 $3.54 23.98 "After filling up this tank, someone broke out my driver side window. Because it is winter and I don't have the money to fix it, it may be awhile before it is driven again"
