2014-01-06 |
129 |
3.7 |
$1.39 |
34.86 |
"GBP" |
2014-01-06 |
213 |
4.31 |
$1.38 |
49.42 |
2014-01-11 |
138 |
3.49 |
$1.38 |
39.54 |
"New wheels put on car. They are 2% larger on rolling radius so manual adjustments need to be made as the car odometer reads 2% low. This is borne out by speedo now close to GPS speed with no real room for error." |
2014-01-16 |
151 |
3.62 |
$1.38 |
41.71 |
2014-01-24 |
174 |
4.09 |
$1.38 |
42.54 |
2014-01-25 |
52 |
1.27 |
$1.38 |
40.94 |
2014-01-26 |
192 |
3.91 |
$1.38 |
49.1 |
"This was a trip to Warrington to Ikea. Used cruise control at 65mph 90% of time. No grill block and normal tyre pressures, 36 psi all round." |
2014-02-08 |
179 |
4.12 |
$1.369 |
43.45 |
"Filled up at local Esso garage. Pump didnt stop and overfilled until diesel went on the floor. The pump reading was 16 litres. I have approximated 400ml went on the floor but ill never know. Next tank will likely be incorrect. May refill sooner rather than later to rectify reading.
Lower grille block now added too. Tyres are now pumped upto 38psi ish. 80% country lanes." |
2014-02-08 |
93 |
1.51 |
$1.35 |
61.59 |
"Filled up at Shell to try and get back to normal level after fuel spillage at Esso. Unsurprisingly I couldn't get much in. The results are still skewed as when I filled up at Esso the tank has been absolutely brim filled, so prob had 1/4 litre more than it should have, maybe more. Next fill will be back to normal. All suburban trips approx 7 miles through country lanes." |
2014-02-10 |
90 |
1.78 |
$1.35 |
50.56 |
"Fill up before setting off for Manchester. Lower grill block removed as temp got too high." |
2014-02-11 |
197 |
3.33 |
$1.35 |
59.16 |
"IKEA Manchester trip - NEW RECORD!" |
2014-02-22 |
238 |
4.81 |
$1.359 |
49.48 |
"Filled up with unleaded petrol by mistake. Doh! Emptied out and refilled with £67 of diesel....nightmare!" |
2014-02-25 |
56 |
1.18 |
$1.359 |
47.46 |
"Fitted Scangauge so zerod today." |
2014-03-14 |
5.87 |
$1.379 |
51.45 |
"Scangauge calibrated for imp gals. 18.5% adjustment. Mileage amended by 2% for wheel size." |
2014-04-06 |
625 |
11.76 |
$1.327 |
53.15 |
"Actually ran the car until it was almost empty. One 200 mile trip, rest just running around. Scangauge was zerod again. It was under reading slightly, so diff increased to a full 20%." |
2014-04-11 |
245 |
4.64 |
$1.379 |
52.8 |
"Regular Esso diesel." |
2014-04-23 |
390 |
7.16 |
$1.379 |
54.47 |
"Front air dam now fitted. 2 mpg improvement over last tank but not really A-B-A tested..and I cant be bothered! Regular Esso fuel used." |
2014-05-08 |
569 |
10.48 |
$1.349 |
54.29 |
"Redex fuel treatment added." |
