2008-05-15 |
458.2 |
9.956 |
46.02 |
2008-06-17 |
473.1 |
9.352 |
50.59 |
"Some P&G, some engine-on coasting." |
2008-07-22 |
505.2 |
10.12 |
$3.949 |
49.92 |
2008-08-25 |
419.7 |
9.436 |
44.48 |
"First tank with new commuting pattern; my commute is now just a couple of miles long, and is now basically just going up (or down) a large hill. I've also just found out that my front bearings are shot and need to be replaced, along with the struts and the swaybars. Bleah." |
2008-10-21 |
355.8 |
9.272 |
38.37 |
"I had the car in for service during this tank, for a tuneup and to replace a wheel bearing and the front shocks and swaybars." |
2011-05-16 |
471 |
46.77 |
"New commute again, no longer a short run. Car-pooling and telecommuting to try to keep the total gas usage down. There's a bit of an elevation change involved which hurts the tank average by a few mpg." |
2011-06-03 |
410.4 |
8.825 |
46.5 |
2011-08-03 |
487.2 |
10.05 |
$3.719 |
48.48 |
"Carpooling, telecommuting 2x/week." |
2011-10-26 |
460.4 |
10.104 |
45.57 |
"Skipped a tank; I added the last of the mower's gas in it, so I'm not sure exactly how many gallons I used." |
2011-11-18 |
8.579 |
$3.279 |
44.88 |
2012-05-09 |
455.7 |
9.667 |
47.14 |
"Switched to summer tires partway through this tank." |
2012-06-06 |
465 |
9.57 |
48.59 |
2012-06-25 |
437.4 |
9.685 |
$3.329 |
45.16 |
2012-07-25 |
446 |
8.79 |
50.74 |
2012-08-27 |
516 |
9.992 |
51.64 |
"The last half tank is a new commute; slightly farther, fewer hills, and no carpooling (yet)." |
2012-09-08 |
451.9 |
8.985 |
$4.119 |
50.29 |
2012-09-22 |
523.8 |
10.157 |
51.57 |
"This tank was premium, trying to clear out some knocking issues (the previous tank was a different brand than my usual, not going to try it again!)" |
2012-10-05 |
500 |
9.8 |
51.02 |
2012-10-18 |
441.5 |
9.235 |
$3.949 |
47.81 |
2012-11-02 |
500.6 |
10.321 |
48.5 |
2012-11-14 |
468.2 |
9.592 |
48.81 |
"Switched to winter tires mid-tank." |
2012-12-03 |
452.2 |
9.284 |
$3.609 |
48.71 |
2012-12-12 |
375.5 |
7.933 |
47.33 |
2012-12-30 |
390.8 |
8.966 |
43.59 |
2013-01-11 |
9.66 |
43.48 |
2013-01-26 |
433.3 |
10.023 |
43.23 |
"COLD! I let it idle for several minutes to warm up this tank." |
