2014-12-23 |
351 |
11.23 |
$2.19 |
31.26 |
"blocked upper grill vents
weather stripping around headlights and front of hood
91 octane" |
2014-12-24 |
94 |
2.97 |
$1.98 |
31.65 |
"Ran 87 octane instead of 93 because the below freezing ambient temperatures lower the intake temps enough to not knock under low to mid boost conditions.
Might lower FE if the ECM switches to crappy fuel mode (less timing advance)" |
2014-12-28 |
123.2 |
3.6 |
$2.1 |
34.22 |
"93 octane" |
2014-12-31 |
172 |
6.07 |
$2.14 |
28.34 |
"'93 octane
very windy combined with low temperatures (<30°F)
Penelope is cold blooded" |
2015-01-07 |
11.02 |
31.03 |
"91 octane
front right wheel spat fell off." |
2015-01-18 |
68 |
2.31 |
29.44 |
"Super 93!
Left wheel spat fell off.
Penelope is hibernating for the winter" |
2015-03-22 |
12.26 |
$2.01 |
33.03 |
"Took 55 mph route home everyday vs 70 mph. Using neutral during braking and at stops (auto tans, so no engine off coasting)
E25 mix of 87 octane and E85 to boost octane rating and lower price" |
2015-04-02 |
147 |
4.23 |
$2.95 |
34.75 |
"Just drivin'" |
2015-04-20 |
8.78 |
$2.67 |
34.4 |
"93 octane
added weatherstripping to sides of hood" |
2015-04-28 |
282 |
8.62 |
32.71 |
"50-65 mph to work
91.8 octane (E30 mix)" |
2015-05-05 |
327 |
$2.69 |
32.06 |
"I accidentally burned the block heater cord on the exhaust last week, so no block heater
Super '93 all the way" |
2015-05-13 |
331 |
10.59 |
31.26 |
"still no block heater
Ran E30 due to increase in gas prices" |
2015-05-21 |
318 |
8.81 |
$2.61 |
36.1 |
"block heater back in action
'91 octane (all they had? price was good)
passenger side mirror delete - The seal was leaking so i thought I would try taking it off
door trims removed to replace broken window regulator and OEM speakers from 1998
10% city 90% hwy" |
2015-06-05 |
322 |
8.69 |
37.05 |
"Super 93!
Kept AC off as much as possible
LED tail light bulbs (only has an effect when brakes or on or lights are on)
I suspect the resonator is rusting out again (still?), it's gotten a bit louder" |
2015-06-10 |
246 |
6.48 |
$3.16 |
37.96 |
"Gas prices going up
The exhaust patch on the resonator blew out. Car has been intolerably loud" |
2015-06-18 |
353 |
10.68 |
$2.52 |
33.05 |
"E30 mix with some questionable 87 octane in the mix
Resonator replaced with a glasspack. Mufflers reconnected.
Road debris took out both wheel spats early in the week. I'm glad i slotted the mounting holes
Front tires may be a bit low due to cooler weather and rough roads due to construction." |
2015-08-03 |
10.06 |
34 |
"91 octane" |
2015-08-11 |
322 |
8.96 |
$2.89 |
35.94 |
"Super 93
Took the alt. route home. All speeds <=60 mph" |
2015-08-14 |
262 |
6.7 |
$3.56 |
39.1 |
"Super 93
Big changes!! Got tuning hardware and software
-timing table from '04 Grand Prix Comp G (same engine, more agrerssive fuel and timing tables)
-Bumped cruise timing advance forward 3 degrees
-Reduced idle fueling by 3% (it was running rich anyways)
-Used trans shift speeds and firmness from '04 Comp G - about 20% decrease in shift time/slippage
-Bumped TCC engage in 4th gear from 45 to 40 (there are a few 45 mph sections on my route home and it hadn't been turning the tcc on." |
2015-08-22 |
352 |
$2.42 |
37.05 |
"91 octane" |
2015-08-30 |
299 |
8.51 |
35.14 |
"91 octane
Front tires severely worn, pulling lightly to the right
I might have to let er sleep until my new struts and bushings come in" |
2015-09-09 |
322 |
8.48 |
$2.56 |
37.97 |
"93 octane
Replaced front steel impact bar w/ aluminum one from an '03 Aztec. Seems a little more nimbly-bimbly on take-off. Shed ~20 pounds
New front struts, rears coming soon
Ecopia EP422 ECO tires in front. I didn't notice much with the tires other than improved handling and traction compared to my worn out tires." |
2015-09-16 |
310 |
8.2 |
37.8 |
2015-10-01 |
322 |
8.31 |
38.75 |
"Nothing notable. Started using block heater. Weather is still in the upper 50s" |
2015-12-07 |
384 |
10.9 |
35.23 |
"Ugh, lost my mileage log for November
93 octane
Headed to CT on a ~600 mile trip" |
2015-12-07 |
487 |
14.89 |
$2.99 |
32.71 |
"Turnpike @ 75 mph
She doesn't do well above 65, but I need to get there by a certain time
Weather is excellent. No rain, upper 50s, lower 60s." |
2015-12-07 |
137 |
4.18 |
$2.83 |
32.78 |
"more turnpike" |
2015-12-13 |
102 |
3.6 |
28.33 |
"Back and forth between hotel and work area all week, probably 40% city compared to the usual 10-20. Not too bad" |
2015-12-13 |
433 |
14.9 |
$3.03 |
29.06 |
"Turnpike @ 65-70 mph
Bottom air dam came off and one wheel spat is loose
Colder and windy. Mid 40s, gusts around 40 mph at regular intervals" |
2016-04-21 |
31.96 |
"Super 93
Air dam was removed due to damage. Fixed wheel spats" |
