2014-11-28 |
421.5 |
23.662 |
17.81 |
"Fill up number 17. All data from fill up composite on 11/17 is of the truck with the Aerolid only mounted on the vehicle unless otherwise noted." |
2014-11-29 |
90.1 |
5.5126 |
16.34 |
"Fill up number 18 short cycle prior to a mpg test to Deming, NM." |
2014-11-29 |
140.1 |
6.09 |
23 |
"Fill up #19.Trip to Deming and back to the same gas station used in fill up #18." |
2014-12-09 |
248.6 |
14.431 |
$2.279 |
17.23 |
"Fill #20." |
2014-12-16 |
345.1 |
18.647 |
$2.179 |
18.51 |
"Fill up #21." |
2014-12-19 |
167.7 |
9.914 |
16.92 |
"Fill up #22." |
2014-12-31 |
471.9 |
26.396 |
$1.879 |
17.88 |
"Fill up #23. Last fill up for 2014." |
2015-01-06 |
158.4 |
9.56 |
$1.799 |
16.57 |
"1st fill up of 2015, it is the 24th fill up since the vehicle was purchased. The dealer turned the truck over to us with a full tank and 117 miles on the odometer when it was new." |
2015-01-16 |
231.9 |
13.804 |
$1.629 |
16.8 |
"Fill up #25-2." |
2015-01-23 |
395.8 |
22.74 |
$1.699 |
17.41 |
"Fill up 26-3." |
2015-01-30 |
187.3 |
11.542 |
$1.799 |
16.23 |
"Fill up #27-4." |
2015-02-04 |
208.9 |
12.019 |
$1.939 |
17.38 |
"Fill up #28-5." |
2015-02-13 |
401.2 |
23.223 |
17.28 |
"Fill up #29-6." |
2015-02-20 |
269.6 |
15.225 |
$2.059 |
17.71 |
"Fill up #30-7." |
2015-02-27 |
279.8 |
16.247 |
17.22 |
"Fill up #31-8" |
2015-03-13 |
463.4 |
25.538 |
18.15 |
"Fill up 32-9." |
2015-03-19 |
216.8 |
11.5 |
18.85 |
"Fill up 33-10." |
2015-03-31 |
354.4 |
19.573 |
$2.069 |
18.11 |
"Fill up #34-11." |
2015-04-09 |
245.1 |
13.173 |
18.61 |
"Fill up #35-12. Fill up the day prior to my trip to Monahans, TX for MPG testing with the boat tail mounted on the truck. I mounted the boat tail at the house so only 20 miles of fill up #36 includes the boat tail." |
2015-04-10 |
54.8 |
3.6 |
15.22 |
"Fill up #36-13. Fill up in Las Cruces, NM at an Alon station 1/2 mile from entrance ramp for I-10 for the start of my trip to Monahans, TX to meet Phil Knox. The boat Tail was mounted on the truck for the trip." |
2015-04-12 |
252.7 |
15.662 |
16.13 |
"Fill up #40-17-4 in Monahans prior to my return to Las Cruces, NM. It is primarily of trash mileage to and from Odessa, Monahans, and Pecos, TX without the boat tail mounted." |
2015-04-17 |
238.5 |
14.986 |
$2.189 |
15.91 |
"Fill up # 44-21, normal daily driving since return from trip without the boat tail mounted." |
2015-04-18 |
52.3 |
2.556 |
20.46 |
"Fill up #45-22, fill up prior to trip to City of Rocks State Park with the boat tail mounted. Eighteen miles only of this fill up includes the boat tail." |
2015-04-30 |
371 |
20.116 |
18.44 |
"Fuel up #47-24." |
2015-05-08 |
308.8 |
19.104 |
16.16 |
"# 48-25 fill up." |
2015-05-09 |
107.5 |
6.233 |
17.25 |
"#49-26 fill up. Fill up on Picacho prior to trip to Dming and back to this station. Next fill up (50-27) is on the Ford Stealth with Stinger log." |
2015-05-29 |
337.4 |
19.72 |
$2.549 |
17.11 |
"#53-30. Two weeks daily run about including towing a trailer a few times and idling to keep the AC running." |
2015-06-07 |
283.1 |
15.965 |
17.73 |
"#54-31. Occasional idling, good mpg in the highway however." |
2015-06-15 |
370.6 |
21.001 |
17.65 |
"#55-32. Idling in hot weather to keep the AC going and testing of the lift gate inserts for trailer towing which increase the wake area from 27 sq ft to 39 sq ft." |
2015-06-30 |
484.9 |
27.644 |
17.54 |
"#59-34. Last two fill ups 6/20 and 6/21 were for towing Apex trailer. Ninety (90) day fuel economy calculated 17.409 mpg." |
