2007-08-14 |
351.5 |
15.92 |
22.08 |
"Starting work at TMMK, 30 mile daily commute" |
2007-08-21 |
328.3 |
15.19 |
21.61 |
2007-08-26 |
214.1 |
9.78 |
21.89 |
2007-09-05 |
310.6 |
23.35 |
2007-09-10 |
265.9 |
12.06 |
22.05 |
2007-09-14 |
197.5 |
8.642 |
22.85 |
2007-09-25 |
393.1 |
17.07 |
23.03 |
2007-10-04 |
350.1 |
15.79 |
22.17 |
2007-10-07 |
437.9 |
17.33 |
25.27 |
"I-75/71 to Columbus, OH" |
2007-10-13 |
275.5 |
12.22 |
22.55 |
"Oil Change" |
2007-10-21 |
374.5 |
16.78 |
22.32 |
2007-10-27 |
430.9 |
17.81 |
24.19 |
2007-11-03 |
393.5 |
17.95 |
21.92 |
"Temperature in KY drops below freezing" |
2007-11-09 |
348.1 |
16.29 |
21.37 |
"Experimenting with WAI" |
2007-11-14 |
382.7 |
17.02 |
22.49 |
"More WAI" |
2007-11-17 |
142 |
6.81 |
20.85 |
2007-11-26 |
414.7 |
17.28 |
24 |
2007-11-29 |
172.7 |
8.72 |
19.81 |
2007-12-07 |
366.1 |
17.67 |
20.72 |
2007-12-12 |
213.9 |
10.51 |
20.35 |
2007-12-19 |
304.9 |
15.98 |
19.08 |
"Last tank with modded WAI" |
2007-12-27 |
321.8 |
15.14 |
21.25 |
"Removed modded WAI. Realized that truck has vacuum-actuated temperature-dependent WAI stock, so overriding temperature switch.
Replaced belt-driven fan with Proform electric fan." |
2007-12-30 |
268 |
10.31 |
25.99 |
"Trip to Murray. My Dad topped off the tank, so I may have had more fuel than usual." |
2008-01-01 |
314.1 |
14.39 |
21.83 |
"Murray to Nashville, then back to Louisville (Mostly interstate driving)." |
2008-01-11 |
336.7 |
17.71 |
19.01 |
"Less highway driving now, back at UK." |
2008-01-19 |
126.7 |
6.72 |
18.85 |
"Really cold in KY!" |
2008-02-04 |
237.7 |
11.86 |
20.04 |
"Tried pink foam aero shell with PVC frame. Ok at 55mph, but unstable at 70mph. Back to the drawing board. Maybe window shrink film?" |
2008-02-29 |
354.4 |
17.69 |
20.03 |
"Doing more city driving than usual. Experimenting with Hypermiling driving habits (trying to not use the brakes). Practicing for NASC rayce." |
2008-03-23 |
397.1 |
15.6 |
25.46 |
"So, hypermiling works! Also, pushed the tire pressure up to 40psi (from 35) and kept the cabin vent closed. My HVAC system pulls air in from the cowl, so air flows into my cabin from the air pressure differential even when the fan is off, unless I use the ""off"" (recirculate) setting." |
2008-03-30 |
77.2 |
3.542 |
21.8 |
2008-05-12 |
436.9 |
17.49 |
24.98 |
2008-05-18 |
278 |
12.5 |
22.24 |
"Dad's gift of gas, tank was topped off - not exact measurement" |
2008-05-29 |
484.3 |
19.19 |
25.24 |
"Reached the MasterCard limit at the pump for the first time ever!" |
2008-06-05 |
228.8 |
8.52 |
26.85 |
"Best tank ever! Partial grille block, electric fan conversion with *NEW* manual cutoff switch, partial wheel well covers" |
2008-06-21 |
388.4 |
14.73 |
26.37 |
"Hypermiling, combined with a partial grille block, partial rear wheel covers, sealed cabin, and electric radiator fan swap. I'm doing better in a truck than my friends with cars!" |
2008-07-28 |
438.1 |
17.83 |
$67.04 |
24.57 |
"Back from NASC. Zach borrowed truck to get a bed." |
2008-07-31 |
140.4 |
5.098 |
$18.4 |
27.54 |
2008-08-07 |
200.4 |
7.5 |
$26.98 |
26.72 |
"Took a hit from removing that partial grille block - hit the year's highest ambient temperature this week." |
2008-09-27 |
369.1 |
16.12 |
$57.52 |
22.9 |
"Back in school, mostly city driving" |
