2013-03-08 |
278 |
11.009 |
25.25 |
"173,671" |
2013-03-15 |
353 |
12.53 |
28.17 |
"174,024 premium" |
2013-03-21 |
338 |
13.183 |
$4.019 |
25.64 |
"174,362" |
2013-03-27 |
375.3 |
13.276 |
28.27 |
"174738" |
2013-04-03 |
342.5 |
12.167 |
28.15 |
"175080" |
2013-04-13 |
155 |
5.662 |
27.38 |
"175439" |
2013-04-16 |
283 |
9.71 |
29.15 |
"175723" |
2013-04-29 |
139 |
5.521 |
25.18 |
"176097
hotday
inj clnr added too" |
2013-05-09 |
309.5 |
13.253 |
23.35 |
"176407" |
2013-05-13 |
235 |
9.717 |
$3.689 |
24.18 |
"175958" |
2013-05-16 |
286.8 |
10.289 |
$4.039 |
27.87 |
"176694" |
2013-05-21 |
205.2 |
7.907 |
25.95 |
"176900" |
2013-05-25 |
189 |
7.392 |
$4.039 |
25.57 |
"177089" |
2013-05-27 |
256 |
9.928 |
25.79 |
"177345" |
2013-06-03 |
355 |
11.676 |
30.4 |
"177700" |
2013-06-24 |
371.6 |
14.016 |
26.51 |
"178509" |
2013-07-03 |
288.1 |
8.691 |
$4.119 |
33.15 |
"178797" |
2013-07-21 |
303.36 |
10.23 |
29.65 |
"179101" |
2013-08-16 |
398.8 |
12.779 |
31.21 |
"179799" |
2013-08-21 |
247 |
7.285 |
$3.719 |
33.91 |
"180048" |
2013-08-27 |
163 |
5.733 |
28.43 |
"180,211" |
2013-08-27 |
436 |
12.769 |
$3.839 |
34.15 |
"180647
speculative distance based on cross-CA trip calc." |
2013-10-18 |
263 |
8.224 |
31.98 |
"182,682" |
2013-10-28 |
357.9 |
11.775 |
30.39 |
"183,040" |
2013-11-19 |
337.2 |
11.55 |
29.19 |
"183,377" |
2013-11-25 |
368.4 |
12.854 |
$3.439 |
28.66 |
"183,746" |
2013-12-02 |
259 |
8.695 |
29.79 |
"184,005" |
2013-12-13 |
101 |
9.897 |
10.21 |
"184839 E" |
2013-12-23 |
309.9 |
10.113 |
30.64 |
"185,149" |
2014-01-02 |
331.3 |
11.336 |
29.23 |
"185480 post-front tire alignment, post rear seat floor carpet pads delete, still no g-block... antenna down fully tho. also starting P&G (need to vinyl that, plus 五十五。。。" |
2014-01-11 |
450 |
12.707 |
35.41 |
"185930, berk
and after this fillup, i got...
* a 2006 subaru wrx spare tire, to shed the plus size 1980s Camry spare tire... (cuz you can't depend on a spray can for a major tire issue, not that i plan to have any...!)
& P&G FTW!" |
2014-01-23 |
377.5 |
12.615 |
29.92 |
"186307. MPGs really dropped. psi? more likely my new commute which is short and on city streets to avoid freeway clogs every morning...
p&g, neutralmatic, ..." |
2014-02-06 |
13.007 |
29.6 |
"186692
low mpg probably. must check psi again.. and do MO MODS" |
2014-02-20 |
405.2 |
12.67 |
31.98 |
"187098 time for an oil change..." |
2014-03-04 |
383.3 |
13.614 |
28.15 |
"187481 76f" |
2014-03-15 |
345.6 |
11.099 |
$3.839 |
31.14 |
"187,827 Vmv" |
2014-03-25 |
371.75 |
11.666 |
$3.789 |
31.87 |
"188198" |
2014-04-06 |
415.66 |
12.898 |
32.23 |
"188614
mostly P&G, some bursts of quickness aside
still need to install majorM0ds" |
2014-04-17 |
388.8 |
12.349 |
$3.919 |
31.48 |
"189003
some speed bursts (60+) but the main air-barrier mpg-lowering culprit is a new front air dam.... damn air!
will see after next fill.." |
2014-05-09 |
375.4 |
12.27 |
30.59 |
"189378 posted 6.4.14" |
2014-05-28 |
331.7 |
13.04 |
25.44 |
"189994
distance is wrong due to unknown partial or full fillup
was 171.7, added 160 as guestimate for 331.7.
still have front airdam which is probably hurting a lot." |
2014-06-08 |
396.4 |
12.829 |
$3.879 |
30.9 |
"190391" |
2014-06-20 |
351.5 |
11.672 |
$3.879 |
30.11 |
"190742 c.co" |
2014-07-03 |
358.75 |
10.888 |
32.95 |
"191,101
1st fillup after EB " |
2014-07-25 |
368.2 |
12.099 |
30.43 |
"191,735
next oil: 192,591..." |
2014-11-22 |
198.4 |
6.395 |
31.02 |
"198312" |
2014-12-29 |
264.7 |
5.936 |
44.59 |
"199432" |
2015-01-16 |
337.9 |
12.197 |
27.7 |
"200124" |
2015-01-26 |
323.3 |
11.669 |
$2.259 |
27.71 |
"200447
mpg seems lower in winter.
have new black plastic FGB" |
2015-02-09 |
350.2 |
12.052 |
29.06 |
"+.35 arco fee
200797" |
2015-02-23 |
349.5 |
12.779 |
27.35 |
"201147" |
2015-04-08 |
416.5 |
12.153 |
34.27 |
"202602 cstco, post tuneup, mostly roadtrip @ 65mph ) MHS" |
