2008-02-28 365.3 13.94 26.21 "the gas light came on while I was waiting for a gas pump in the station..
This usually means I have 2 gallons reserve till empty."
2008-03-04 436.1 14.76 29.55 "On my last fuel log, I forgot to make up for my slightly smaller size tires..
100% - 1.8% = 98.2 %
444.1 miles X 0.982 (which is the same as 98.2%) = 436.106 miles
436.106 miles / 14.766 gals = 29.534 MPG!!!!
I will adjust the last log to keep correct.."
2008-03-09 373.2 12.23 30.52 "Getting my light timing alot better with coasting to stops..
I'm working on wheel skirts currently and I'll be removing my antenna and maybe my tailgate for next tank to see how that works out.."
2008-03-15 393.1 13.26 29.65 "I dicked around and had some fun and all that for a bit, first time I've gone wide open with it since I've started the Hypermiling journey and it felt fast.. LOL
this next tank will reflect the wheel skirts and indicate if those are going to help.. so far the current tank has 1 trip up the Altamont Pass and that was killing my vac readings..
I'd also like to add that I used to fill up my tank once ever 3.5 days, now I'm at 6 days roughly.."
2008-03-20 418.3 14.29 29.27 "Did lots of mountain driving.. Goofed around a little, had to jump on it to avoid an accident.
Didn't draft any semi's at all, they all do 65mph now for some reason?
Its my birthday!"
2008-03-27 389.8 13.3 29.31 "very strange, I thought for sure i was in the 32mpg range on this one..
Air filters due, and now this tanks full of premium to see if that makes a difference (experiment)
and I have a huge road trip comming up.. 95% freeway, hello numbers! "
2008-03-30 376.1 12.49 30.11 "at just 1/3 of a tank of consumed fuel I was just shy of 240 miles.. I thought I was in like Flint for some serious FE till I realized my directions called for some steep mountain driving.. That killed it.. but i made up for some of it with coasting downhill.. But I still did pretty good for having goofing around in the offroad areas with my truck.. All in all, my average speed was around 57mph approx..
I'm not sure of the premium made a difference, fresh air filter.. Cant believe they cost over 20 bucks now.. I'm looking into a NON K&N reuseable/cleanable drop in filter, thats bs!..
I also drafted a truck for a good 40 miles solid, its great when you find a truck thats consistant on flat land.. my vac guage saw on average when drafting 18 vac
I also went from 36psi all around to 60psi front and 55psi rear on the tires..
I like it and I believe it made a difference..
I'm just keeping an eye on the wear characteristics..
I'm going to keep with premium for a few tanks worth then go back to regular to see if it makes a difference.."
2008-04-03 432.4 13.88 31.15 "watching my vacuum guage alot more and keeping it in the economy range, tires were pumped upto to 60psi front and 55psi rear.. Rides good..
I even hauled about 800lbs worth of granite headstones and cement..
slow steady throttle with very slight adjustment for acceleration..
MY NEW RECORD!!! I need to finish that bed cover and start reaping those benifits..
Still using premium.."
2008-04-05 104 3.111 33.43 "It wasn't a very long distance to travel, but it was all in town mileage.. A friend of mine kicked in on gas and said he'd fill it, so I took him up on it ans went with it..
reguardless of distance, mileage is mileage.. right?
Now I'll be going back to the 87 gas to see if it effects my mileage"
2008-04-11 361.3 12.7 28.45 "Had some serious WOT sessions, in persuit of a person that damaged my vehicle..
first tank of regular, but these results arent accurate because of the mad man like driving I had to do..
next tank will own all!
also scanguage II is on order"
2008-04-16 226.3 7.971 28.39 "100% city driving, still getting used to the scan guage..
Not discouraged, things will improve
87 octane.."
2008-04-23 348 12.01 28.98 "lots of in city driving, my alighment is off and pulling to the right after an inccodent..
I'm getting new tires with the proper size so I have the proper gearing and speedo % and an alignment soon there after..
also my water pump has started leaking at 118K miles..
Next project
87 octane as well.. I'm seeing a pattern in FE with regular vs premium.."
2008-05-02 289.9 10.49 27.64 "I coded in the HPR (horsepower) code into the X-Guage to see what that was all about..
It seems that top of 3rd is where you get your most accurate reading..
138hp.. and the gas mileage to prove it.."
2008-05-07 416.3 12.23 34.04 "The weathers getting warmer, this is geting easier
last tank was on regular Arco gas..
I filled today with Premium..
if I dont get a result on this tank, I'll just stick with regular..
I'm doing this to form my own opinion vs. going off of other peoples opinion.."
2008-05-10 298 12.91 23.08 "I ran premium to take care of detionation for
hauling a 6 foot by 12 foot enclosed trailer..
http://i4.photobucket.com/albums/y104/PentastarTurbo/tacoma/airshocks/P1050867.jpg
http://i4.photobucket.com/albums/y104/PentastarTurbo/tacoma/airshocks/P1050866.jpg
I tried to observe as many hypermiling techniques, but they just dont apply as well when hauling a trailer "
2008-05-16 348.3 12.57 27.71 "paid $3.85/gal for regular
hauled around the trailer for a day, then went into the mountains.."
2008-05-19 363.7 13.49 26.96 "paid $3.89/gallon regular
hauled the trailer for a few hours to clean out storage, also went to Hollister to go camping..
my fill on my scanguage got messed up..
readings are out of tune."
2008-05-27 387 13.96 27.72 "paid $4.05/gallon regular
didn't do a whole lot of hypermiling, just sticking to 55 on the freeway and trying to time lights..
the last couple of tanks, no ICE off.."
2008-06-03 428.2 15.02 28.51 "paid $4.29/gallon regular
did a little bit of EOC for about 6 miles on the tank..
I think I'm due for plugs..
Just got a camper shell too, so that mite help things a little.. We'll see.."
2008-06-10 349.1 11.36 30.73 "paid $4.39/gallon regular
did a bit of EO at lights.."
2008-06-15 355.4 13.18 26.97 "paid $4.47/gallon regular
I Can't seem to shake the high 20's ad get back into the 30's.. a/c's making that much of a difference I suppose.."
2008-07-17 283.6 12.19 $3.99 23.26 "Not much hypermiling till around the last 1/4 of a tank.. I'm living in a new state and i thought California was bad, sheesh..
I'm truly lagging on the maintenance..
its even running a little rough.."
2008-10-01 357.2 13.13 $3.22 27.2 "been a while since i've done a log"
