2014-07-06 |
341.7 |
$3.78 |
28.48 |
"trip to itasca" |
2014-07-07 |
346.8 |
$3.86 |
26.68 |
"return trip
daytime, more traffic, some air" |
2014-07-19 |
465.1 |
17.8 |
26.13 |
"mixed driving
dry
75F" |
2014-07-27 |
422.3 |
16.4 |
$3.38 |
25.75 |
"Mixed driving
WAI after this" |
2014-08-02 |
510 |
17.8 |
28.65 |
"Highway trip and 1/4 mixed driving
new record range with.2 gal left
blocked CAI and have WAI now" |
2014-08-11 |
477.4 |
17.75 |
$3.57 |
26.9 |
"mixed driving
WAI
HAI installed today, 45 miles no problems" |
2014-08-19 |
372.3 |
14.7 |
$3.31 |
25.33 |
"Mixed driving, Idled for 10 min at tint shop
HAI temps per IR thermometer 120 to 129 @ throttle body, 115 @ MAF, Airbox inlet 100 to 110
Got window tint to help reduce Air Con use.
20% sides, 5% rear and 5% header
Cooler ambient temps" |
2014-08-20 |
71.1 |
2.45 |
29.02 |
"mixed
engine coded OD off?
Changed oil and filter 144,600 miles, fl820S, amsoil5w20
replaced muffler clamp, muffler was loose
tires@40psi" |
2014-08-26 |
435.5 |
17.05 |
25.54 |
"Mixed with some diagnostic idling time
tires set @44psi after this fill up
calibrated odometer 100mi each way via mile markers
x1.02" |
2014-09-03 |
446.8 |
17.1 |
26.13 |
"mixed driving and a 15 min traffic jam
removed (2) 5# exhaust weights" |
2014-09-17 |
208.1 |
$3.23 |
20.4 |
"deleted upper grill block,lower air dams to have transmission serviced
I am sure they had lots of idle time and some spirited testing of the rebuilt tranny
Torque converter lockup working now" |
2014-09-18 |
269.3 |
10.95 |
24.59 |
"tire pressure was down to 40 all around from 44
mixed driving, loaned car out for 30 miles?
deleted front air dam for tranny service
deleted partial wheel skirts
used HAI this tank, not last tank
Planned:
building belly pan
building PP wheel covers
reinstall modified front air dam
reinstall grill block" |
2014-09-24 |
424.3 |
17.16 |
$3.47 |
24.73 |
"mixed driving, ,70 degrees, tire PSI 40 - 42
still no front air dam or grill block" |
2014-09-25 |
289.8 |
11.37 |
$3.46 |
25.49 |
"Mixed, a bit more highway, partial front grill block, a little higher highway speed" |
2014-10-02 |
270.7 |
12.3 |
$3.23 |
22.01 |
"All city driving, less than 50mph, colder, 39psi in tires.
Added front lower air dams, added another inch lower in portions and extended a bit and stiffened with dynamat" |
2014-10-09 |
375.4 |
16.6 |
$3.02 |
22.61 |
"mostly city and some highway 70m to 80 mph
just shortened air dam about 1""" |
2014-10-14 |
180.6 |
7.7 |
$2.96 |
23.45 |
"cooler temps, no highway, 90% upper grill block
End of this tank, added rear diffuser/spoiler under rear bumper" |
2014-10-21 |
254.9 |
11.05 |
$2.96 |
23.07 |
"no highway, 43psi
end of this added partial rear wheel skirt
added rear under bumper diffuser/spoiler 8"" extension" |
2014-10-22 |
354.9 |
13.05 |
27.2 |
"commute 48 degrees, 43psi,
added partial rear wheel skirts and modified front wheel flare. Full HAI." |
2014-10-28 |
372.4 |
14.45 |
$2.91 |
25.77 |
"43 psi 63 degree high, wet. 50 % highway,
full tank on new rear wheel skirts, painted wheels, treated tires." |
2014-11-01 |
343.3 |
13.65 |
$2.72 |
25.15 |
"new brake pads and rotors, balanced and rotated tires" |
2014-11-07 |
331.5 |
12.9 |
$2.99 |
25.7 |
"new shocks all around, changed oil filter 149,000mi
tire pressure 43psi" |
2014-11-14 |
472.3 |
18.9 |
$2.83 |
24.99 |
"32 degrees, full HAI, mixed driving" |
2014-11-20 |
427.87 |
17.91 |
23.89 |
"cold 14 to 40 degrees, mixed, some idle and some highway 70 to 80
added hitch receiver plug diffuser and stabilized the rear diffuser @ 7 degrees" |
2014-11-26 |
399.6 |
17.05 |
$2.96 |
23.44 |
"mixed, cold, idle time for warm up" |
2014-11-30 |
243.8 |
10.14 |
$2.76 |
24.04 |
"MIxed, cold, tire pressure had dropped to 40psi all around, raised to 44psi" |
2014-11-30 |
213.2 |
7.08 |
$2.78 |
30.11 |
"highway trip, 50 degree temps, added coroplast wheel covers, target speed 65mph" |
2014-12-03 |
405.1 |
15.85 |
$2.69 |
25.56 |
"mixed, cold, some highway, seat heater, solar charger" |
2014-12-07 |
243.4 |
9.82 |
$2.52 |
24.79 |
"mixed, highway portion 70plus mph" |
2014-12-12 |
297.9 |
13.2 |
$2.32 |
22.57 |
2014-12-14 |
110.2 |
4.21 |
$2.28 |
26.18 |
"sealed drvrs side headlight area and plugged a bumper vent" |
2014-12-17 |
375.1 |
14.14 |
$2.19 |
26.53 |
"mixed" |
2014-12-19 |
148.9 |
6.42 |
$1.98 |
23.19 |
"all city, ice, short tank, added 45# at rear wheels." |
2014-12-23 |
208.1 |
7.71 |
$1.93 |
26.99 |
2015-01-04 |
306.7 |
11.23 |
$1.68 |
27.31 |
2015-01-04 |
164.3 |
7.12 |
$1.65 |
23.08 |
"all city and warmup" |
2015-01-08 |
309.1 |
14.79 |
$1.84 |
20.9 |
"coldddd 6to 10 degrees last 3 days
HAI 35 at air box 48 at out 72 to throttle body
opened to full on after this tank
lots of idle w engine warm up for son to school
Added 50# over rear axle in trunk" |
2015-01-14 |
351.7 |
16.23 |
$1.75 |
21.67 |
2015-01-20 |
412.1 |
17.91 |
$1.98 |
23.01 |
2015-01-21 |
361.6 |
15.31 |
$1.81 |
23.62 |
"cold, 50# added weight in trunk for last 4 tanks, need to check tire pressure. removed right side air dam, idle time and electric blanket." |
2015-02-01 |
362.1 |
15.1 |
$1.83 |
23.98 |
2015-02-03 |
395.8 |
16.24 |
$2.19 |
24.37 |
2015-02-11 |
379.5 |
17.1 |
$2.13 |
22.19 |
"Lots of engine idling and warm up." |
2015-02-13 |
362.1 |
16.24 |
$2.13 |
22.3 |
"idle and warm up
some high speed to 100, lol" |
2015-02-18 |
310.1 |
13.54 |
$2.01 |
22.9 |
"cold" |
2015-02-25 |
382.6 |
17.25 |
$2.18 |
22.18 |
"below zerooooo" |
2015-03-02 |
349.6 |
17.42 |
$2.24 |
20.07 |
2015-03-06 |
417.4 |
18.14 |
$2.14 |
23.01 |
"changed oil w amzoil 0w20 synthetic from amzoil 5w20,motorcraft fl802s stock filter" |
2015-03-13 |
342.7 |
14.12 |
$2 |
24.27 |
2015-03-16 |
272.4 |
12.26 |
$2.17 |
22.22 |
"gettn warmer up to 65 today. reinstalled new airdam 4.25 to 6"" taper out. extended inboard 3 more inches.
Removed a bit of ballast. tire pressure was up to 46#" |
2015-03-24 |
397.9 |
15.13 |
$2.48 |
26.3 |
"first tank w new air dam reinstalled" |
2015-03-26 |
393.8 |
15.34 |
$2.38 |
25.67 |
2015-03-31 |
541.1 |
17.31 |
$2.09 |
31.26 |
"Trip to Fl, first leg of 2,700 round trip, PSI 44.5
monitored HAI" |
2015-04-03 |
535.9 |
17.09 |
$2.38 |
31.36 |
"installed scan gauge for this tank.
removed a bit of grill block as temps warmed
hit a deer and it took out my pass side airdam last 120 miles" |
2015-04-12 |
344.9 |
16.28 |
$2.48 |
21.19 |
"On island, AC lots of idling w mom barely got out of 2nd gear. made new airdam, slimmed front wheel wells. taped rear skirts, retaped headlights, plan to add new rear spoiler. plan to extend decklid 5/8"" and raise an 1/8""" |
2015-04-18 |
524.32 |
17.39 |
$2.23 |
30.15 |
"E10 fuel extra 300# of moms baggage" |
2015-04-18 |
525.6 |
17.41 |
$2.32 |
30.19 |
"added extended rear deck spoiler 2"" @ 20 Degrees" |
2015-04-18 |
284.7 |
10.04 |
28.36 |
2015-05-07 |
366.2 |
15.67 |
$2.48 |
23.37 |
2015-05-20 |
358.6 |
13.1 |
$2.48 |
27.37 |
2015-06-05 |
358.7 |
12.13 |
$2.58 |
29.57 |
