2014-11-28 |
258.2 |
18.309 |
14.1 |
"one tire keeps going soft" |
2014-12-04 |
261.2 |
18.545 |
14.08 |
"Tire keeps going soft" |
2014-12-09 |
248.6 |
16.852 |
14.75 |
"Typical commute, cold and wet" |
2014-12-19 |
303.8 |
21.872 |
13.89 |
"Typical driving, cold & snow" |
2014-12-23 |
280.2 |
19.421 |
14.43 |
"Lot of extra driving made for a short tank." |
2014-12-31 |
272.2 |
19.689 |
13.82 |
"Cold and snowy." |
2015-02-03 |
228.7 |
19.722 |
"Replaced harmonic balancer and vacuum pump. Been cold." |
2015-07-06 |
332.4 |
21.17 |
15.7 |
"One of the first few tanks after replacing rear frame x-members, fuel tank, lift pump, sending unit and pickup strainer, oil pressure switch. Truck had numerous stalling issues since February, led to replacing a lot of stuff while tank was out. Had a gas strainer on the sending unit that was clogging in the cold, rusted out rear x-members, etc. Had to empty tank into barrels, ignored a tank or two due to sitting in garage testing" |
2015-07-18 |
328.5 |
20.286 |
16.19 |
"Exhaust still leaking is hurting turbo boost" |
2015-08-15 |
328.5 |
23.103 |
14.22 |
"Truck smoking badly, low power, been hot." |
2015-08-22 |
315.2 |
22.488 |
14.02 |
"Truck smoking badly, low on power, appears turbo not working." |
2015-09-19 |
312.4 |
21.296 |
14.67 |
"Truck smoking badly entire tank at all speeds, low power, turbo nearly non-functional. Replaced exhaust pipe at end of this tank and fixed vac leak, should see mpg improvement next tank. been warm." |
2015-10-09 |
314.2 |
21.391 |
14.69 |
"Turbo issue turned out to be leaking sensor, downpipe made little improvement. Unplugged sensor, CEL been on since" |
2015-10-17 |
318 |
22.032 |
14.43 |
2015-10-25 |
21.446 |
13.38 |
"Receipt had no date, assumed date to fill in gap in pattern" |
2015-11-07 |
419.2 |
28.428 |
14.75 |
"Includes partial fillup on 11/4" |
2015-11-14 |
362 |
22.638 |
15.99 |
2015-11-23 |
322.4 |
22.218 |
$2.389 |
14.51 |
"Turbo working, CEL on for a sensor. Cold out, but warm for time of year" |
2015-12-05 |
281 |
21.086 |
$2.389 |
13.33 |
"EGR sensor still unplugged" |
2015-12-13 |
311.1 |
20.762 |
$2.389 |
14.98 |
"EGR sensor still unplugged." |
2015-12-23 |
302.6 |
21.862 |
13.84 |
"EGR sensor still unplugged due to black smoke otherwise" |
2015-12-30 |
318.8 |
22.098 |
14.43 |
"EGR sensor still unplugged. Almost no snow so far. 30*s or so temps" |
2016-01-13 |
278 |
21.305 |
$2.239 |
13.05 |
"EGR sensor still unplugged. Significant snow, been mostly sub-20*" |
2016-01-23 |
265.3 |
19.817 |
13.39 |
"EGR sensor still unplugged. New General Grabbers installed, substantial aggressive tread. Expect mpg to decrease next tank." |
2016-02-01 |
283.9 |
21.656 |
$2.159 |
13.11 |
"Typical driving, been very cold." |
2016-02-22 |
269.9 |
21.907 |
12.32 |
"Winter" |
2016-03-03 |
291.3 |
21.641 |
13.46 |
"Been warming up for the season. No snow." |
2016-03-08 |
288.8 |
18.552 |
15.57 |
"Typical driving" |
2016-03-26 |
265.4 |
18.882 |
$2.159 |
14.06 |
"Typical driving, spent time in the garage replaced oil lines, exhaust donuts, idling to check for leaks." |
2016-05-20 |
267.2 |
16.904 |
$2.319 |
15.81 |
"Spring" |
2016-06-16 |
333 |
19.46 |
17.11 |
2016-06-24 |
315.3 |
17.662 |
17.85 |
2016-07-04 |
347.5 |
19.44 |
17.88 |
2016-07-14 |
268.55 |
16.264 |
$2.319 |
16.51 |
"2 separate fillups, had a fillup and forgot to reset trip odo. Split total tank and total miles between 2 fill dates to make up for this (so its not one 32gal fillup)" |
2016-07-28 |
268.55 |
16.264 |
$2.319 |
16.51 |
"2nd fillup from forgetting to reset trip odo. Took total miles and total fillup sum from both receipts and divided by 2." |
2016-08-26 |
303.1 |
18.544 |
16.34 |
2016-11-08 |
281.1 |
19.509 |
14.41 |
2016-12-09 |
302.5 |
21.608 |
14 |
2017-01-12 |
242.9 |
19.142 |
$2.629 |
12.69 |
"Stalling randomly, parked shortly after this tank" |
2017-05-08 |
277.8 |
22.231 |
12.5 |
2017-05-21 |
312.4 |
20.062 |
15.57 |
"New ECM this tank, cured stalling issue, was sitting for months until this point." |
