2013-08-28 |
266.3 |
14.02 |
18.99 |
"$52.70 11:55AM 76 Almaden Expressway
Drove car like ""normal"", no hypermilling. Mom drove for about 1/2 tank (definitely not hypermilled, probably 70-75 MPH and A/C on)." |
2013-09-03 |
325.8 |
16.094 |
20.24 |
"$61.14 8:20PM 76 Almaden Expressway
""Hypermilled"" the car on this tank. Neutral coasting, no A/C, limited acceleration to under 2,000RPMs, etc." |
2013-09-10 |
322.3 |
15.608 |
20.65 |
"$61.48 1:50PM 76 Almaden Expressway
Did some basic maintenance: Changed (really dirty) air filter, sparks plugs and oil" |
2013-09-16 |
232.3 |
11.466 |
20.26 |
"$43.56 5:30PM Bird Avenue Chevron
Pumped tires up to 35PSI about 150 miles into tank. Changed PCV valve and oil filter (finished oil change) on 9/16." |
2013-10-02 |
252.1 |
13.665 |
18.45 |
"$52.73 5:10PM 76 Almaden Expressway
Took off crossbars at about 1/4 tank to empty. Fixed spark plug thread issue part way through tank." |
2013-10-10 |
270.1 |
14.331 |
18.85 |
"$54.44 3:20PM 76 Almaden Expressway
Occasional Engine Tick (I think the fan), squeak on front passenger (I think something along axle), need to check for exhaust leaks and cylinder compression." |
2013-10-18 |
309.9 |
14.4 |
21.52 |
"$54.71 9:00PM 76 Almaden Expressway" |
2013-10-29 |
351 |
17.309 |
20.28 |
"$64.03 10:10 PM 76 Almaden Expressway
Truck wanted to stall occasionally on the way to gas station. Fuel regulator ball valve is getting stuck and causing problems with extremely low fuel and sometimes when starting." |
2013-11-09 |
278.4 |
14.118 |
19.72 |
"$51.09 6:15PM 76 Almaden Expressway
Took Corolla to SLO for 3 days, saved truck fuel" |
2013-11-20 |
298.5 |
14.76 |
20.22 |
"$51.94 7:00 PM 76 Almaden Expressway
Took air foil off with 4.4 miles into tank." |
2013-11-27 |
309.4 |
14.962 |
20.68 |
"$52.65 3:00PM 76 Almaden Expressway
Changed front brake pads and cleaned MAF" |
2013-12-15 |
266.9 |
14.583 |
18.3 |
"$51.32 6:15PM 76 Almaden Expressway
Truck had cylinder 5 spark plug electrode break, causing misfire." |
