2014-11-01 |
326.9 |
10.443 |
31.3 |
"I drove most of the miles, but my dad refilled the tank before this one and forgot to reset the trip until a few miles in. My brother also drove it around in a parking lot for practice, which killed the mileage and my mom drove it a couple of times as well." |
2014-11-19 |
326.9 |
$2.43 |
32.46 |
"It's getting cold out. Definitely not my best, but on the bright side, my performance is increasing because of the cold air. I didn't do as much highway driving this time, and had to go WOT once because I had to get up to speed to actually be safe. Tire pressure is also getting lower, and I didn't get a chance to fill them back up. Next time will definitely be higher." |
2014-12-15 |
319.1 |
9.392 |
$1.99 |
33.98 |
"Beginning of tank did some sporty/spirited driving. Used some more advanced techniques and used engine braking more often. Weather is supposedly cold, but it has been pretty warm out lately. Tires pumped up to 40 PSI. Next tank may or may not be better, depends on the weather. Should be getting instrumentation soon, which will help a lot." |
2015-01-18 |
241 |
9.104 |
$1.71 |
26.47 |
"This tank was a huge let down for me, but not too surprising. Last fillup I didn't go to my usual spot, and instead went to the place where gas was $0.02 cheaper. Made me underfill the tank, then my battery died that same day. During the time of it being dead, I did a lot of unnecessary idling, which led to the tank being bad. This next tank, though, will definitely be a good one!!" |
