2012-04-20 |
476.1 |
9.22 |
$3.72 |
51.64 |
"this was my first tank used in the insight, so this tank was normal driving and getting used to the car. this is my base numbers no hypermiling or ecomodding yet." |
2012-06-09 |
555.6 |
9.789 |
$3.46 |
56.76 |
"added a scangauge2 and used some hypermilling skills. side note still getting used to the car." |
2012-07-13 |
556.1 |
9.641 |
57.68 |
"better and better each tank." |
2012-08-31 |
575.6 |
9.573 |
60.13 |
"labor day weekend so gas was high priced." |
2012-09-25 |
527.3 |
9.628 |
$3.95 |
54.77 |
"starting to get cold here." |
2012-10-26 |
518.6 |
10.103 |
51.33 |
"the cold weather seems to affect my mpg greatly also i need an oil change soon." |
2012-12-07 |
429.9 |
9.354 |
45.96 |
"ima light is on, its storing the code for unbalanced cells but the ima system seems to still be in fine working order....for how long i dont know. also the snow, freezing temps and warm ups are killing my mpg. cant wait for summer to start pulling in the 60mpg range again. also need a oil change very soon." |
2013-01-09 |
397.2 |
9.709 |
$2.91 |
40.91 |
"worst tank to date. car is in need of a tune-up and most of this tank was used in sub-zero temps which means the car has much more idling. snow/ice all to blame. cant wait for spring to pull big numbers again." |
2013-02-04 |
350.1 |
9.623 |
36.38 |
"poor mpg due to coldest month of winter so far. soon i will be doing a full tune up, also hoping for warmer temps, then i should see a great increase in mpg." |
2013-02-21 |
431.1 |
10.112 |
$3.7 |
42.63 |
"new oil pan, gaskets, oil, oil filter, slightly warmer temps, and superamerica gas opposed to holiday gas." |
2013-03-31 |
496.4 |
9.91 |
$3.57 |
50.09 |
"warmer days hit 50 a few days even." |
2013-05-29 |
594 |
11.68 |
50.86 |
2013-07-08 |
572.1 |
10.114 |
$3.45 |
56.57 |
"finally summer in full and it shows in my mpg" |
