2012-11-03 312 12 26 "First tank after purchase. Added injector cleaner. Changed tires from 25"" dia. to 26"" dia. half way through tank. Must still calibrate speedometer for larger tires. Shortened filler tube, which may have reduced tank volume."
2012-11-09 333 13.31 25.02 "Checked speedometer calibration: Accurate within 2%. Added air dam and grill cover. Weather got cooler. Drove 50 miles with 1/3 cord of ash blocks.
2012-11-20 316 12.184 $3.529 25.94 "Raised tire pressure to 40 psi after the first quarter tank. Brought home one 1/4 cord load of ash slabs from 50 miles away. Changed fuel injectors just before end of tank."
2012-11-30 348 13.786 25.24 "Started hard all tank. Just after this fill (a full tank after changing the injectors) I investigated, removed, sea-foamed (with relay open) cold start injector. As I was putting everything back together I noticed the throttle position sensor cable was not connected. D'oh!
I also slipped a piece of .0015"" brass sheet in between the EGR and the intake plenum."
2012-12-08 327 12.278 26.63 "Found fuel leak, #3 injector. Fixed it."
2012-12-28 298 11.856 25.13 "Found fuel leak, #2 injector. Fixed it."
2013-01-09 338 14.009 24.13 "Snow and cold. Changed rear tires to studs."
2013-01-18 346 13.369 25.88 ""
2013-02-12 306 12.511 24.46 ""
2013-02-20 314 12.298 25.53 ""
2013-02-27 351 13.379 26.24 ""
2013-03-05 335 12.982 25.8 ""
2013-03-13 334 13.057 25.58 ""
2013-03-16 396 14.01 28.27 ""
2013-03-28 351 13.981 25.11 ""
