2013-07-08 204.7 15.29 13.39 "Mostly highway, about 1/8 of tank was around town."
2013-07-22 262.8 18.019 14.58 "Mostly city, some highway. After transmission install, big improvement considering that the last tank was almost all highway miles."
2014-01-20 57.5 3.714 15.48 "Test run of only highway miles to test new gear and tire setup: 235/75r15 with 3.08:1 rear gears."
2014-02-03 221.3 15.283 14.48 "On way from San Diego to WNY in Tacna AZ. First fill up of trip."
2014-02-04 300.5 19.736 15.23 "From SD to WNY in Vega, TX."
2014-02-05 329 23.6 13.94 "On way from SD to WNY in Chandler, OK"
2014-02-05 343 22.09 15.53 "On the way to NY in MO."
2014-02-05 381.7 24.828 15.37 "From SD to WNY in Straughn, IN. Last leg of trip in which tires were under pressure. Discovered they were at 25 psi and pumped up to 35 psi during this fill up."
2014-02-07 498.8 26.44 18.87 "First fill up with tires at 35 psi for whole leg. Done in Lockport, NY. Tank was used up on last leg of journey from SD to WNY. Closest I've come to my 20 mpg target on the highway!"
2014-02-11 524.3 49.845 10.52 "Around 5 Fahrenheit temps. First two fill ups combined on the way back to San Diego in Elkhart IN. First receipt was lost, but memorized number of gallons used to combine on this receipt. While in Upstate NY, lots of idling, moving of trailers in small areas, short trips, etc. Rest of leg was done with 2000 lbs cargo and another 2500 lbs trailer being towed. Poor aerodynamics on enclosed trailer that's about the height of the truck (front is perfectly flat). With no cap, lots of trailer sticking up above tail gate. Also had a large cast iron mill sticking out above the cab of the truck."
2014-02-12 322.8 26.033 12.4 "From WNY to SD in Kearney, MO. Same 4500 lb load, truck/trailer."
2014-02-13 332.2 26.621 12.48 "On way from WNY to San Diego in Tucumcari, NM. Same 4500 lb load on truck and trailer."
2014-02-13 285.7 24.66 11.59 "From WNY to SD in Jamestown NM. Same 4500 lb load truck/trailer. Last receipt I could find from trip. Missing several receipts due to chaotic nature of living out of my truck for 2 weeks. The ones I've located and recorded here are fairly representative of the mileage I got."
2014-03-08 369 30.44 12.12 "In San Diego, all city miles."
2014-03-12 280.8 18.723 15 "In San Diego. Mix of highway/city."
