2013-10-30 397.5 22.109 $3.399 17.98 "Ave 43 mph. First tank. Mixed driving."
2013-11-04 478.7 24.723 $3.279 19.36 "Ave 43 mph."
2013-11-11 410.1 21.991 $3.399 18.65 "Ave 43 mph. 85 octane. Working on shift points."
2013-11-19 447.5 22.677 $3.199 19.73 "Ave 44 mph. Bumped timing midway. Shifting at 2500-3000. 85 octane. BFGs at 40 psi."
2013-11-25 428.3 21.448 $3.139 19.97 "Ave 41 mph. 2000-2500 rpm shifts, skipping gears, 55-60 mph max. 85 octane, bumped timing."
2013-12-11 418.9 23.288 $3.179 17.99 "Ave 42 mph. Filled with 87 Shell Fort Lupton E-whatever gas. Headwinds, bad weather."
2013-12-16 520.5 25.676 $3.099 20.27 "Ave 44 mph. Filled with Shell 87. Shifting at 1750 rpm. 55 mph max."
2013-12-27 346 18.848 $2.999 18.36 "Ave 44 mph. Filled with 85 Octane Sams Club. 55 mph max, 1750 rpm shifts."
2014-01-07 485.2 25.148 $3.299 19.29 "Ave 42 mph. Filled with Shell 87."
2014-01-14 540 27.367 $3.199 19.73 "Ave 45 mph. 8 gals 87 in Cheyenne, 19.367 in Fort Lupton Shell 85."
2014-01-23 496.1 25.17 $3.199 19.71 "Ave 43 mph. 55 mph max. 1750 rpm shifts. Dryer vent WAI."
2014-01-30 353 20.268 $3.369 17.42 "Ave 40 mph. Winter weather, using 4x4. Filled with Briggsdale 85."
2014-02-04 465 23.942 $3.349 19.42 "Ave 39 mph. Snow, winter, 4x4 etc. IAC disconnected for this tank."
2014-02-10 479 28.907 $3.369 16.57 "Ave 44 mph. 1750/no IAC, filled with Briggsdale 85. 4x4, very cold weather (well below 10 degrees). Need to improve WAI."
2014-02-14 540.3 24.898 $3.519 21.7 "Ave 44 mph. Nicer mornings and days - above freezing. Filled with Briggsdale 85."
2014-02-19 479.9 23.889 $3.649 20.09 "Filled with Briggsdale 85. Improved WAI."
2014-02-26 479 24.828 $3.599 19.29 "Ave 44 mph."
2014-03-07 597.4 28.863 $3.779 20.7 "Ave 43 mph. Not quite 600 miles."
2014-03-13 552 25.616 $3.779 21.55 "Ave 43 mph. Still 55 mph max, IAC disconnected, WAI. Decent weather."
2014-04-14 520 24.83 $3.579 20.94 ""
2014-04-17 460 22.07 $3.719 20.84 ""
2014-05-05 503.2 25 $3.749 20.13 ""
2014-05-12 495.2 26.29 $3.719 18.84 ""
2014-06-23 752.2 35.76 $3.789 21.03 "Pump limit on first fill. Drove to/from work, filled."
