2014-01-07 |
360 |
7.03 |
$3.23 |
51.21 |
"Exclusively used for driving from Henderson to LV. Approx. 33.5 miles round trip. 70% city 30%hwy
3.79 trans
K&N
Route Used = Sahara95
Engine on coasting. Engine off if idle for > 30 sec. 44 psi." |
2014-01-21 |
7.23 |
$3.18 |
52.28 |
"Sahara95
Engine on coasting. Engine off if idle for > 30 sec." |
2014-02-03 |
7.89 |
$3.15 |
52.47 |
"Sahara95
2014-02-18 |
412 |
8.05 |
$3.28 |
51.18 |
"Sahara95
Station #1 closed. 7-11 gas.
2014-03-04 |
409.7 |
6.82 |
$3.33 |
60.07 |
"Changed route to BoluderSahara/Sahara95
Installed XFI cam and SRD underdrive pulley
Installed LSI aerodynamic headlights
Increased tires to 50 psi
Engine OFF coasting" |
2014-03-23 |
415.7 |
7.16 |
$3.41 |
58.06 |
"BoulderSahara/95Sahara
Installed H&R springs / KYB shocks.
Experimenting with different routes.
Testing for vibrations, 100+ MPH run.
95/215
95lakemede" |
2014-04-07 |
413 |
6.64 |
$3.45 |
62.2 |
"BoulderSahara/Sahara95
Top speed 68
SaharaLakeMedeBoulder return route" |
2014-04-27 |
518 |
8.25 |
$3.57 |
62.79 |
"Entire tank BoulderSahara/Sahara95.
Top speed 65
On a very windy day only got 47mpg." |
2014-05-14 |
446.2 |
7.09 |
$3.68 |
62.93 |
"100% BoulderSahara route
Top speed 55
Added for next tank :
+4 cam pulley
Start/kill switches
7/11 low grade" |
2014-06-03 |
554.6 |
7.71 |
$3.91 |
71.93 |
"Route BoulderSahara
Lots of EOC with these new kill switches.
Top speed 47 mph.
P&G between lights
7/11 premium. Timing adjusted. Noticed a few pings under load." |
2014-07-02 |
548 |
7.61 |
$4.03 |
72.01 |
"Bouldersahara
P&G between lights.
Top speed 45 mph.
7/11 premium." |
2014-07-27 |
585.7 |
9.31 |
$3.84 |
62.91 |
"AC Use on return trip
No EOC with AC running
49 MPH top speed
7/11 premium" |
2014-08-19 |
620.7 |
9.77 |
63.53 |
"AC use on return trip
7/11 premium
Added Aluminum water pump pulley" |
2014-09-14 |
646.8 |
9.84 |
$3.78 |
65.73 |
"Some AC use. Limited EOC with headlight use due to battery charging problems.
7/11 premium" |
2014-10-18 |
659.5 |
8.96 |
$3.33 |
73.6 |
"No more AC use
Still need a new deep cycle battery and LEDs
Circle K premium" |
2014-11-14 |
667.5 |
$3.11 |
70.26 |
"Need new battery.
7/11 mid" |
2014-12-06 |
520.5 |
8.8 |
$2.76 |
59.15 |
"Start/kill switch broken. Needs new battery." |
2014-12-28 |
502.6 |
8.89 |
$2.46 |
56.54 |
"Kill switches broken. 65 mph hwy." |
2015-01-12 |
451.5 |
8.76 |
$2.22 |
51.54 |
"Need battery, kill switches fixed. 65 mph hwy." |
2015-02-16 |
456.4 |
8.48 |
$2.36 |
53.82 |
"65 mph hwy. More battery problems." |
2015-04-03 |
448 |
8.22 |
$2.7 |
54.5 |
"65 mph - Replaced battery, but still needs new kill switch." |
2015-04-25 |
447 |
8.5 |
52.59 |
2015-05-19 |
480.5 |
9.05 |
$3.15 |
53.09 |
2015-06-15 |
497.1 |
8.32 |
$3.11 |
59.75 |
2015-07-12 |
490.8 |
9.01 |
$3.14 |
54.47 |
2015-08-06 |
514.6 |
8.51 |
$3.21 |
60.47 |
2015-08-28 |
531 |
8.84 |
$3.07 |
60.07 |
2015-09-19 |
532.4 |
8.67 |
$3.33 |
61.41 |
2015-10-18 |
541.9 |
9.02 |
$3.01 |
60.08 |
2015-11-08 |
527.6 |
8.45 |
$2.76 |
62.44 |
2015-11-29 |
509.3 |
8.83 |
$2.4 |
57.68 |
2015-12-22 |
479.2 |
8.5 |
$2.4 |
56.38 |
2016-01-10 |
470.1 |
9.02 |
$2.37 |
52.12 |
2016-02-01 |
477.6 |
8.21 |
$2.09 |
58.17 |
2016-02-16 |
449.3 |
7.99 |
$1.89 |
56.23 |
2016-03-04 |
475.1 |
8.9 |
$1.79 |
53.38 |
2016-03-19 |
498.2 |
8.11 |
$1.99 |
61.43 |
2016-04-06 |
512 |
8.76 |
$2.31 |
58.45 |
2016-04-22 |
570.8 |
$2.27 |
60.08 |
2016-05-20 |
537.8 |
8.68 |
$2.27 |
61.96 |
2016-07-22 |
515 |
8.49 |
$2.35 |
60.66 |
2016-08-12 |
583.5 |
9.73 |
$2.18 |
59.97 |
2016-08-31 |
550.4 |
9.22 |
$1.27 |
59.7 |
2016-10-09 |
504 |
9.7 |
$2.31 |
51.96 |
2016-10-24 |
529 |
9.26 |
$2.41 |
57.13 |
